Home » Modeling » EMF » Proxy & Lazy Load on Many-To-On Association
Proxy & Lazy Load on Many-To-On Association [message #720216] |
Tue, 30 August 2011 07:08 |
Cristian Prevedello Messages: 33 Registered: June 2011 |
Member |
Greetings
i'm having some problems with many-to-one associations and lazy load.
Currently all my entities are marked ad lazy="true". There's no proxy turned on, and so far everything works fine, except for those many-to-one associations who are eagerly loaded.
Until now we were in alpha phase, and were just grounding the application so this issue was not important.
Now we need to start to fine tune the datalayer and loading half database in memory is not an option.
So we turned on
props.setProperty(org.eclipse.emf.teneo.PersistenceOptions.SET_PROXY,"true");
First problem is referenced entity is still eagerly loaded, and i get an exception in the eSet method of my containing entity:
public void eSet(int featureID, Object newValue) {
switch (featureID)
case MyPagePackage.XXXXX:
setMyReferenceProperty((MyClass)newValue);
newvalue is an HibernateProxy and is casted to MyClass throwing an exception.
The faq mentions disabling "resolve proxies" on the model: i did this but still the property is eagerly loaded.
thank you in advance.
best regards.
[Updated on: Tue, 30 August 2011 07:27] Report message to a moderator
Re: Proxy & Lazy Load on Many-To-On Association [message #720231 is a reply to message #720216] |
Tue, 30 August 2011 07:47 |
Resolve proxies is set on the ereference.
To find out why the proxy get's loaded get the Hibernate source code and put a breakpoint in
AbstractLazyInitializer.initialize. The callstack should show what calls the proxied object. Can you post the callstack
here if you feel it is teneo/emf code?
Not sure why the CCE happens, see this part of the hibernate docs:
http://docs.jboss.org/hibernate/core/3.6/reference/en-US/html_single/#performance-fetching-proxies
especially about the example cat/domesticcat. Could that be the issue here?
gr. Martin
On 08/30/2011 09:08 AM, cristian.prevedello wrote:
> Greetings
> So we turned on
> entity:
> switch (featureID)
> The faq mentions disabling "resolve proxies" on the model, but could not find any othe informations about. This might
> fix the lazy load problem, but what about the hibernateproxy cast problem?
> best regards.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Proxy & Lazy Load on Many-To-On Association [message #720252 is a reply to message #720246] |
Tue, 30 August 2011 08:29 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
I can remember having had the same problem and the only solution for us
was to remove the generated proxy="..." in a postprocessing step because
we are loading a pregenerated hbm.xml-File this is not really a problem
to us.
The code looks like this:
> private File generateHbmXML(Properties hibernateProps, File outDir,
> Class<?> dialect, Class<?> idMapper) throws Exception {
> File hbmXML = new File(outDir, dialect.getSimpleName()
> + "-hibernate.hbm.xml");
> ExtensionManager extensionManager = ExtensionManagerFactory
> .getInstance().create();
> extensionManager.registerExtension(IdMapper.class.getName(),
> idMapper.getName());
> extensionManager.registerExtension(SQLNameStrategy.class.getName(),
> BizerbaSQLNameStrategy.class.getName());
> String mapping = HbHelper.INSTANCE.generateMapping(
> new EPackage[] { RetailPackage.eINSTANCE }, hibernateProps,
> extensionManager);
> FileWriter writer = new FileWriter(hbmXML);
> // Last fix up else we get JavaAssist errors
> mapping = mapping.replaceAll("proxy=\"com\\.(\\w+\\.?)*\"", "");
> writer.write(mapping);
> writer.close();
> return hbmXML;
Tom
Am 30.08.11 10:10, schrieb cristian.prevedello:
> Ty Martin, as you wrote i was browsing emf.codegen code looking for
> reloveproxy stuff and found it. been wandering for a while looking for
> this option and it was under my eyes.
> anyhow this is the stack :
> VariabileUtente is the my container class, while ParametroQuestionario
> is the contained class.
> with at
> com.ViewShape.DAO.ViewShapeDAO.loadVariabileUtenteById(ViewShapeDAO.java:600)
> i'm loading an instance of VariabileUtente by Id. In the stack trace
> there's not sign of LazyLoad initializer
> this is mapping extract of VariabileUtente
> <class name="com.ViewShape.Model.ViewshapemodelFactory$6"
> entity-name="VariabileUtente" abstract="false" lazy="true"
> discriminator-value="VariabileUtente" table="`variabileutente`"
> proxy="com.ViewShape.Model.Base.VariabileUtente">
> <many-to-one name="ParametriQuestionari"
> entity-name="ParametroQuestionario" lazy="proxy" cascade="all"
> foreign-key="variabileutente_parametriquestionari" insert="true"
> update="true" not-null="false">
> <column not-null="false" unique="false"
> name="`parametroquestionario_parametriquestionari_e_id`"/>
> </many-to-one>
> mapping for ParametroQuestionario
> <class name="com.ViewShape.Model.ViewshapemodelFactory$29"
> entity-name="ParametroQuestionario" abstract="false" lazy="true"
> discriminator-value="ParametroQuestionario"
> table="`parametroquestionario`"
> proxy="com.ViewShape.Model.Base.ParametroQuestionario">
> java.lang.ClassCastException:
