Re: OSGI nor found BIRT3.7 JBOSS [message #723539 is a reply to message #722850] |
Thu, 08 September 2011 18:37 |
Can you open a bugzilla entry for this?
JAson
On 9/6/2011 7:33 PM, Sarah wrote:
> I was trying to update the BIRT through the eclipse update manager and I
> got this error
> Your original request has been modified.
> "BIRT Chart Framework" is already installed, so an update will be
> performed instead.
> "Eclipse BIRT Chart Context Sensitive Help Documentation" is already
> installed, so an update will be performed instead.
> Cannot complete the install because of a conflicting dependency.
> Software being installed: BIRT Chart Framework
> 3.7.0.v20110603-7r9e1FQCnvKN67BslXE5
> (org.eclipse.birt.chart.feature.group 3.7.0.v20110603-7r9e1FQCnvKN67BslXE5)
> Software currently installed: BIRT Framework
> 3.7.0.v20110329-B7F907AGS6mD_gcl4-07XxVEeM9k
> (org.eclipse.birt.feature.group
> 3.7.0.v20110329-B7F907AGS6mD_gcl4-07XxVEeM9k)
> Only one of the following can be installed at once: BIRT Core Package
> 2.6.0.v20100526 (org.eclipse.birt.core 2.6.0.v20100526)
> BIRT Core Package 2.6.2.r262_v20110209 (org.eclipse.birt.core
> 2.6.2.r262_v20110209)
> BIRT Core Package 3.7.0.v20110815-0857 (org.eclipse.birt.core
> 3.7.0.v20110815-0857)
> BIRT Core Package 3.7.0.v20110519 (org.eclipse.birt.core 3.7.0.v20110519)
> BIRT Core Package 3.7.0.v20110608 (org.eclipse.birt.core 3.7.0.v20110608)
> BIRT Core Package 2.6.1.v20100819 (org.eclipse.birt.core 2.6.1.v20100819)
> Cannot satisfy dependency:
> From: BIRT Chart Framework 3.7.0.v20110603-7r9e1FQCnvKN67BslXE5
> To: org.eclipse.birt.core [3.7.0.v20110608]
> From: BIRT Framework 3.7.0.v20110329-B7F907AGS6mD_gcl4-07XxVEeM9k
> To: org.eclipse.birt.core [3.7.0.v20110519]
> Sp I want back through the update manager and I saw that I have some
> earlier versions installed.
> I clicked on already installed and I did not find any birt 2.6 jars
> installed.
> How do I remove the old versions?
Re: OSGI nor found BIRT3.7 JBOSS [message #724558 is a reply to message #723616] |
Mon, 12 September 2011 14:20 |
Sarah,
What is contained in the deployed apps WEB-INF/lib?
Does it contain all the jars from the birt runtime download's
reportengine/lib directory?
Jason
On 9/8/2011 8:45 PM, Sarah wrote:
> Ok so I read some where that Birt 3.7 can only be used with eclipse 3.7
> (indigo)
> So I downloaded the new version and added the seam facets to my web
> project. I am using apache tomcat 7.
> When i run the server i get this error.
> 09-Sep-2011 02:38:17 org.apache.catalina.core.StandardContext listenerStart
> SEVERE: Error configuring application listener of class
> org.eclipse.birt.report.listener.ViewerHttpSessionListener
> java.lang.ClassNotFoundException:
> at
> org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1676)
> at
> org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1521)
> at
> org.apache.catalina.core.DefaultInstanceManager.loadClass(DefaultInstanceManager.java:415)
> at
> org.apache.catalina.core.DefaultInstanceManager.loadClassMaybePrivileged(DefaultInstanceManager.java:397)
> at
> org.apache.catalina.core.DefaultInstanceManager.newInstance(DefaultInstanceManager.java:118)
> at
> org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4638)
> at
> org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5204)
> at
> org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5199)
> at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
> at java.util.concurrent.FutureTask.run(FutureTask.java:138)
> at
> java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
> at
> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
> at java.lang.Thread.run(Thread.java:662)
> org.eclipse.birt.report.listener.ViewerServletContextListener
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> SEVERE: Skipped installing application listeners due to previous error(s)
> 09-Sep-2011 02:38:17 org.apache.catalina.core.StandardContext startInternal
> SEVERE: Error listenerStart
FUDForum. Page generated in 0.02493 seconds
