Re: Installing artifacts from Eclipse projects into Virgo manually [message #721725 is a reply to message #721289] |
Fri, 02 September 2011 16:56 |
If your using the latest Virgo IDE tools you should just add the server using the 2.1 configuration, it will mostly work although a few features might be missing compared to the tools before donation to Eclipse, these will be re-instated soon.
The /stage subfolder is created by the tools, you should not use it. It is just another configured repository like 'repositories/ext' and 'repositories/user'.
If you have built bundles you can always just deploy them in to the pickup directory if your having trouble with the tools.
Chris.
Chris Frost, Twitter @cgfrost
Springsource, a divison of VMware.
FUDForum. Page generated in 0.03036 seconds
