Re: [EMFStore] Problems when sharing project to Server [message #721780 is a reply to message #721704] |
Fri, 02 September 2011 20:18 |
Originally posted by: Jonas Helming
Hi Mauricio,
You say you have followed the step "prepare the model for the emfstore".
I assume you are following the tutorial for a older version of EMFStore.
Inheriting from a base class is not necessary in the newer versions of
EMFStore.
Did you follow this getting started:
http://eclipse.org/emf-store/gettingstarted.php
Please tell me if the new Tutorial solves your problem.
Cheers
Jonas
Am 02.09.2011 18:01, schrieb maureyeslopez:
> Hi, I'm starting with EMFStore and I followed the first 2
> videotutorials: "How to install the EMFStore Framework" and "How to
> prepare your model for the EMFStore".
> I have installed EMFStore SDK 0.8.9.M3 and the server starts ok. I also
> created the library model and prepared the client configuration
> correctly. The Client app starts ok and I can create the project and
> create instances of library and book. My problem is when I try to
> connect share the project to the EMF Server. When I try to login to it I
> get a "Server could not be reached." message and the EMFStore Server
> console shows me:
> !ENTRY org.unicase.metamodel 1 1 2011-09-02 12:46:44.197
> !MESSAGE Initialitation COMPLETE.
> !MESSAGE Server is RUNNING...
> 02/09/2011 12:48:01 PM org.apache.xmlrpc.server.XmlRpcErrorLogger log
> GRAVE: Received fatal alert: certificate_unknown
> javax.net.ssl.SSLHandshakeException: Received fatal alert:
> certificate_unknown
> at com.sun.net.ssl.internal.ssl.Alerts.getSSLException(Unknown Source)
> at com.sun.net.ssl.internal.ssl.SSLSocketImpl.recvAlert(Unknown Source)
> at com.sun.net.ssl.internal.ssl.SSLSocketImpl.readRecord(Unknown Source)
> at
> com.sun.net.ssl.internal.ssl.SSLSocketImpl.performInitialHandshake(Unknown
> Source)
> at com.sun.net.ssl.internal.ssl.SSLSocketImpl.readDataRecord(Unknown
> Source)
> at com.sun.net.ssl.internal.ssl.AppInputStream.read(Unknown Source)
> at java.io.BufferedInputStream.fill(Unknown Source)
> at java.io.BufferedInputStream.read(Unknown Source)
> at org.apache.xmlrpc.webserver.Connection.readLine(Connection.java:241)
> at
> org.apache.xmlrpc.webserver.Connection.getRequestConfig(Connection.java:150)
> at org.apache.xmlrpc.webserver.Connection.run(Connection.java:204)
> at org.apache.xmlrpc.util.ThreadPool$Poolable$1.run(ThreadPool.java:68)
> Can this error be related with the es.properties config file? What
> should I change?
> Thanks
> Mauricio
Re: [EMFStore] Problems when sharing project to Server [message #723061 is a reply to message #722353] |
Wed, 07 September 2011 13:57 |
would it be possible for you to share the detailed configuration with
us, which caused problems? We are running EMFStore on Indigo and we
would be interested in fixing any issues if there are some.
Jonas
Am 05.09.2011 15:34, schrieb maureyeslopez:
> Jonas, my problem was in the prerrequisites. I was trying to use EMF
> Store with Eclipse Indigo for Plugin Development with several plugins
> added (EMF, Teneo, etc)
> I installed Helios for Modelling and I don't have the problem any more.
> Thanks
FUDForum. Page generated in 0.02984 seconds
