Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Properties from subclass added as not null to superclass table.
[Teneo] Properties from subclass added as not null to superclass table. [message #77414] |
Thu, 29 March 2007 14:07 |
Duncan Alexander Messages: 90 Registered: July 2009 |
Member |
--------------000405030101020600080007
Hi Martin et al,
I am noticing an issue with multiple inheritance and Teneo whereby properties from a subclass are
being mapped into the superclass' table but set to NOT NULL. The result is that whenever a type is
inserted into the table which does not have a discriminator type of that specific subclass these
columns are NULL and an error is thrown from the DB.
- Setup: EMF 2.2, Teneo 0.75 with latest fixes, JDK 1.5, Hibernate 3.2
- Inheritance mapping is set to SINGLE_TABLE
- See attached diagram for model snippit
Looking in particular at CodedXSMeasure, this inherits from CodedMeasure and XSMeasure, CodedMeasure
is a Measure, which is a Component which in turn is an Identifiable. Identifiable is the main
class for this heirarchy and hence it maps to a table in the DB.
From what I understand the way Teneo handles multiple inheritance, the features which
CodedXSMeasure inherits from XSMeasure will be pulled into the subclass declaration for
CodedXSMeasure (as XSMeasure is the secondary superclass) and will hence be included in the
Identifiable table which holds everything within that heirarchy.
The features inherited from XSMeasure are references to a Code and a MeasureTypeDimension.
In the Teneo generated hibernate mapping, the COdedXSMeasure subclass contains these two properties
and there NOT NULL attribute is set to true, which corresponds to the model as these properties are
mandatory for subclasses of XSMeasure. But, once this is mapped to the single table inheritance
mapping for the DB I would assume that these fields would be NOT NULL and referential integrity
would be enforced by Hibernate (or Teneo) when these objects were being persisted.
Is this a bug or am I misunderstanding how this works ?
Duncan
Content-Type: image/gif;
name="MultipleInheritanceDiagram.gif"
Content-Disposition: inline;
filename="MultipleInheritanceDiagram.gif"
R0lGODlhEgFUAcQAAE1NPtDQpr29l+npuqenhYyMcPDwwLKyj3x8Y2hoU5qa e8fHn9nZreHh
tAAAAJkAM///zP///wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
ACH5BAAAAAAALAAAAAASAVQBAAX/YCSOZGmeaKqubOu+cCzPdG3feK7vfO// wKBwSCwaj8ik
cslsOp/QqHRKrVqv2Kx2y+16v+CweEwum8/otHrNbrvf8Lh8Tq/b7/i8fl96 +P+AgYKDhIWG
g3yJOw8QjY6PkJGSk5SVkA+KmTeMlp2en5SYmqMynKCnqJWipKwtpqmwsaut tCivkA65sbEO
krO1wCO3jr2Nxbunx4+/wcDDEMrGx7rKucW60tfT1NjLzd8Rz9HXxtDm5b3k 59jq6b7gzeKP
7ObuxPXo6Nbr55HM8KTk5cNnD5o7cgjnDfQH0NmkfdLyTetHb107g+8a0noG KxoyhhpbcUzl
8aO3kKxG/5pc2egfSj4qWZp0+VJPzEYEAgQoKYnnowAEPtGsieemAAG5diII AADAzgIHlhKD
