Remove whitespaces from generation [message #76988] |
Wed, 28 March 2007 15:12 |
Originally posted by: matroska.libero.it
i am using emft jet generation to create java code however i cannot find
how to remove whitespaces (these whitespaces are that from used tags).
Thanks in advance
Tobia Loschiavo
Re: Remove whitespaces from generation [message #76997 is a reply to message #76988] |
Wed, 28 March 2007 21:05 |
John,
Please use the M2T newsgroup for JET2 questions. I've added it to the
"to" list so Paul should see your question. He might need more detail
though. Often the goodness of the answer is proportional to the amount
of information provided in the question...
John Slave wrote:
> find how to remove whitespaces (these whitespaces are that from used
> tags).
> Thanks in advance
> Tobia Loschiavo
Re: Remove whitespaces from generation [message #77471 is a reply to message #77290] |
Thu, 29 March 2007 15:16 |
Originally posted by: evaandoli.dodo.com.au
I get the same thing and yes I have comments all over the place trying to
make the text understandable.
Are you saying to remove these ghost blank lines you have to remove all
comments ? Seems a shame.
"Paul Elder" <pelder@ca.ibm.com> wrote in message
news:eugbj7$qk8$1@build.eclipse.org...
> John:
> JET2 removes write space when a tag (or other language element) is alone
> on a line.
> Rule of thumb: If you don't want write space associated with a tag, put it
> on its own line.
> So:
> <c:iterate select... >
> Some code
> </c:iterate>
> Should produce
> Some code
> Some code
> Some code
> But, if you put a comment on the line
> <c:iterate select... > <%-- a comment --%>
> Some code
> </c:iterate>
> You'd get:
> Some code
> Some code
> Some code
> "Ed Merks" <merks@ca.ibm.com> wrote in message
> news:euelal$d3e$1@build.eclipse.org...
>> John,
>> John Slave wrote:
>>> Hi,
>>> Thanks in advance
>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #77851 is a reply to message #76997] |
Sat, 31 March 2007 15:31 |
Something else I notice is a blank line appears in generation if you put a
<c:log> </c:log> line in.
> John,
> though. Often the goodness of the answer is proportional to the amount of
> John Slave wrote:
>> Hi,
>> Thanks in advance
>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #77898 is a reply to message #77882] |
Mon, 02 April 2007 12:21 |
I have all comments on a separate line so it must be something else. I'll
look more into it and post something with more detail if I can narrow it
down.
The <c:log>Log here</c:log>
Seems to add a blank line is what I have found so far.
Cheers for all your time.
Stu
news:euqrei$jfl$1@build.eclipse.org...
> Stu:
> No, just put them on a separate line.
> I'll have another look at the new line trimming algorthim to see if I can
> make it more friendly with respect to comments. No promises for this
> release, so it still comes down to, put your comments on a separate line.
> <%-- Good: do something --%>
> <c:iterate ... >
> <c:iterate ...> <%-- Bad: will result in a an unexpected new line --%>
> Paul
> "Stu" <evaandoli@dodo.com.au> wrote in message
> news:eugl88$70b$1@build.eclipse.org...
>>> John:
>>> on a line.
>>> it on its own line.
>>> So:
>>> Some code
>>> </c:iterate>
>>> Should produce
>>> Some code
>>> Some code
>>> Some code
>>> Some code
>>> </c:iterate>
>>> You'd get:
>>> Some code
>>> Some code
>>> Some code
>>>> John,
>>>> John Slave wrote:
>>>>> Hi,
>>>>> tags).
>>>>> Thanks in advance
>>>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #78355 is a reply to message #77898] |
Wed, 04 April 2007 12:18 |
Paul Elder Messages: 849 Registered: July 2009 |
Stu:
would add a line, while
<c:log>
Log here
</c:log>
will not.
The whitespace/line stripping would have to get smarter about the intent of
individual tags to successfully do the right thing on:
and, and the same time:
<f:lc>Lower Case here</f:lc>
I'll give it some thought. Here's a bugzilla to track it...
https://bugs.eclipse.org/bugs/show_bug.cgi?id=180927
Paul
news:euqsgl$rhf$1@build.eclipse.org...
>down.
> Stu
>> Stu:
>> <c:iterate ... >
>> Paul
>>>> John:
>>>> alone on a line.
