Archive/package for manual installation [message #721040] |
Wed, 31 August 2011 19:01  |
Andi  Messages: 5 Registered: August 2011 |
could you please provide packages to allow manual installation of the plugin? I have a network which is not connected to internet and two different operating systems and problems with the Eclipse proxy feature. Furthermore the daily Hudson/Jenkins builds are not an option, because I don't know which release it is -- So everything I tried to get the Egit plugin didn't work.
This of course also affects all other plugins -- so perhaps it would make sense to add a general feature request against eclipse.org? If someone can point me to a location where this could be addressed, I would appreciate this very much.
Andi
Re: Archive/package for manual installation [message #722803 is a reply to message #722688] |
Tue, 06 September 2011 18:27  |
Yep, you're absolutely right. I would highly appreciate this.
What you say is true for other plugins as well (e.g. considering using Java and C/C++ through CDT on such a PC). So perhaps you can post the current process you're using to release an official build. I would be interested how much handwork this involves. If this is a lot, other projects will perhaps not do it because of lack of manpower. In this case (at least for eclipse.org related projects) I could try to contact the different stakeholders (Web team, Hudson maintainer, people from other projects) to find a way to automatize this (through a hudson plugin, e.g.) or reduce handwork.
FUDForum. Page generated in 0.01804 seconds
