Create Control Dynamically [message #720484] |
Tue, 30 August 2011 17:09 |
Balaji Messages: 17 Registered: August 2011 |
I want to dynamically create 'n' number of control(say TextBox or Label) and want to have an action to all Controls.
Example
1. Dynamically Create 10 Textbox
2. On CARRIAGE return of it perform some operation (addKeyListener)
(Edited)
My Question
How to I add action to those created controls?
Is there any Control Array(same as VB)
[Updated on: Wed, 31 August 2011 02:59] Report message to a moderator
Re: Create Control Dynamically [message #720728 is a reply to message #720484] |
Wed, 31 August 2011 06:52 |
Originally posted by:
On 2011-08-30 19:09, Balaji wrote:
> Hi I want to dynamically create 'n' number of control(say TextBox or
1) There is no 'TextBox' in SWT, do you mean the
org.eclipse.swt.widgets.Text widget?
2) You don say what kind of "actions" you are referring to. Do you want
to register a SelectionListener or a generic Listener?
> Example
> 2. Specific 5 TextBox has to perform some action on CARRIAGE RETURN and
> other 5 perform some action on ESCAPE key
> My Question
I don't understand the question. If you are writing a loop to generate
the control, why is there there a problem to add the listeners within
the loop?
I don't know, what a Control Array is, but you can simply create a
java.util.List<org.eclipse.swt.widgets.Control> if you really need to.
HTH & Greetings from Bremen,
- Daniel Krügler
Re: Create Control Dynamically [message #722333 is a reply to message #721889] |
Mon, 05 September 2011 12:06 |
On 2011-09-03 13:56, Balaji wrote:
> Hi
> Thanks.
> Here is the sample code, where I want to create a 'n' Label and want to
> perform a move operation on selected Label.
> Example
> Label label;
> Listener listener = new Listener () {
> public void handleEvent (Event event) {
> // MY HANDLER HERE
> for(...) { label = new Label(composite, SWT.NONE);
> label.addListener (SWT.MouseDown, listener);
> Please correct me if anything is wrong.
> My Doubt
> In the above case, in the handler how do I know on which Label its
> operating?
The event handler function provides an Event object. Look at the member
"widget" to get access to the widget that had caused the event to fire.
- Daniel Krügler
FUDForum. Page generated in 0.03455 seconds
