Home » Archived » BIRT » Dynamic SVG Image: Item is not supported
Dynamic SVG Image: Item is not supported [message #720979] Wed, 31 August 2011 15:54 Go to next message
Originally posted by: Mirko Swillus
Hej,
I'm trying to render a SVG image that is provided as a byte array within
a DataSource, target format is PDF. All the PDF says, is
"Current report item is not supported in this report format."
When I put a JPG as a byte array into the DataSources property
'row["Image"]' (see rptdesign below) everything works fine. Furthermore,
adding an embedded SVG image works, too.
I guess I have to specify the images mime type ("image/svg+xml"), image
type or file extension, but I have no glue how to do it. All I tried
concerning this failed.
Please find the interesting part of my .rptdesign below. Thanks in advance,
Mirko Swillus
<body>
<image name="name_blue" id="15">
<property name="height">3.15625in</property>
<property name="width">7.583333333333333in</property>
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<property name="name">Image</property>
<expression name="expression"
type="javascript">dataSetRow["Image"]</expression>
<property name="dataType">javaObject</property>
</structure>
</list-property>
<structure name="toc"/>
<property name="source">expr</property>
<expression name="valueExpr">row["Image"]</expression>
</image>
</body>
Re: Dynamic SVG Image: Item is not supported [message #721115 is a reply to message #720979] Wed, 31 August 2011 22:28 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Have you set the data type to blob and tried it?
I was able to read one from a file in the image onCreate script like:
importPackage(Packages.java.io);
importPackage(Packages.java.lang);
var file = new File("C:/work/workspaces/2.6.1workspaces/BIRT -
Reports/BIRT Reports/resources/spain.svg");
var ist = new FileInputStream(file);
var lengthi = file.length();
bytesa = new ByteArrayOutputStream( lengthi);
var c;
while((c=ist.read()) != -1){
bytesa.write(c);
} ist.close();
this.data = bytesa.toByteArray();
Jason
On 8/31/2011 11:54 AM, Mirko Swillus wrote:
> Hej,
> Mirko Swillus
> <body>
> <structure>
> </structure>
> </list-property>
> </image>
> </body>
Re: Dynamic SVG Image: Item is not supported [message #721269 is a reply to message #721115] Thu, 01 September 2011 09:50 Go to previous messageGo to next message
Jason,
Am 01.09.2011 00:28, schrieb Jason Weathersby:
thanks for your answer, but changing 'javaObject' to 'blob' makes no
difference.
But I managed to solve the problem, with the help of [0]. As I guessed
yesterday, I had to set the MIME type explicitly, since BIRT obviously
has problems to resolve the image type itself when overhanding a SVG as
a byte array (at least within my BIRT 3.7 runtime here, providing a JPG
the same way works fine).
The resulting part of my .rptdesign looks like this now:
<body>
<image name="some" id="15">
<structure>
</structure>
</list-property>
<expression name="typeExpr">"image/svg+xml"</expression>
</image>
</body>
Mind the <expression name="typeExpr">"image/svg+xml"</expression>.
Quotes are required because it has to be a valid JavaScript Expression.
Mirko Swillus
[0]
http://www.eclipse.org/birt/ref/rom/elements/Image.html#Property-typeExpr
> var c;
> bytesa.write(c);
> } ist.close();
> Jason
>> Hej,
>> advance,
>> Mirko Swillus
>> <body>
>> <structure>
>> </structure>
>> </list-property>
>> </image>
>> </body>
Re: Dynamic SVG Image: Item is not supported [message #721387 is a reply to message #721269] Thu, 01 September 2011 16:01 Go to previous messageGo to next message
Thanks for posting.
Jason
On 9/1/2011 5:50 AM, Mirko Swillus wrote:
> Jason,
> difference.
> <body>
> <structure>
> </structure>
> </list-property>
> </image>
> </body>
> Regards,
> Mirko Swillus
> [0]
> > var c;
> > bytesa.write(c);
> > } ist.close();
> > Jason
> >> Hej,
> within
> Furthermore,
> >> advance,
> >> Mirko Swillus
> >> <body>
> >> <structure>
> >> </structure>
> >> </list-property>
> >> </image>
> >> </body>
Re: Dynamic SVG Image: Item is not supported [message #777630 is a reply to message #721387] Tue, 10 January 2012 20:57 Go to previous messageGo to next message
Chris Harrington is currently offline Chris HarringtonFriend
I tried setting typeExpr to "image/svg+xml" but am not getting the SVG to display. Same code works for PNG, and SVG url works if is static. What might I check?