CuGANQcFICA9KsDTUKJ2bgLIB2DAAAAODDhYME0tBAYFEmDNBmFsp69g6Ygl axYtPmNuHTBo
4ABB0GN2LeHNK8doV3dMnR6cegCCgqsBtDogcNQr40Q3IeSU2Qio0M8wSat2 tBi1m9CrUbV2
zQZ2bFCzaas5xLu3b966i94mnTv4GdvD7xoPm5xl8eVkkDcPBV3v7+vYe1ef I316xu1wunu/
BD6O+PGsy4dHv+u5+i7n2bt/vyU++vn0s2Tfzz9QfnD4/VdTgAKGhAmBBQJ0 YP+C262CIIPB
OAihcbM8OKFIfVxI2y8WapjJPx16CNMJIYqYB00lmhiWISoylmKLoMHo2osy 2lTjZzTeeEeO
OtbBY4/cAUnUj0KGV+RLRB7ZRpJKrsFkk2k8CeVxUypYJTxSXjlGllqGwWWX X3wJJnxjOlNm
LWKeqZ+aGLIZkJtvwmlGf3QWImcTaWZ45xJ5ktCnm3+KEKiagw565lC5jJAo EIaWSZMDEUAa
qaSM7slnCpBKao2ii066aaSedkqipUo8CuqmlIIqAqWanrpqCo2OaWqiV4VK wqeZrvrpqKQi
4ZKmuSr6qqqLBpuqLb36ikKrnuraKa2ocqpCrGAWmuz/EdZeW0S22g7BbbdB fAvuD+KO20O5
5i4iBbVdoptuDnXG69+7WLBLrw723rtJOPouyW+/uwkDcJQCD0yloAbPqWfC YnDI8JYLP+wF
iBKHyWvF9cGKcX0sbjyxxxCD7KXII5Nssckfo0ymyjjI6/LLfuibrw0z01cz DTerl3Mp9/6q
sAnHCplq0LdGXPQJQweRNKYm/EP00iJC/WyziT6w69VTC+uD1MyiKqnVrBab 9bAaSk12tJFa
/WrXSB+9g9nE5tqqKMaqWgLUFy5dq7Ohqu2q3aLi/fbRe9NqK93E6uq23R4m HTTa4bTKrNaC
8+D43XL7uTbZiWvdI66KW+M3/7CkS4G215AiTrWocu4cg+sNvgF7dbO7UPty t7OQe3C7T9uz
7CbCLPzwzBBvfHYpsac8eX0s713v5zrvfPHSNwc9D/ZVDwv12t92/SLd39d0 +LF9jy8lE6Hi
U0HlJMc9+t1Esn7791if/EP1J4M+RhG5P/7+9MMFALsRP+/dryfEgAj/FggR AnIjgQ5kBzX0
kQ6fvA+B89iGNiDYP4NI8IP82EcBQTKKkWxjIPZIYQgl8pdx9GOF/PiOMCpR DRTCMCEqvEcN
WxhAEmrChAlcyA09qMLJXIWD/EsIESdxQfkphIdHvMhBGijB9qVQgTL8EACT OEQlWpEgL4yh
DdVBnf/mbZEeXoyhEZ9YQyX65CQlpOEELRJEuniQLu2gIjc0SJERtuR/8Nug HfX4xSVGMYJ9
fKP54EW+5wGykc45ICQNaMZJrmSRLbPkcJqoSVlIspMy4SQoZfPJUc7kkaYk ZUBSGUpUsvI0
q3zlKSspS1jGsZbIECUumVjKXeLGlb7MoiKOR8z+NK2YyLQThDDpil7FrCjO /JePpHmnBYWF
mq3DZmO0ySYJTZObhyrY3fyFsMW1qHJaq1DbgGZOI7BKBcfypufMSbTycG1t VetD2ErHuXoq
bZ7Fatak1CnQq40zP3Djp8Pq9rR2/rOfwwLdQjfHToduR2+4ymfT6japxfn/ EwjvdBY/c1G8
rgnuo9W53K00qs/ORdSiQwjpsSS6UYgy7qYTOp0DQFS6XWVBp6sq3upQqiMU GelisurYa5QJ
KBuRipnNfKpTeZfMqsarD1bNqlJrE8zy0bKrp4BqOMCqGg6RNRVizd5Z4Sio tYZVdm695Ffj
WsYl4a+HnnhjQSqoPbMGcotOTF9F8rdJuGIwjHmlIQsRKz4/nfGuGMwhXztY 2NdA9oh1ROQC
7wjGDGI2gtoo4gN56VjIdpCKSMzhaSf72TlWcLKktethKyLIIhYyfQy0IhmF 6Ea8/rG0h+2i
DQOIxnrsln29ZexvZevE/pGxt5/94g7zqEDU3hCL/2wdq2mhK0LpCtCIra0t CrGb3d1c9iJc
TKMaeahGF77QtspND3Cbm17eeneFU2SjQpKrCsP2xLWZ5SNn7zgRAkr3g6/l oIB9qN2HVHGQ
IBQsehN8SD4umMHmpWsu56phDEepw+3hMIjly9wRv3W+Ji7vh1N84hmymHkl frFiRGzitMrY
lm298XK5quMZo/jFNu5xf3/M4iALObY51nFatcrk62C1yVAWa4LQCaWZsiGk NqCyerTsAi5T
ActXEZviBGrT/2C0cHEjM+OICgUsd05uHMUbm3WTUIoabnJr5gKYX5qpOAO0 QHrjc+hc6uUp
yFTQhnszTO1ZNLYB6294nv8zFhz9aJfWyNFpxjPLqBDlJm8aBlL+3afXNOp6 lXoKhzg1njSm
aiZQTHad3qpuXm1ZTYYaCg5bj61pZzQeW/LWT8i1f5PhR9+2GHfiHPYncCvA DfO6nLrWXwZT
+8a6Ihvayk5s/eBbbWHyDpxOIol+EUJe5cQO2N05IRRDDB5gN5jYguRsuX0c kFj/xgpq9WpK
VsbpTrob1PxGtb/blLEq5BsZBvB2jLhArWfkZCcfqYZHNuPhha8TcGGTFrmC 7cqjJKUwkXlK
VDJTGrQkoCkBOEABHLAVjDzFGJ1RscXbdmhjSZpnwX7muxthF3eU5SxpWQti BlCXvgRdhL0g
