Home » Eclipse Projects » Virgo » VTS 3.0 can't resolve constraint satisfied by a package in /repository/usr
Re: VTS 3.0 can't resolve constraint satisfied by a package in /repository/usr [message #723489 is a reply to message #723318] |
Thu, 08 September 2011 16:44 |
I'm not sure what is going on here, I have two hunches.
It is either finding the mini bundles in repository/ext and getting confused between that one and the one in usr or the package version doesn't match. Can you double check the manifest in your mini bundle and the 'pshd.plan-3.2-ru.focusmedia.odp.poim.server' bundle.
Chris.
Chris Frost, Twitter @cgfrost
Springsource, a divison of VMware.
Re: VTS 3.0 can't resolve constraint satisfied by a package in /repository/usr [message #723715 is a reply to message #723489] |
Fri, 09 September 2011 08:46 |
Alexey Romanov Messages: 263 Registered: May 2010 |
By "mini bundles" do you mean Mina bundles? There are no Mina bundles in /repository/ext, and here is the manifest from mina-core-2.0.2.jar:
Manifest-Version: 1.0
Export-Package: org.apache.mina.proxy.handlers.http.ntlm;uses:="org.ap
ache.mina.proxy.session,javax.crypto,org.slf4j,org.apache.mina.proxy,
javax.crypto.spec,org.apache.mina.proxy.handlers,org.apache.mina.core
.filterchain,org.apache.mina.proxy.handlers.http,org.apache.mina.util
,org.apache.mina.proxy.utils";version="2.0.2",org.apache.mina.core.fu
ture;uses:="org.apache.mina.core.polling,org.apache.mina.core.session
,org.apache.mina.core.service,org.apache.mina.util,org.apache.mina.co
re";version="2.0.2",org.apache.mina.filter.codec.demux;uses:="org.apa
che.mina.core.session,org.apache.mina.core.buffer,org.apache.mina.uti
l,org.apache.mina.filter.codec";version="2.0.2",org.apache.mina.handl
er.demux;uses:="org.apache.mina.core.future,org.apache.mina.core.sess
ion,org.apache.mina.core.service,org.apache.mina.util";version="2.0.2
",org.apache.mina.core.buffer;version="2.0.2",org.apache.mina.filter.
keepalive;uses:="org.apache.mina.core.future,org.apache.mina.core.ses
sion,org.apache.mina.core.filterchain,org.slf4j,org.apache.mina.core.
write";version="2.0.2",org.apache.mina.util.byteaccess;uses:="org.apa
che.mina.core.buffer";version="2.0.2",org.apache.mina.handler.stream;
uses:="org.apache.mina.core.future,org.apache.mina.core.session,org.a
pache.mina.core.buffer,org.apache.mina.core.service,org.slf4j";versio
n="2.0.2",org.apache.mina.transport.vmpipe;uses:="org.apache.mina.cor
e.future,org.apache.mina.core.buffer,org.apache.mina.core.write,org.a
pache.mina.core.session,org.apache.mina.core.filterchain,org.apache.m
ina.core.service,org.apache.mina.util";version="2.0.2",org.apache.min
a.handler.multiton;uses:="org.apache.mina.core.session,org.apache.min
a.core.service";version="2.0.2",org.apache.mina.filter.stream;uses:="
org.apache.mina.core.file,org.apache.mina.core.future,org.apache.mina
.core.session,org.apache.mina.core.buffer,org.apache.mina.core.filter
chain,org.apache.mina.core.write";version="2.0.2",org.apache.mina.fil
ter.executor;uses:="org.apache.mina.core.future,org.apache.mina.core.
session,org.apache.mina.core.buffer,org.apache.mina.core.filterchain,
org.slf4j,org.apache.mina.core.write";version="2.0.2",org.apache.mina
.filter.errorgenerating;uses:="org.apache.mina.core.session,org.apach
e.mina.core.future,org.apache.mina.core.buffer,org.apache.mina.core.f
ilterchain,org.apache.mina.core.write,org.slf4j";version="2.0.2",org.
apache.mina.filter.codec;uses:="org.apache.mina.core.file,org.apache.