Re: Dynamic SVG Image: Item is not supported [message #778399 is a reply to message #777630] Wed, 11 January 2012 17:28 Go to previous messageGo to next message
What browser are you using?
Jason
> What might I check?
Re: Dynamic SVG Image: Item is not supported [message #778713 is a reply to message #778399] Fri, 13 January 2012 17:19 Go to previous messageGo to next message
Firefox 9
Re: Dynamic SVG Image: Item is not supported [message #778715 is a reply to message #778713] Fri, 13 January 2012 17:28 Go to previous messageGo to next message
I also tried doing it in onCreate()
First, I tried using it directly:
-- begin code --
var file = new File("C:/Users/chris/Downloads/helloworld.svg");
var c;
bytesa.write(c);
ist.close();
-- end code --
The SVG wasn't displayed and there was no error
Then since I wasn't sure if it needed to be transcoded, I tried:
-- begin code --
try {
var t = new Packages.org.apache.batik.transcoder.image.PNGTranscoder();
var s = new Packages.java.lang.String(ist.toString());
var bais = new Packages.java.io.ByteArrayInputStream(s.getBytes());
var input = new Packages.org.apache.batik.transcoder.TranscoderInput(bais);
var baos = new Packages.java.io.ByteArrayOutputStream();
var output = new Packages.org.apache.batik.transcoder.TranscoderOutput(baos);
t.transcode(input, output);
this.data = baos.toByteArray();
} catch (e) {
Packages.javax.swing.JOptionPane.showMessageDialog(null, e);
-- end code --
This resulted in the error
JavaException org.apache.batik.transcoder.TranscoderException: null
Enclosed Exception
Content is not allowed in prolog.
Re: Dynamic SVG Image: Item is not supported [message #778775 is a reply to message #778715] Fri, 13 January 2012 19:57 Go to previous messageGo to next message
Can you try the attached example?
Jason
> -- begin code --
> var c;
> bytesa.write(c);
> ist.close();
> -- end code --
> -- begin code --
> try {
> var output = new
> } catch (e) {
> -- end code --
> Enclosed Exception
Re: Dynamic SVG Image: Item is not supported [message #778804 is a reply to message #778775] Fri, 13 January 2012 21:46 Go to previous messageGo to next message
Hi Jason,
It runs without error, but it didn't render the SVN. I've attached an image of the output.
I installed the BIRT reporting version of Eclipse about two weeks ago, so I should be current. I've also attached a dump of my configuration.
Many thanks for your assistance!
- Chris
Re: Dynamic SVG Image: Item is not supported [message #778838 is a reply to message #778804] Fri, 13 January 2012 23:20 Go to previous messageGo to next message
Hi Jason,
I noticed that your report file has BIRT Designer Version 2.6.1, and I am using Version 3.7.1. Is that relevant?
What I am ultimately needing to do is modify an SVG template based upon data fields. I think the options are
a) request an SVG via a url with a querystring, and have a the servlet load, modify, and return the SVG
b) load an SVG in the onRender event and using script modify the SVG DOM before transcoding
c) some other approach I haven't considered.
But first I need to get working a simple example of a dynamic SWF.
Re: Dynamic SVG Image: Item is not supported [message #780355 is a reply to message #778838] Tue, 17 January 2012 16:48 Go to previous messageGo to next message
Chris,
This worked for me in 3.7.1 as well. Can you look at your preferences:
Window->preferences->Report Design->Preview and check the box to Always
use external browsers. Then click on the Web Browser link below the
checkbox to verify that it is using firefox?
Jason
On 1/13/2012 6:20 PM, Chris Harrington wrote:
> Hi Jason,
> before transcoding
Re: Dynamic SVG Image: Item is not supported [message #781116 is a reply to message #720979] Fri, 20 January 2012 15:21 Go to previous messageGo to next message
Hi Jason,
That did the trick. Thanks much for your assistance.
- Chris
Re: Dynamic SVG Image: Item is not supported [message #782891 is a reply to message #780355] Tue, 24 January 2012 16:48 Go to previous messageGo to next message
How to load SVG from a URL?
