Problem deploying Spring web bundle - ContextLoaderListener not found [message #723494] |
Thu, 08 September 2011 16:50 |
Simon Watson Messages: 30 Registered: September 2011 |
Member |
Hi all,
I'm new to Virgo and trying to get my first web bundle working with Virgo 3, Spring 3.0.5, and Eclipse 3.7.
I've created a simple web project bundle but Virgo fails to deploy it, throwing an exception: java.lang.ClassNotFoundException: ?org.springframework.web.context.ContextLoaderListener
To try and ensure I'm not missing any dependencies, I've now added the Spring library to my manifest but I still get the same problem. In my Eclipse project's bundle dependencies, I can see all the Spring JARs, including .../virgo-tomcat-server-3.0.0.RELEASE/repository/ext/org.springframework.web-3.0.5.RELEASE.jar. In Virgo's admin tool I can also see that this bundle has been loaded.
If I remove the following lines from web.xml, the bundle deploys and I can access static pages e.g. index.html.
<listener>
<listener-class>org.springframework.web.context.ContextLoaderListener</listener-class>
</listener>
Given I'm new to this, I'm sure I'm missing something obvious but would be very grateful for any pointers.
Simon.
web.xml
<display-name>Test Spring Web App</display-name>
<context-param>
<param-name>contextClass</param-name>
<param-value>org.eclipse.virgo.web.dm.ServerOsgiBundleXmlWebApplicationContext</param-value>
</context-param>
<listener>
</listener>
<servlet>
<servlet-name>springmvc</servlet-name>
<servlet-class>org.springframework.web.servlet.DispatcherServlet</servlet-class>
<init-param>
</init-param>
<load-on-startup>1</load-on-startup>
</servlet>
<servlet-mapping>
<url-pattern>/app/*</url-pattern>
</servlet-mapping>
<welcome-file-list>
<welcome-file>index.html</welcome-file>
</welcome-file-list>
</web-app>
MANIFEST.MF
Manifest-Version: 1.0
Class-Path:
Bundle-Version: 1.0.0
Bundle-Name: Test Spring Web App Bundle
Bundle-ManifestVersion: 2
Web-ContextPath: /test
Bundle-SymbolicName: com.my.test
Import-Package: org.eclipse.virgo.web.dm
Import-Library: org.springframework.spring;version="[3.0.5.RELEASE,3.0.5.RELEASE]"
Exception from log:
Sep 8, 2011 5:24:53 PM org.apache.catalina.core.StandardContext listenerStart
[2011-09-08 17:24:53.496] ERROR Thread-101 System.err SEVERE: Error configuring application listener of class ?org.springframework.web.context.ContextLoaderListener
[2011-09-08 17:24:53.496] ERROR Thread-101 System.err java.lang.ClassNotFoundException: ?org.springframework.web.context.ContextLoaderListener
[2011-09-08 17:24:53.496] ERROR Thread-101 System.err at org.eclipse.gemini.web.tomcat.internal.loading.BundleWebappClassLoader.loadClass(BundleWebappClassLoader.java:306)
[2011-09-08 17:24:53.496] ERROR Thread-101 System.err at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
[2011-09-08 17:24:53.496] ERROR Thread-101 System.err at org.apache.catalina.core.DefaultInstanceManager.loadClass(DefaultInstanceManager.java:415)
[2011-09-08 17:24:53.496] ERROR Thread-101 System.err at org.apache.catalina.core.DefaultInstanceManager.loadClassMaybePrivileged(DefaultInstanceManager.java:397)
[2011-09-08 17:24:53.496] ERROR Thread-101 System.err at org.apache.catalina.core.DefaultInstanceManager.newInstance(DefaultInstanceManager.java:118)
[2011-09-08 17:24:53.497] ERROR Thread-101 System.err at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4638)
[2011-09-08 17:24:53.497] ERROR Thread-101 System.err at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5204)
[2011-09-08 17:24:53.497] ERROR Thread-101 System.err at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5199)
[2011-09-08 17:24:53.497] ERROR Thread-101 System.err at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
[2011-09-08 17:24:53.497] ERROR Thread-101 System.err at java.util.concurrent.FutureTask.run(FutureTask.java:138)
[2011-09-08 17:24:53.497] ERROR Thread-101 System.err at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
[2011-09-08 17:24:53.497] ERROR Thread-101 System.err at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
[2011-09-08 17:24:53.497] ERROR Thread-101 System.err at java.lang.Thread.run(Thread.java:680)
FUDForum. Page generated in 0.03724 seconds