mina.core.future,org.apache.mina.core.session,org.apache.mina.core.bu
ffer,org.apache.mina.core.filterchain,org.apache.mina.core.service,or
g.slf4j,org.apache.mina.core.write";version="2.0.2",org.apache.mina.f
ilter.util;uses:="org.apache.mina.core.session,org.apache.mina.core.f
ilterchain,org.apache.mina.core.write";version="2.0.2",org.apache.min
a.filter.statistic;uses:="org.apache.mina.core.session,org.apache.min
a.core.filterchain,org.apache.mina.core.write";version="2.0.2",org.ap
ache.mina.core.polling;uses:="org.apache.mina.core.future,org.apache.
mina.core.buffer,org.apache.mina.core,org.slf4j,org.apache.mina.core.
write,org.apache.mina.core.file,org.apache.mina.core.session,org.apac
he.mina.core.filterchain,org.apache.mina.core.service,org.apache.mina
.util,org.apache.mina.transport.socket";version="2.0.2",org.apache.mi
na.handler.chain;uses:="org.apache.mina.core.session,org.apache.mina.
core.service";version="2.0.2",org.apache.mina.proxy.handlers;version=
"2.0.2",org.apache.mina.core.filterchain;uses:="org.apache.mina.core.
future,org.apache.mina.core.session,org.apache.mina.core.buffer,org.a
pache.mina.core.service,org.slf4j,org.apache.mina.core.write";version
="2.0.2",org.apache.mina.filter.buffer;uses:="org.apache.mina.core.se
ssion,org.apache.mina.core.buffer,org.apache.mina.core.filterchain,or
g.apache.mina.util,org.apache.mina.core.write,org.slf4j";version="2.0
.2",org.apache.mina.core.service;uses:="org.apache.mina.core.future,o
rg.apache.mina.core,org.slf4j,org.apache.mina.core.write,org.apache.m
ina.core.session,org.apache.mina.core.filterchain,org.apache.mina.uti
l";version="2.0.2",org.apache.mina.proxy.handlers.http;uses:="org.apa
che.mina.proxy.handlers.http.ntlm,org.apache.mina.core.future,org.apa
che.mina.core.buffer,org.apache.mina.proxy.session,org.apache.mina.pr
oxy.handlers.http.digest,org.slf4j,org.apache.mina.proxy,org.apache.m
ina.core.session,org.apache.mina.proxy.handlers,org.apache.mina.core.
filterchain,org.apache.mina.proxy.handlers.http.basic,org.apache.mina
.proxy.utils";version="2.0.2",org.apache.mina.proxy.handlers.http.bas
ic;uses:="org.apache.mina.proxy.handlers,org.apache.mina.core.filterc
hain,org.apache.mina.proxy.handlers.http,org.apache.mina.util,org.apa
che.mina.proxy.utils,org.apache.mina.proxy.session,org.slf4j,org.apac
he.mina.proxy";version="2.0.2",org.apache.mina.transport.socket.nio;u
ses:="org.apache.mina.core.buffer,org.apache.mina.core,org.apache.min
a.core.session,org.apache.mina.core.polling,org.apache.mina.core.file
,org.apache.mina.core.filterchain,org.apache.mina.core.service,org.ap
ache.mina.transport.socket";version="2.0.2",org.apache.mina.filter.co
dec.serialization;uses:="org.apache.mina.core.session,org.apache.mina
.core.buffer,org.apache.mina.filter.codec";version="2.0.2",org.apache
.mina.filter.codec.prefixedstring;uses:="org.apache.mina.core.session
,org.apache.mina.core.buffer,org.apache.mina.filter.codec";version="2
.0.2",org.apache.mina.proxy.filter;uses:="org.apache.mina.core.buffer
,org.apache.mina.proxy.session,org.apache.mina.core.write,org.slf4j,o
rg.apache.mina.proxy,org.apache.mina.core.session,org.apache.mina.pro
xy.handlers,org.apache.mina.proxy.handlers.socks,org.apache.mina.core
.filterchain,org.apache.mina.proxy.handlers.http,org.apache.mina.prox
y.event";version="2.0.2",org.apache.mina.filter.firewall;uses:="org.a
pache.mina.core.session,org.apache.mina.core.future,org.apache.mina.c
ore.filterchain,org.slf4j,org.apache.mina.core.write";version="2.0.2"
,org.apache.mina.core;uses:="org.apache.mina.core.future,org.apache.m
ina.core.session,org.apache.mina.core.buffer";version="2.0.2",org.apa
che.mina.proxy.session;uses:="org.apache.mina.core.future,org.apache.
mina.proxy.filter,org.apache.mina.core.session,org.apache.mina.proxy.