I can do this to load an image from a URL:
try {
importPackage(Packages.java.net);
importPackage(Packages.javax.imageio);
var myurl = new Packages.java.net.URL("http://localhost/welcome.png");
var img = ImageIO.read(myurl);
bas = new ByteArrayOutputStream();
ImageIO.write(img, "png", bas);
this.data = bas.toByteArray();
} catch (e) {
But I can't figure out how to do the same for an SVG image. Thanks for any guidance.
- Chris
Re: Dynamic SVG Image: Item is not supported [message #783012 is a reply to message #782891] Tue, 24 January 2012 22:32 Go to previous messageGo to next message
Why not use a URI image and just set the uri in the editor or in script
like:
var myurl = new Packages.java.net.URL("yoururltosvg");
this.URI = myurl;
Jason
> try {
> } catch (e) {
> any guidance.
> - Chris
Re: Dynamic SVG Image: Item is not supported [message #783928 is a reply to message #783012] Thu, 26 January 2012 19:07 Go to previous messageGo to next message
I tried that, both in onCreate() and onRender(). There was no error but nothing was drawn.
Re: Dynamic SVG Image: Item is not supported [message #783933 is a reply to message #783012] Thu, 26 January 2012 19:26 Go to previous messageGo to next message
Here's more details on my results so far. Some things work properly with some methods, but there are certainly lots of issues.
Method 1:
code:
var file = new File("C:/inetpub/wwwroot/spaceship3.svg");
var c;
bytesa.write(c);
ist.close();
results:
In report viewer, the SVG image is displayed. The render quality is high. Onload()
script in SVG is executted and rendered results reflect DOM operations done in script.
In PDF, the SVG image is displayed but the transparency is lost (transparency was
present in web viewer). Onload() script operations are not reflected in rendered
results.
Method 2:
code:
var url = new Packages.java.net.URL("http://localhost/sendsvg.aspx?score=5&m=3&sd=2");
this.URI = url;
results:
The SVG image is not rendered.
Method 3:
code:
var conn = url.openConnection();
var inp = conn.getInputStream();
var input = new Packages.org.apache.batik.transcoder.TranscoderInput(inp);
results:
The SVG is rendered in the report viewer. Rendering quality is not as good
as in Method 2. Transparency is rendered properly. Onload() script in SVG
in not reflected in rendering.
In the PDF, rendering quality is not so good, transparency works, onload() is
not reflected in results.
Re: Dynamic SVG Image: Item is not supported [message #784503 is a reply to message #783933] Fri, 27 January 2012 16:17 Go to previous messageGo to next message
In method 1 are you running to html in the viewer and then exporting to pdf?
Jason
> Method 1:
> code:
> var c;
> bytesa.write(c);
> ist.close();
> results:
> high. Onload()
> done in script.
> (transparency was
> rendered
> results.
> Method 2:
> code:
> var url = new
> this.URI = url;
> results:
> Method 3:
> code:
> var url = new
> var output = new
> results:
> onload() is
Re: Dynamic SVG Image: Item is not supported [message #784550 is a reply to message #784503] Fri, 27 January 2012 17:30 Go to previous messageGo to next message
Yes.
Re: Dynamic SVG Image: Item is not supported [message #786589 is a reply to message #784550] Mon, 30 January 2012 15:56 Go to previous messageGo to next message
Chris,
Can you open a bugzilla request for this?
Jason
On 1/27/2012 12:30 PM, Chris Harrington wrote:
> Yes.
Re: base64 image is not rendering in pdf [message #1403237 is a reply to message #786589] Tue, 22 July 2014 15:00 Go to previous message
Padmasridhar c is currently offline Padmasridhar cFriend
I have Two problems in BIRT
1.I have base64 image url I am able view the imag ein BIRT viewer but when i download as pdf.Its showing as error The resource of this report item is not reachable.
2 . I am not able to pass base64 link as a parameter
Kindly help in this
Example base64 link :
data:image/jpeg;base64,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
Previous Topic:Parameter help
Next Topic:4.4: Hang/Crash on "view report"
Current Time: Tue Apr 16 04:35:24 GMT 2024
Powered by FUDForum. Page generated in 0.07257 seconds