QFb/ypGYHf8QnnKO2z5FmrgwszoKMRtGz83xc78UpCxFB7pa1G0YpsO4hFA/ qKsgZ2nJWVpz
OQ9EJDoDGZRPpuQOOLlTVM5yiuviMiQHQMxJjHZMPQ6fttpbR91uK6T6wDd+ 8oMkRuMd05z9
6ct6KaSDJWhIv71pttsPqEVx8LISXO0Zf7PYxJx4jY9KO+Gq0MD3zXB8zz5O BV9CPe3N1BLy
HvZKYJ2Lf316UrueUzdvwe5vX/jcfz75yrcF8zHvfE1zXgfL3zXtq8+5hwIz fP9+Qc5moWmQ
Sl/7uNcC+bufhNITp/imRr6woL+J6X8o4Ouy/zDxj3X9z9z4qPZ7ggB//1cQ flQlgLLWagp4
MAuIdQ24LpgDNML3gOpCORVFgRtngY2GgRmoeRxIBOuHUx/YgZ83go+3Uu9E fya4AgbYLS2o
LS94LTGYLDMYTSvYfjeIgzmILTvIgz24LT8IhEHoLUNYKf8SgkVIM/xCfiqY hAJjTfPkhDyj
c1Eoha9DhexnheKHhSKohbZzcRWDgGIIfDXifkJWg2Bghj2GhmFyZK1UVIAV Xx2BWXnVXSbR
bUgmIyakbqSBh08kh44Ehw4GQRoUWiE0WrcVPwYWEWGmbtVFW4Y4ZDcCRHfn QtO1XvQjWYWE
EVI0Rt81XHkII5RoXJpFWxaxiOwVXYx4YACWW6H8pXDBsz93t237BYr5o4l/ 2IrIRVyeKIds
ODEDlA2hlWB4hETvhUV6VIm6JVoStomwKCJquAvF5n+xSD7sk0q/CB9uGElF NYbeSAg9Eo03
lo0Mt41yJYjm6GyTmI4fQY71wY7qWIbfOI+AEI7wyG7reI/bY4/6iFb82I/H pocAqUqTSI8G
6YUImZAKuZAM2ZAO+ZAQGZESOZEUWZEWqSYhAAA7
--------------000405030101020600080007--
Re: [Teneo] Properties from subclass added as not null to superclass table. [message #77486 is a reply to message #77414] |
Thu, 29 March 2007 15:16 |
Hi Duncan,
Yes this is a bug (or a missing feature). Setting nullable for inherited features in case of single
table is done for eattributes (primitive types) but not for EReferences. Please enter a bugzilla for
this.
gr. Martin
Duncan ALexander wrote:
> Hi Martin et al,
> properties from a subclass are being mapped into the superclass' table
> but set to NOT NULL. The result is that whenever a type is inserted into
> subclass these columns are NULL and an error is thrown from the DB.
> and XSMeasure, CodedMeasure is a Measure, which is a Component which in
> turn is an Identifiable. Identifiable is the main class for this
> features which CodedXSMeasure inherits from XSMeasure will be pulled
> into the subclass declaration for CodedXSMeasure (as XSMeasure is the
> secondary superclass) and will hence be included in the Identifiable
> contains these two properties and there NOT NULL attribute is set to
> true, which corresponds to the model as these properties are mandatory
> table inheritance mapping for the DB I would assume that these fields
> would be NOT NULL and referential integrity would be enforced by
> Duncan
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Properties from subclass added as not null to superclass table. [message #77601 is a reply to message #77486] |
Thu, 29 March 2007 21:31 |
I was to quick with my analysis, ereference and single table are supported, this error occurs only
in multi-inheritance situations. I will provide a fix for this in the next release.
gr. Martin
Martin Taal wrote:
> Hi Duncan,
> features in case of single table is done for eattributes (primitive
> types) but not for EReferences. Please enter a bugzilla for this.
