C++ Build problem!!!!!!!!!!!! [message #721916] |
Sat, 03 September 2011 15:31 |
Gabriel Ameen Messages: 4 Registered: September 2011 |
Hi friends,
I facing a problem with Eclipse IDE and MinGW, hope you will help me out. This is how I installed eclipse.
1. I installed JRE.
2. I donwloaded the MinGW automatic installer, installed everything except Fortran compiler, under C:\MinGW
3. Then I added C:\MinGW\bin to my system path variable.
4. Then I downloaded Eclipse IDE for C/C++ Developers (includes Incubating components), extracted it under C:\eclipse
Now when I create a c project, with .c source file, the build is successfuly done, and I can run the executable created. But when I try to do the same thing with a c++ project, I face the following errors.
Description Resource Path Location
Symbol 'cout' could not be resolved First.cpp /First/src line 13 Semantic Error
Symbol 'endl' could not be resolved First.cpp /First/src line 13 Semantic Error
Symbol 'std' could not be resolved First.cpp /First/src line 10 Semantic Error
Error launching external scanner info generator (g++ -E -P -v -dD C:/Users/dawood/workspace/.metadata/.plugins/org.eclipse.cdt.make.core/specs.cpp) First [Discovery Options] page in project properties C/C++ Problem
Program 'g++' is not found in $PATH First [Discovery Options] page in project properties C/C++ Problem
I searched for the iostream under C:\MinGW but couldn't find, why is iostream not included with MinGW???
I am running Windows 7 x64 Ultimate SP1, please help me with this! Looking forward to your replies!
Thanks in advance!
FUDForum. Page generated in 0.03766 seconds
