Home » Archived » M2M (model-to-model transformation) » [atl] thisModule.resolveTemp() for a called rule
[atl] thisModule.resolveTemp() for a called rule [message #77275] Wed, 19 March 2008 19:42 Go to next message
wong is currently offline wongFriend
Member
How can I use the thisModule.resolveTemp() for a called rule
Thank you,
Wong.
Re: [atl] thisModule.resolveTemp() for a called rule [message #77292 is a reply to message #77275] Wed, 19 March 2008 20:40 Go to previous message
William Piers is currently offline William PiersFriend
--------------090305030705060805070104
The resolveTemp method is linked to the traceability system, which is
only managed when using matched rules. So you can't use it into called
rules.
You may redefine your transformation using matched rules, or use some
helper attributes to store then retrieve a previously created element.
William
wong a
Previous Topic:[QVTO] One more question...
Next Topic:Get ATL for Eclipse 3.3.1.1?
Current Time: Mon Jun 24 13:13:55 GMT 2019
Powered by FUDForum. Page generated in 0.01638 seconds
