Home » Newcomers » Newcomers » Problem starting Eclipse
Re: Problem starting Eclipse [message #721952 is a reply to message #721946] |
Sat, 03 September 2011 18:53 |
On 03-Sep-11 12:47, Lukesteral wrote:
> When i try to start it i get this:
> Java was started but returned exit code=1
> Thats the first part of what came up i just dont feel like copying the
> whole thing down word for word. so does anyone know what to do?
Okay, if I have to fly blind here...
Make certain your Java and your Eclipse share the same bittedness.
Then, see http://wiki.eclipse.org/Eclipse.ini.
Re: Problem starting Eclipse [message #721970 is a reply to message #721959] |
Sat, 03 September 2011 20:38 |
On 03-Sep-11 13:43, Lukesteral wrote:
> ok fine heres the rest of the code that popped up:
> C:\Windows\system32\javaw.exe
> -Dosgi.requiredJavaVersion=1.5
> -Xms40m
> -Xmx512m
> -XX:MaxPermSize=256m
> -jar C:\Users\(private)\Documents\my stuff\Eclipse
> stuff\eclipse\\plugins\org.eclipse.equinox.launcher_1.2.0.v20110502.jar
> -os win32
> -ws win32
> -archx86_64
> -showsplash
> -launcher C:\Users\(private)\Documents\my stuff\Eclipse
> stuff\eclipse\eclipse.exe
> -name Eclipse
> --launcher.library C:\Users\(private)\Documents\my stuff\Eclipse
> Stuff\eclipse\\plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.
> 100.v20110502\eclipse_1406.dll
> -startup C:\Users\(private)\Documents\my stuff\Eclipse
> stuff\eclipse\\plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
> --launcher.overrideVmargs
> -exitdata 22c0_60
> -product org.eclipse.epp.package..jee.product
> -vm C:\Windows\system32\javaw.exe
> -vmargs
> -Xms40m
> -Xmx512m
> Thats the end of the code.
I would install a proper Java. If you're going to use Eclipse to develop
Java applications, you'll need a JDK anyway. Whatever the case, install
a JRE or JDK from Sun (java.sun.com, then hover over Downloads button
and choose Java for Developers). You don't have to install this on your
Windows host; you can just drop it privately somewhere, e.g.:
C:\Users\(private)\mystuff\jdk1.6.0_27. Then, edit your eclipse.ini,
specify it with the -vm option (see the Eclipsepedia link I sent) and
try again.
Re: Problem starting Eclipse [message #721985 is a reply to message #721972] |
Sat, 03 September 2011 22:13 |
On 03-Sep-11 15:04, Lukesteral wrote:
> Well i already have JDK installed hopefully correctly.. but that link
> you sent didnt have any text on the page
According to what you posted, I can see that you a) are not necessarily
using a Sun JRE and b) that's it's not a JDK. You can run Eclipse on a
mere JRE if you like, but you can't really do Java development. The JRE
you are using is unclear. The reason I know this is:
I would expect something either like the path I gave you or something like:
-vm
C:\Program Files\Java\jre6\bin\javaw.exe
if you had specified a JRE installed in the usual place the installer
would drop it.
In either case, you've not caught the spirit of
If you want a fairly detailed and perhap tedious summary of this, the
following link should get you running or bore you to tears:
http://www.javahotchocolate.com/tutorials/eclipse-summary.html
Re: Problem starting Eclipse [message #721995 is a reply to message #721988] |
Sat, 03 September 2011 23:12 |
On 03-Sep-11 16:51, Lukesteral wrote:
> Well i only understand about half of what your talking about (you
> obviously know way more about computers then i do) but this is what i
> have: C:\Program Files\Java\jdk1.7.0\bin\javaw.
> and can you explain to me what im supposed to do with that link you eep
> mentioning? whenever i click on it it takes me to a page that says
> theres no text on this page.
Please reply with the URL that does not work. Both URLs I sent you work.
I don't usually type URLs, but copy and paste them from my browser
address line; that way, I know I'm not jerking you around.
Re: Problem starting Eclipse [message #722005 is a reply to message #721996] |
Sun, 04 September 2011 02:00 |
On 2011.09.03 18:01, Lukesteral wrote:
> i have to post 5 times before i can upload URLs'. i think this my 4th or
> something. here hold on.
There are many tricks to posting it leaving off http://, adding spaces, etc.
Re: Problem starting Eclipse [message #722006 is a reply to message #721976] |
Sun, 04 September 2011 02:01 |
On 2011.09.03 15:26, Lukesteral wrote:
> Also if it helps to know that i installed JDK and eclipse with a
> tutorial on youtube. it wont let me post post the tutorials until i post
> 5 messages though. so im not sure if this helps anything. but perhaps i
> did a step wrong?
No, this is not important.
Re: Problem starting Eclipse [message #722007 is a reply to message #721997] |
Sun, 04 September 2011 02:03 |
On 2011.09.03 18:02, Lukesteral wrote:
> http://wiki.eclipse.org/Eclipse.ini. this is the first link.
If you can't get to that link, then I can't imagine what you can do. How
could you download Eclipse in the first place? Etc. Maybe there's
something wrong with your connection that's only temporary? Keep trying
until you get that link. * * Everybody * * uses that link when they
start setting up Eclipse.
Re: Problem starting Eclipse [message #722024 is a reply to message #722010] |
Sun, 04 September 2011 04:11 |
On 2011.09.03 20:16, Lukesteral wrote:
> oh well ive been useing this tutorial:
> http://www.youtube.com/watch?v=CE8UIbb_4iM&feature=relmfu
> But yeah ill try later. ill figure it out
I looked at this tutorial. Besides being a little old (we're three full
versions past Ganymede now), the explanations are simplistic and he
completely skips over how to install Eclipse. If that weren't enough,
he's not a Java programmer. There are standards in Java he completely
ignores.
I'd like to help, but as you can't seem to see the links I've posted,
it's hard to do so.
Should you be able to reach
http://www.javahotchocolate.com/tutorials/eclipse-summary.html, use it
to learn how to download and set up Eclipse. Once you get Eclipse
installed and working, the workbench itself has a link you can click to
tutorials which are very good.
However, ...
While I have tried it out, but elected to stay with Eclipse which the
vast majority of developers who write commercial software use for Java
development, I would suggest you look at NetBeans; you might find it
easier. It's a much more beginners' environment, I think. (I hope I
don't take too much flack from the rest of the forum for suggesting this.)
Russ
Re: Problem starting Eclipse [message #722026 is a reply to message #722010] |
ignores.
it's hard to do so.
However, ...
Russ
Re: Problem starting Eclipse [message #722029 is a reply to message #722010] |
ignores.
it's hard to do so.
However, ...
Russ
Re: Problem starting Eclipse [message #722041 is a reply to message #722010] |
ignores.
it's hard to do so.
However, ...
Russ
Re: Problem starting Eclipse [message #722043 is a reply to message #722010] |
ignores.
it's hard to do so.
However, ...
Russ
Re: Problem starting Eclipse [message #722049 is a reply to message #722010] |
ignores.
it's hard to do so.
However, ...
Russ
Current Time: Fri Mar 29 10:27:37 GMT 2024
Powered by FUDForum. Page generated in 0.04815 seconds
