Home » Modeling » Papyrus » Create custom diagram type from profile
Create custom diagram type from profile [message #721677] Fri, 02 September 2011 14:18 Go to next message
Manwlis Kapshs is currently offline Manwlis KapshsFriend
I have a UML profile and I want to create custom diagram types from this profile. I searched in the svn and online but I could not find any documentation/example how to do this. How can I do this? Is there any documentation for this task?
Many thanks for your help,
Manwlis
Re: Create custom diagram type from profile [message #721878 is a reply to message #721677] Sat, 03 September 2011 10:11 Go to previous messageGo to next message
Neslepaks  is currently offline Neslepaks Friend
Member
I wonder if this is useful though it is not directly associated with profiles http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papyrus/trunk/examples/others/org.eclipse.papyrus.example.diagram.simplediagram/docs/PapyrusDevelopperTutorial_OnDiagramCreating.odt
Re: Create custom diagram type from profile [message #722152 is a reply to message #721878] Sun, 04 September 2011 19:03 Go to previous messageGo to next message
Timothy Marc is currently offline Timothy MarcFriend
As Neslepeaks indicated, this is not related to UML profiles and rather
explains how to create new diagrams for UML (what can be quite helpful as
well). You may look into the SysML sources, in particular the
oep.sysml.diagram.common, oep.sysml.diagram.ui and
oep.sysml.diagram.requirements. From what I've seen so far (since the
question Manwlis stated is important for me as well), it introduces some
Papyrus-specific "simplifications". I've found some new EMF models, which
are obviously used for GMF generation, but are not further explained...
I think without help from the Papyrus developer community, you won't find
the best answer.
Timothy
"Neslepaks" schrieb im Newsbeitrag news:j3stru$vkk$1@news.eclipse.org...
profiles
Re: Create custom diagram type from profile [message #722396 is a reply to message #722152] Mon, 05 September 2011 16:12 Go to previous message
Thank you both for your replies.
Since one of the strong/selling points of Papyrus is its customisation capabilities, there should be some documentation which covers this area. Building a profile is one thing, but building a modeller dedicated to the profile is another. I hope that the developer team will put some time and effort in the future to provide a tutorial covering this area.
Previous Topic:CallEvent to trigger stateMachine transition ?
Next Topic:Reuse of elements of user created models inter / intra projects
Current Time: Mon Feb 17 21:22:12 GMT 2020
Powered by FUDForum. Page generated in 0.08756 seconds
