Home » Eclipse Projects » Eclipse 4 » How to retrieve/inject a list of services
How to retrieve/inject a list of services [message #722419] Mon, 05 September 2011 18:16 Go to next message
Hannes Niederhausen is currently offline Hannes NiederhausenFriend
I use services to implement extensions to my domain model. All extensions implement the same interface. The question is, how can I retrieve all the implementations?
I tried the @Inject annotation with a list/array of my interface but it didn't work.
Then I tried the get method of the IEclipseContext but also got only one instance.
Funny thing: if I inject a single instance via annotation and retrieve another instance using the context I get two different implementations.
Any hints or is just not possible right now?
Best regards and thanks in advance
Hannes
[Updated on: Mon, 05 September 2011 18:26]
Report message to a moderator
Re: Hot to retrieve/inject a list of services [message #722443 is a reply to message #722419] Mon, 05 September 2011 19:09 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
The only possibility is to create a Component in your plugin which you
configure using DS to receive all services and let you inject exactly
this one component.
This also solves the dynamic aspect of OSGi-Services currently not solve
by e4 DI by default.
Tom
Am 05.09.11 20:16, schrieb Hannes Niederhausen:
> didn't work.
> instance.
> Hannes
Re: Hot to retrieve/inject a list of services [message #722444 is a reply to message #722419] Mon, 05 September 2011 19:09 Go to previous messageGo to next message
this one component.
Tom
> didn't work.
> instance.
> Hannes
Re: Hot to retrieve/inject a list of services [message #722550 is a reply to message #722444] Tue, 06 September 2011 07:09 Go to previous message
Hi Tom,
thanks for the hint.
I was afraid it isn't possible at all in e4.
I still getting used to the component declarations, learning something new each day. Smile
Best regards
Hannes
Previous Topic:Ant Script for eclipse e4 application
Next Topic:Disable drag and drop to detached window?
Current Time: Wed Oct 21 16:27:57 GMT 2020
Powered by FUDForum. Page generated in 0.02067 seconds