handlers,org.apache.mina.proxy.event,org.apache.mina.proxy";version="
2.0.2",org.apache.mina.proxy.handlers.http.digest;uses:="javax.securi
ty.sasl,org.apache.mina.proxy.session,org.slf4j,org.apache.mina.proxy
,org.apache.mina.core.session,org.apache.mina.proxy.handlers,org.apac
he.mina.core.filterchain,org.apache.mina.proxy.handlers.http,org.apac
he.mina.util,org.apache.mina.proxy.utils";version="2.0.2",org.apache.
mina.core.write;uses:="org.apache.mina.core.future,org.apache.mina.co
re.session,org.apache.mina.util";version="2.0.2",org.apache.mina.prox
y;uses:="javax.security.sasl,org.apache.mina.core.future,org.apache.m
ina.proxy.filter,org.apache.mina.core.buffer,org.apache.mina.proxy.se
ssion,org.apache.mina.core.write,org.slf4j,org.apache.mina.core.file,
org.apache.mina.core.session,org.apache.mina.proxy.handlers,org.apach
e.mina.proxy.handlers.socks,org.apache.mina.core.filterchain,org.apac
he.mina.core.service,org.apache.mina.proxy.event,org.apache.mina.tran
sport.socket";version="2.0.2",org.apache.mina.filter.ssl;uses:="org.a
pache.mina.core.future,org.apache.mina.core.buffer,org.slf4j,org.apac
he.mina.core.write,org.apache.mina.core.session,org.apache.mina.core.
filterchain,org.apache.mina.core.service,javax.net.ssl";version="2.0.
2",org.apache.mina.core.session;uses:="org.apache.mina.core.future,or
g.apache.mina.core.buffer,org.apache.mina.core.write,org.apache.mina.
core.file,org.apache.mina.core.filterchain,org.apache.mina.core.servi
ce,org.apache.mina.util";version="2.0.2",org.apache.mina.core.file;ve
rsion="2.0.2",org.apache.mina.filter.codec.statemachine;uses:="org.ap
ache.mina.core.session,org.apache.mina.core.buffer,org.apache.mina.co
re.filterchain,org.slf4j,org.apache.mina.filter.codec";version="2.0.2
",org.apache.mina.filter.reqres;uses:="org.apache.mina.filter.util,or
g.apache.mina.core.session,org.apache.mina.core.filterchain,org.slf4j
,org.apache.mina.core.write";version="2.0.2",org.apache.mina.proxy.ha
ndlers.socks;uses:="org.apache.mina.core.future,org.apache.mina.core.
buffer,org.apache.mina.proxy.session,org.ietf.jgss,org.slf4j,org.apac
he.mina.proxy,org.apache.mina.core.session,org.apache.mina.proxy.hand
lers,org.apache.mina.core.filterchain,org.apache.mina.proxy.utils";ve
rsion="2.0.2",org.apache.mina.proxy.event;uses:="org.apache.mina.core
.session,org.apache.mina.proxy.handlers,org.apache.mina.proxy.handler
s.socks,org.apache.mina.core.filterchain,org.apache.mina.proxy.sessio
n,org.slf4j,org.apache.mina.proxy";version="2.0.2",org.apache.mina.ut
il;uses:="org.slf4j";version="2.0.2",org.apache.mina.proxy.utils;uses
:="javax.security.sasl,org.apache.mina.core.buffer";version="2.0.2",o
rg.apache.mina.filter.codec.textline;uses:="org.apache.mina.core.sess
ion,org.apache.mina.core.buffer,org.apache.mina.filter.codec";version
="2.0.2",org.apache.mina.filter.logging;uses:="org.apache.mina.filter
.util,org.apache.mina.core.session,org.apache.mina.core.filterchain,o
rg.apache.mina.core.service,org.apache.mina.core.write,org.slf4j";ver
sion="2.0.2",org.apache.mina.transport.socket;uses:="org.apache.mina.
core.session,org.apache.mina.core.service";version="2.0.2"
Built-By: elecharny
Tool: Bnd-0.0.255
Bundle-Name: Apache MINA Core
Created-By: Apache Maven Bundle Plugin
Bundle-Vendor: Apache MINA Project
Build-Jdk: 1.6.0_22
Bundle-Version: 2.0.2
Bnd-LastModified: 1292004266446
Bundle-ManifestVersion: 2
Bundle-License: http://www.apache.org/licenses/LICENSE-2.0
Bundle-Description: Apache MINA is a network application framework whi
ch helps users develop high performance and highly scalable network a
pplications easily. It provides an abstract event-driven asynchronou
s API over various transports such as TCP/IP and UDP/IP via Java NIO.
