Home » Language IDEs » ServerTools (WTP) » "Map" containing present elements?(Does it exist?)
"Map" containing present elements? [message #723057] Wed, 07 September 2011 14:17 Go to next message
MarcoGT  is currently offline MarcoGT Friend
Member
inside AbstractModelQueryCompletionProposalComputer class the method addAttributeValueProposal has a map containing all the inserted attributes.
At the moment I am working on addEntityProposals(ContentAssist, ITextRegion, CompletionProposalInvocationContext)
Let's suppose I have something similar:
<family>
 <mother>Lisa</mother>
 <father>Bob</father>
Now I call content assist and for example I get proposal for <daughter>...ok...is there a way to know that <mother> and <father> have been already inserted?
Marco
Re: "Map" containing present elements? [message #723534 is a reply to message #723057] Thu, 08 September 2011 18:36 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
No, you'll have to get the list of child nodes from the parent. The ordering can matter, so a Map will not give you enough information.
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: "Map" containing present elements? [message #724442 is a reply to message #723057] Mon, 12 September 2011 11:29 Go to previous messageGo to next message
Member
Ok, thank you.
<family>
 <father></father>
</family>
Let's suppose cursor is between "father" tag and content assist is called.
At the moment I am working on addEntityProposals method.
I have access to ContentAssistRequest
ContentAssistRequest.getParent() gives me back "father"
I should use ContentAssistRequest.getParent().getParent() and I get "family", then using getChildNodes() I get a NodeList containing all the children nodes (mother and father in my case)...but how do I get their content?
If I print out every child node I get:
#text
mother
#text
father
Why?
Re: "Map" containing present elements? [message #724457 is a reply to message #724442] Mon, 12 September 2011 12:04 Go to previous messageGo to next message
If the cursor is between the father start and end tags, father is supposed to be the parent of what you insert.
Getting their content requires using the DOM API from org.w3c.dom.Node and its subinterfaces; #toString() has no such requirement.
Those are Text nodes in the DOM representing white space not contained under the "mother" and "father" Elements. There should be one trailing "father" as well.
Nitin Dahyabhai
Re: "Map" containing present elements? [message #724797 is a reply to message #724457] Tue, 13 September 2011 07:50 Go to previous messageGo to next message
Member
Ok, I got, thanks.
Another question:
if I have
<Book title="aaa" author="bbb" price="12" year="2011" />
I can use an XPath expression to see if some conditions are verified, for example:
local-name(.) = 'Book' and @title
If the result of XPath expression execution is true...do something, otherwise do something else.
In this case I built an expression directly on a Node, and that's ok.
In the case of NodeList, how can I do the same task?
I would like to see if NodeList has some nodes, for example, but using an XPath expression.
Re: "Map" containing present elements? [message #724804 is a reply to message #724457] Tue, 13 September 2011 08:31 Go to previous message
Member
Nitin Dahyabhai wrote on Mon, 12 September 2011 08:04
Yes, ok, but I can not understand why in my NodeList I also get, as children elements, #text elements...
I mean...I get why I have in the NodeList...but is it possible to have only tag name inside NodeList?
For example only "father" and "mother"...nothing else, I do not want #text or #comment
[Updated on: Tue, 13 September 2011 08:57]
Report message to a moderator
Previous Topic:Modern Source Editor Tutorial
Next Topic:Eclipse
Current Time: Mon Mar 08 10:11:22 GMT 2021
Powered by FUDForum. Page generated in 0.01362 seconds
