event handle class problem [message #721274] |
Thu, 01 September 2011 10:03 |
Spatial_Man Messages: 4 Registered: September 2011 |
Hi, I create a new java project in Birt with some class as here:
publib.boulder.ibm.com/infocenter/rsasehlp/v7r5m0/index.jsp?topic=/org.eclipse.birt.doc/birt/ScriptingWithJava.html
But when I preview my report in Web Viewer, in bottom of the document I see this error:
The following items have error:
Label (id=169):
+Class WordPackage.LabelEventHandler not found.
Why he can not see a path?
For earlier thanks to all.
[Updated on: Thu, 01 September 2011 10:12] Report message to a moderator
Re: event handle class problem [message #721403 is a reply to message #721274] |
Thu, 01 September 2011 16:38 |
Take a look at this blog:
http://birtworld.blogspot.com/2009/12/birt-designer-classpath-changes.html
Jason
> see this error:
> Label (id=169):
> Because of what he can not see a path?
Re: event handle class problem [message #721691 is a reply to message #721628] |
Fri, 02 September 2011 15:12 |
Do you have one java project and one Birt report project in your
workspace. If you look at the classpath setting in the preferences for
Report Design, you should be able to add the java project to your classpath.
Jason
On 9/2/2011 7:05 AM, Spatial_Man wrote:
> Thanks Jason Weathersby. But I not find there any solution of problem :(
FUDForum. Page generated in 0.03290 seconds