>>>> it on its own line.
>>>> So:
>>>> Some code
>>>> </c:iterate>
>>>> Should produce
>>>> Some code
>>>> Some code
>>>> Some code
>>>> Some code
>>>> </c:iterate>
>>>> You'd get:
>>>> Some code
>>>> Some code
>>>> Some code
>>>>> John,
>>>>> amount of information provided in the question...
>>>>> John Slave wrote:
>>>>>> Hi,
>>>>>> tags).
>>>>>> Thanks in advance
>>>>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #79526 is a reply to message #78355] |
Thu, 12 April 2007 04:47 |
Ok I got around to finding my problem with a blank line appearing when I
think it shouldnt.
Here is the line that caused trouble:-
PreText1
<c:addTextElement select="$conductorType/valueHolder" name="notFoundName"
var="notFound">NotFound</c:addTextElement>
PostText1
Output looks like:
PreText1
PostText1
I tried:-
var="notFound">
NotFound
</c:addTextElement>
but got the same result.
Stuart
news:ev053l$dvg$1@build.eclipse.org...
> Stu:
> <c:log>
> Log here
> </c:log>
> will not.
> of individual tags to successfully do the right thing on:
> Paul
>>down.
>> Stu
>>> Stu:
>>> can make it more friendly with respect to comments. No promises for this
>>> line.
>>> <c:iterate ... >
>>> Paul
>>>>to make the text understandable.
>>>>> John:
>>>>> alone on a line.
>>>>> put it on its own line.
>>>>> So:
>>>>> Some code
>>>>> </c:iterate>
>>>>> Should produce
>>>>> Some code
>>>>> Some code
>>>>> Some code
>>>>> Some code
>>>>> </c:iterate>
>>>>> You'd get:
>>>>> Some code
>>>>> Some code
>>>>> Some code
>>>>>> John,
>>>>>> the "to" list so Paul should see your question. He might need more
>>>>>> detail though. Often the goodness of the answer is proportional to
>>>>>> the amount of information provided in the question...
>>>>>> John Slave wrote:
>>>>>>> Hi,
>>>>>>> tags).
>>>>>>> Thanks in advance
>>>>>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #603923 is a reply to message #76988] |
Ed Merks Messages: 33141 Registered: July 2009 |
John,
John Slave wrote:
> tags).
> Thanks in advance
> Tobia Loschiavo
Ed Merks
Re: Remove whitespaces from generation [message #604333 is a reply to message #77898] |
Stu:
<c:log>
Log here
</c:log>
will not.
Paul
>down.
> Stu
>> Stu:
>> <c:iterate ... >
>> Paul
>>>> John:
>>>> alone on a line.
>>>> it on its own line.
>>>> So:
>>>> Some code
>>>> </c:iterate>
>>>> Should produce
>>>> Some code
>>>> Some code
>>>> Some code
>>>> Some code
>>>> </c:iterate>
>>>> You'd get:
>>>> Some code
>>>> Some code
>>>> Some code
>>>>> John,
>>>>> John Slave wrote:
>>>>>> Hi,
>>>>>> tags).
>>>>>> Thanks in advance
>>>>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #604663 is a reply to message #78355] |
Stu Plu Messages: 44 Registered: July 2009 |
Member |
think it shouldnt.
PreText1
PostText1
Output looks like:
PreText1
PostText1
I tried:-
var="notFound">
NotFound
</c:addTextElement>
Stuart
> Stu:
> <c:log>
> Log here
> </c:log>
> will not.
> Paul
>>down.
>> Stu
>>> Stu:
>>> line.
>>> <c:iterate ... >
>>> Paul
>>>>> John:
>>>>> alone on a line.
>>>>> So:
>>>>> Some code
>>>>> </c:iterate>
>>>>> Should produce
>>>>> Some code
>>>>> Some code
>>>>> Some code
>>>>> Some code
>>>>> </c:iterate>
>>>>> You'd get:
>>>>> Some code
>>>>> Some code
>>>>> Some code
>>>>>> John,
>>>>>> John Slave wrote:
>>>>>>> Hi,
>>>>>>> tags).
>>>>>>> Thanks in advance
>>>>>>> Tobia Loschiavo
FUDForum. Page generated in 0.03817 seconds
