Home » Archived » Sapphire » DiagramEditor - Manage nodes and edges separatly
DiagramEditor - Manage nodes and edges separatly [message #722153] Sun, 04 September 2011 19:09 Go to next message
Nepomuk Seiler is currently offline Nepomuk SeilerFriend
Member
Currently I'm trying to extend my editor with a diagram page. My model is a graph consisting of nodes and edges. Both are managed in a ListProperty. I implemented everything like the architecture example, besides the root entity. The root entity manage both nodes and edges.
IDataProcessingUnit.class snippet (root entity, graph)
	/* === Nodes === */
	@Type(base = INode.class)
	@XmlListBinding(path = "nodes", mappings = { @XmlListBinding.Mapping(element = "node", type = INode.class) })
	@Label(standard = "Nodes")
	ListProperty PROP_NODES = new ListProperty(TYPE, "nodes");
	ModelElementList<INode> getNodes();
	/* === Edges === */
	@Type(base = IEdge.class)
	@XmlListBinding(path = "edges", mappings = { @XmlListBinding.Mapping(element = "edge", type = IEdge.class) })
	@Label(standard = "Edges")
	ListProperty PROP_EDGES = new ListProperty(TYPE, "edges");
	ModelElementList<IEdge> getEdges();
INode.class snippet
/* === Node ID === */
	@XmlBinding(path = "@id")
	@Label(standard = "id")
	@Required
	ValueProperty PROP_ID = new ValueProperty(TYPE, "id");
	Value<String> getId();
	void setId(String value);
	/* === Edges === */
        //I try to reference to the root path here!
	@XmlListBinding(path = "/edges", mappings = { @XmlListBinding.Mapping(element = "edge", type = IEdge.class) })
IEdge.class snippet
/* === Edge ID === */
	@Reference( target = INode.class )
	@Service( impl = NodeReferenceService.class )
	@XmlBinding(path = "@edgeId")
	@Label(standard = "EdgeId")
	@Required
	ValueProperty PROP_EDGE_ID = new ValueProperty(TYPE, "edgeId");
	Value<String> getEdgeId();
	void setEdgeId(String value);
	/* === Source ID === */
	@XmlBinding(path = "@sourceId")
	@Label(standard = "SourceId")
	@Required
        @PossibleValues( property = "/nodes/id" )
	ValueProperty PROP_SOURCE_ID = new ValueProperty(TYPE, "sourceId");
	Value<String> getSourceId();
	void setSourceID(String value);
	/* === Target ID === */
	@XmlBinding(path = "@targetId")
	@Label(standard = "TargetId")
	@Required
	ValueProperty PROP_TARGET_ID = new ValueProperty(TYPE, "targetId");
	Value<String> getTargetId();
	void setTargetID(String value);
If I create edges via the MasterDetailPage my xml-model looks right:
<DataProcessingUnit name="myFirstDPU">
    <nodes>
        <node id="Node1" />
        <node id="Node2" />
    </nodes>
    <edges>
        <edge edgeId="e1" sourceId="Node1" targetId="Node2"/>
    </edges>
</DataProcessingUnit>
However if I use the Graphiti editor, it looks like:
    <nodes>
        <node factoryId="fac1" id="Node1" type="processor" >
            <edges>
                <edge edgeId="Node2"></edge>
            </edges>
        </node>
        <node factoryId="fac2" id="Node2" type="loader"/>
    </nodes>
He only adds the edge in the Graphiti-Editor if I reference edgeIdas Endpoint2. If not, nothing is added.
Is it possible to reference a higher path in the xml-tree from a lower entity?
thx,
Muki
Re: DiagramEditor - Manage nodes and edges separatly [message #722159 is a reply to message #722153] Sun, 04 September 2011 19:58 Go to previous message
Konstantin Komissarchik is currently offline Konstantin KomissarchikFriend
You have a list of edges defined twice. Once at the root of the model and again inside the node element. Those are two styles of edge representation. You typically want one or the other. If you look at the map sample, you will see how to implement either option... IMap.Routes (top-level) and IDestination.RailwayRoutes (part of node).
- Konstantin
Previous Topic:Dynamic combobox content generated out of the model
Next Topic:Re-scheduling Sapphire 0.3.1 release
Current Time: Thu Apr 25 13:33:29 GMT 2024
Powered by FUDForum. Page generated in 0.02961 seconds