Bundle-DocURL: http://mina.apache.org/
Bundle-SymbolicName: org.apache.mina.core
Import-Package: javax.crypto,javax.crypto.spec,javax.net.ssl,javax.sec
urity.sasl,org.apache.mina.core;version="2.0.2",org.apache.mina.core.
buffer;version="2.0.2",org.apache.mina.core.file;version="2.0.2",org.
apache.mina.core.filterchain;version="2.0.2",org.apache.mina.core.fut
ure;version="2.0.2",org.apache.mina.core.polling;version="2.0.2",org.
apache.mina.core.service;version="2.0.2",org.apache.mina.core.session
;version="2.0.2",org.apache.mina.core.write;version="2.0.2",org.apach
e.mina.filter.buffer;version="2.0.2",org.apache.mina.filter.codec;ver
sion="2.0.2",org.apache.mina.filter.codec.demux;version="2.0.2",org.a
pache.mina.filter.codec.prefixedstring;version="2.0.2",org.apache.min
a.filter.codec.serialization;version="2.0.2",org.apache.mina.filter.c
odec.statemachine;version="2.0.2",org.apache.mina.filter.codec.textli
ne;version="2.0.2",org.apache.mina.filter.errorgenerating;version="2.
0.2",org.apache.mina.filter.executor;version="2.0.2",org.apache.mina.
filter.firewall;version="2.0.2",org.apache.mina.filter.keepalive;vers
ion="2.0.2",org.apache.mina.filter.logging;version="2.0.2",org.apache
.mina.filter.reqres;version="2.0.2",org.apache.mina.filter.ssl;versio
n="2.0.2",org.apache.mina.filter.statistic;version="2.0.2",org.apache
.mina.filter.stream;version="2.0.2",org.apache.mina.filter.util;versi
on="2.0.2",org.apache.mina.handler.chain;version="2.0.2",org.apache.m
ina.handler.demux;version="2.0.2",org.apache.mina.handler.multiton;ve
rsion="2.0.2",org.apache.mina.handler.stream;version="2.0.2",org.apac
he.mina.proxy;version="2.0.2",org.apache.mina.proxy.event;version="2.
0.2",org.apache.mina.proxy.filter;version="2.0.2",org.apache.mina.pro
xy.handlers;version="2.0.2",org.apache.mina.proxy.handlers.http;versi
on="2.0.2",org.apache.mina.proxy.handlers.http.basic;version="2.0.2",
org.apache.mina.proxy.handlers.http.digest;version="2.0.2",org.apache
.mina.proxy.handlers.http.ntlm;version="2.0.2",org.apache.mina.proxy.
handlers.socks;version="2.0.2",org.apache.mina.proxy.session;version=
"2.0.2",org.apache.mina.proxy.utils;version="2.0.2",org.apache.mina.t
ransport.socket;version="2.0.2",org.apache.mina.transport.socket.nio;
version="2.0.2",org.apache.mina.transport.vmpipe;version="2.0.2",org.
apache.mina.util;version="2.0.2",org.apache.mina.util.byteaccess;vers
ion="2.0.2",org.ietf.jgss,org.slf4j;version="1.5"
Manifest for ru.focusmedia.odp.poim.server:
Export-Package: ru.focusmedia.pshd.server;uses:="ru.focusmedia.odp.psh
d.domain.model,ru.focusmedia.odp.pshd.integration",ru.focusmedia.pshd
.server.poim;uses:="javax.xml.parsers,javax.xml.xpath,org.xml.sax,ru.
focusmedia.pshd.server,ru.focusmedia.pshd.server.poim.db,ru.focusmedi
a.pshd.server.poim.db.entity,ru.focusmedia.pshd.server.poim.protocol.
