Search results window always on top [message #723126] |
Wed, 07 September 2011 13:38  |
Is it possible to get the search results window to behave as any other window ?
After searching, the window comes up and stays on top. As long as Eclipse is the active application, the search results window is always on top. I can't get it to go behind the editor window.
I am using Version: Helios Service Release 2
Build id: 20110218-0911
Re: (no subject) [message #832874 is a reply to message #724464] |
Fri, 30 March 2012 13:55  |
I have the same issue as the original poster, but with ANY view. For some reason, someone on the Eclipse team thought this "feature" would be a great idea, but it's really not, as it deviates from normal, expected window behavior on every known platform. Forcing the user to resize the window so there's no overlap with the parent feels like a Windows 1.0-era kluge.
Let me try to explain it using workflow familiar to all of us: sending an email using virtually any GUI email client that opens up a modeless window for a "new email". For this sequence, I'll use Microsoft Outlook:
1) Open Outlook.
2) Create a "new email". This creates a new, modeless window for the new email, which appears in the foreground, covering part of the main Outlook window.
3) Work on "new email" for a while, before realizing other information is needed from a different email. Click on visible part of main Outlook window to get that information. This brings the main Outlook window to the foreground, covering part of the new email window.
4) After retrieving information from main Outlook window, click on the visible part of "new email" window. This brings the "new window" to the foreground, covering part of the main Outlook window again.
Now, I understand that this issue was reported in January 2006 and subsequently marked as "Won't Fix" 1-1/2 years later (Bug 123400), so I don't have any hope of getting a resolution from the team, but if anyone out there can tell me exactly HOW the always-on-top behavior is being implemented, maybe I can code a workaround to make my own views that respect standard modeless child window behavior.
FUDForum. Page generated in 0.06348 seconds