> gr. Martin
>> Hi Martin et al,
>> whereby properties from a subclass are being mapped into the
>> type is inserted into the table which does not have a discriminator
>> type of that specific subclass these columns are NULL and an error is
>> thrown from the DB.
>> CodedMeasure and XSMeasure, CodedMeasure is a Measure, which is a
>> the features which CodedXSMeasure inherits from XSMeasure will be
>> pulled into the subclass declaration for CodedXSMeasure (as XSMeasure
>> Duncan
The Netherlands
Re: [Teneo] Properties from subclass added as not null to superclass table. [message #77616 is a reply to message #77601] |
Fri, 30 March 2007 09:28 |
Member |
Ah right, no worries. Do you still want it in Bugzilla ?
> supported, this error occurs only in multi-inheritance situations. I
> gr. Martin
> Martin Taal wrote:
>> Hi Duncan,
>> inherited features in case of single table is done for eattributes
>> this.
>> gr. Martin
>>> Hi Martin et al,
>>> thrown from the DB.
>>> the single table inheritance mapping for the DB I would assume that
>>> these fields would be NOT NULL and referential integrity would be
>>> persisted.
>>> Duncan
Re: [Teneo] Properties from subclass added as not null to superclass table. [message #77659 is a reply to message #77616] |
Fri, 30 March 2007 10:48 |
Yes please, the bugzillas are used to generate the release notes.
gr. Martin
>> gr. Martin
>> Martin Taal wrote:
>>> Hi Duncan,
>>> for this.
>>> gr. Martin
>>>> Hi Martin et al,
>>>> the Identifiable table which holds everything within that heirarchy.
>>>> subclass contains these two properties and there NOT NULL attribute
>>>> are mandatory for subclasses of XSMeasure. But, once this is mapped
>>>> to the single table inheritance mapping for the DB I would assume
>>>> that these fields would be NOT NULL and referential integrity would
>>>> persisted.
>>>> Duncan
The Netherlands
Re: [Teneo] Properties from subclass added as not null to superclass table. [message #78492 is a reply to message #77659] |
Thu, 05 April 2007 14:29 |
Member |
belatedly added to Bugzilla today.
Duncan
> gr. Martin
>>> gr. Martin
>>> Martin Taal wrote:
>>>> Hi Duncan,
>>>> for this.
>>>> gr. Martin
>>>>> Hi Martin et al,
>>>>> a type is inserted into the table which does not have a
>>>>> discriminator type of that specific subclass these columns are NULL
>>>>> main class for this heirarchy and hence it maps to a table in the DB.
>>>>> in the Identifiable table which holds everything within that
>>>>> heirarchy.
>>>>> persisted.
>>>>> Duncan
Re: [Teneo] Properties from subclass added as not null to superclass table. [message #604027 is a reply to message #77414] |
Hi Duncan,
this.
gr. Martin
> Hi Martin et al,
> Duncan
The Netherlands
Re: [Teneo] Properties from subclass added as not null to superclass table. [message #604056 is a reply to message #77486] |
gr. Martin
Martin Taal wrote:
> Hi Duncan,
> gr. Martin
>> Hi Martin et al,
>> thrown from the DB.
>> Duncan
The Netherlands
Re: [Teneo] Properties from subclass added as not null to superclass table. [message #604058 is a reply to message #77601] |
Member |
> gr. Martin
> Martin Taal wrote:
>> Hi Duncan,
>> this.
>> gr. Martin
>>> Hi Martin et al,
>>> thrown from the DB.
>>> persisted.
>>> Duncan
Re: [Teneo] Properties from subclass added as not null to superclass table. [message #604073 is a reply to message #77616] |
gr. Martin
>> gr. Martin
>> Martin Taal wrote:
>>> Hi Duncan,
>>> for this.
>>> gr. Martin
>>>> Hi Martin et al,
>>>> persisted.
>>>> Duncan
The Netherlands
Re: [Teneo] Properties from subclass added as not null to superclass table. [message #604368 is a reply to message #77659] |
Member |
Duncan
> gr. Martin
>>> gr. Martin
>>> Martin Taal wrote:
>>>> Hi Duncan,
>>>> for this.
>>>> gr. Martin
>>>>> Hi Martin et al,
>>>>> heirarchy.
>>>>> persisted.
>>>>> Duncan
Current Time: Tue Apr 23 09:27:55 GMT 2024
Powered by FUDForum. Page generated in 0.05125 seconds