impl.commands",ru.focusmedia.pshd.server.poim.cmdexec;uses:="ru.focus
media.pshd.server,ru.focusmedia.pshd.server.poim.protocol.impl.schema
",ru.focusmedia.pshd.server.poim.db;uses:="javax.measure,javax.measur
e.unit,org.core,ru.focusmedia.odp.pshd.domain.model,ru.focusmedia.odp
.pshd.integration,ru.focusmedia.pshd.server,ru.focusmedia.pshd.server
.poim,ru.focusmedia.pshd.server.poim.db.entity,ru.focusmedia.pshd.ser
ver.poim.protocol.impl.commands,ru.focusmedia.pshd.server.poim.protoc
ol.impl.schema",ru.focusmedia.pshd.server.poim.db.entity,ru.focusmedi
a.pshd.server.poim.integration;uses:="javax.measure,javax.measure.uni
t,org.core,org.utils.statuscodes,ru.focusmedia.odp.pshd.domain.model,
ru.focusmedia.odp.pshd.integration,ru.focusmedia.pshd.server,ru.focus
media.pshd.server.poim.db.entity",ru.focusmedia.pshd.server.poim.prot
ocol;uses:="javax.measure,javax.measure.unit,org.core,org.utils.statu
scodes,ru.focusmedia.jump,ru.focusmedia.jump.protocol,ru.focusmedia.o
dp.pshd.domain.model,ru.focusmedia.odp.pshd.ssd.domain,ru.focusmedia.
pshd.server.poim,ru.focusmedia.pshd.server.poim.integration,ru.focusm
edia.pshd.server.poim.protocol.impl.commands,ru.focusmedia.pshd.serve
r.poim.protocol.impl.commands.requests",ru.focusmedia.pshd.server.poi
m.protocol.impl;uses:="ru.focusmedia.pshd.server.poim.protocol.impl.s
chemaslist",ru.focusmedia.pshd.server.poim.protocol.impl.commands;use
s:="ru.focusmedia.jump,ru.focusmedia.jump.annotation",ru.focusmedia.p
shd.server.poim.protocol.impl.commands.requests;uses:="ru.focusmedia.
jump.annotation",ru.focusmedia.pshd.server.poim.protocol.impl.command
s.responses;uses:="ru.focusmedia.jump.annotation,ru.focusmedia.pshd.s
erver.poim.protocol.impl.commands",ru.focusmedia.pshd.server.poim.pro
tocol.impl.schema;uses:="javax.xml.bind,javax.xml.bind.annotation",ru
.focusmedia.pshd.server.poim.protocol.impl.schemaslist;uses:="javax.x
ml.bind.annotation",ru.focusmedia.pshd.server.poim.protocol.tests;use
s:="org.junit",ru.focusmedia.pshd.server.poim.schema_stubs;uses:="org
.slf4j,ru.focusmedia.odp.pshd.poim.bridge,ru.focusmedia.pshd.server,r
u.focusmedia.pshd.server.poim.db",ru.focusmedia.pshd.server.poim.sche
ma_stubs.tests.manual;uses:="org.junit,ru.focusmedia.odp.pshd.domain.
model",ru.focusmedia.pshd.server.poim.tests.manual
Tool: Bundlor 1.1.0.BUILD-20101220120024
Import-Package: javax.measure,
javax.measure.unit,
javax.xml.bind,
javax.xml.bind.annotation,
javax.xml.namespace,
javax.xml.parsers,
javax.xml.xpath,
org.core;version="[3.1.0,3.1.0]",
org.slf4j,
org.w3c.dom,
org.xml.sax,
ru.focusmedia.odp.poim.protocol,
ru.focusmedia.odp.poim.protocol.requests,
ru.focusmedia.odp.poim.protocol.responses,
ru.focusmedia.odp.pshd.entity,
ru.focusmedia.odp.pshd.integration.fb,
ru.focusmedia.odp.pshd.integration.roles,
ru.focusmedia.odp.pshd.integration.users,
ru.focusmedia.odp.pshd.repository.spi,
Import-Bundle: ru.focusmedia.jsr-275;version="[1.0.0,1.0.0]",
org.apache.mina.core;version="[2.0.2,2.0.2]"
Bundle-SymbolicName: ru.focusmedia.odp.poim.server
Bundle-Version: 3.2.0
Bundle-Name: ru.focusmedia.odp.poim.server
Bundle-Vendor: focusmedia
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Import-Library: org.springframework.spring;version="[3.0.0.RELEASE,3.0.5.RELEASE]"
As I said, what seems really weird is point 3: VTS can find the Mina bundle in the repository,
and use it to satisfy the constraint.
Current Time: Wed Apr 24 16:57:54 GMT 2024
Powered by FUDForum. Page generated in 0.03105 seconds