> org.hibernate.proxy.HibernateProxy_$$_javassist_0 cannot be cast to
> at
> com.ViewShape.Model.Base.VariabileUtente.eSet(VariabileUtente.java:2171)
> at
> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjectImpl.java:1081)
> at
> org.eclipse.emf.teneo.hibernate.mapping.property.EReferencePropertyHandler.set(EReferencePropertyHandler.java:190)
> at
> org.hibernate.tuple.entity.AbstractEntityTuplizer.setPropertyValues(AbstractEntityTuplizer.java:583)
> at
> org.hibernate.persister.entity.AbstractEntityPersister.setPropertyValues(AbstractEntityPersister.java:3822)
> at
> org.hibernate.engine.TwoPhaseLoad.initializeEntity(TwoPhaseLoad.java:152)
> at
> org.hibernate.loader.Loader.initializeEntitiesAndCollections(Loader.java:982)
> at org.hibernate.loader.Loader.doQuery(Loader.java:857)
> at
> org.hibernate.loader.Loader.doQueryAndInitializeNonLazyCollections(Loader.java:274)
> at org.hibernate.loader.Loader.loadEntity(Loader.java:2037)
> at
> org.hibernate.loader.entity.AbstractEntityLoader.load(AbstractEntityLoader.java:86)
> at
> org.hibernate.loader.entity.AbstractEntityLoader.load(AbstractEntityLoader.java:76)
> at
> org.hibernate.persister.entity.AbstractEntityPersister.load(AbstractEntityPersister.java:3268)
> at
> org.hibernate.event.def.DefaultLoadEventListener.loadFromDatasource(DefaultLoadEventListener.java:496)
> at
> org.hibernate.event.def.DefaultLoadEventListener.doLoad(DefaultLoadEventListener.java:477)
> at
> org.hibernate.event.def.DefaultLoadEventListener.load(DefaultLoadEventListener.java:227)
> at
> org.hibernate.event.def.DefaultLoadEventListener.proxyOrLoad(DefaultLoadEventListener.java:285)
> at
> org.hibernate.event.def.DefaultLoadEventListener.onLoad(DefaultLoadEventListener.java:152)
> at org.hibernate.impl.SessionImpl.fireLoad(SessionImpl.java:1090)
> at org.hibernate.impl.SessionImpl.get(SessionImpl.java:1005)
> at
> com.Larix.Utils.DataLayer.DataLayerSessionHibernate.get(DataLayerSessionHibernate.java:87)
> at
> at
> com.ViewShape.ViewShapeModel.tests.ViewShapeModelSearchTests.TestLoadForMultipleJoin(ViewShapeModelSearchTests.java:91)
Re: Proxy &amp; Lazy Load on Many-To-On Association [message #720253 is a reply to message #720246] |
Tue, 30 August 2011 08:31 |
Hmm, I mean the stacktrace when you put a breakpoint in the initialize method of the AbstractLazyInitializer, that will
show what code forces the proxy load.
The names of the classes in the mapping seem very strange (with $29 and $6), where is this coming from? It could be related.
gr. Martin
On 08/30/2011 10:10 AM, cristian.prevedello wrote:
> Ty Martin, as you wrote i was browsing emf.codegen code looking for reloveproxy stuff and found it. been wandering for a
> while looking for this option and it was under my eyes.
> VariabileUtente is the my container class, while ParametroQuestionario is the contained class.
> with at com.ViewShape.DAO.ViewShapeDAO.loadVariabileUtenteById(ViewShapeDAO.java:600)
> i'm loading an instance of VariabileUtente by Id. In the stack trace there's not sign of LazyLoad initializer
> <class name="com.ViewShape.Model.ViewshapemodelFactory$6" entity-name="VariabileUtente" abstract="false" lazy="true"
> discriminator-value="VariabileUtente" table="`variabileutente`" proxy="com.ViewShape.Model.Base.VariabileUtente">
> <many-to-one name="ParametriQuestionari" entity-name="ParametroQuestionario" lazy="proxy" cascade="all"
> foreign-key="variabileutente_parametriquestionari" insert="true" update="true" not-null="false">
> <column not-null="false" unique="false" name="`parametroquestionario_parametriquestionari_e_id`"/>
> </many-to-one>
> <class name="com.ViewShape.Model.ViewshapemodelFactory$29" entity-name="ParametroQuestionario" abstract="false"
> lazy="true" discriminator-value="ParametroQuestionario" table="`parametroquestionario`"
> java.lang.ClassCastException: org.hibernate.proxy.HibernateProxy_$$_javassist_0 cannot be cast to
> at com.ViewShape.Model.Base.VariabileUtente.eSet(VariabileUtente.java:2171)
> at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjectImpl.java:1081)
> at org.eclipse.emf.teneo.hibernate.mapping.property.EReferencePropertyHandler.set(EReferencePropertyHandler.java:190)
> at org.hibernate.tuple.entity.AbstractEntityTuplizer.setPropertyValues(AbstractEntityTuplizer.java:583)
> at org.hibernate.persister.entity.AbstractEntityPersister.setPropertyValues(AbstractEntityPersister.java:3822)
> at org.hibernate.engine.TwoPhaseLoad.initializeEntity(TwoPhaseLoad.java:152)
> at org.hibernate.loader.Loader.initializeEntitiesAndCollections(Loader.java:982)
> at org.hibernate.loader.Loader.doQueryAndInitializeNonLazyCollections(Loader.java:274)
> at org.hibernate.loader.entity.AbstractEntityLoader.load(AbstractEntityLoader.java:86)
> at org.hibernate.loader.entity.AbstractEntityLoader.load(AbstractEntityLoader.java:76)
> at org.hibernate.persister.entity.AbstractEntityPersister.load(AbstractEntityPersister.java:3268)
> at org.hibernate.event.def.DefaultLoadEventListener.loadFromDatasource(DefaultLoadEventListener.java:496)
> at org.hibernate.event.def.DefaultLoadEventListener.doLoad(DefaultLoadEventListener.java:477)
> at org.hibernate.event.def.DefaultLoadEventListener.load(DefaultLoadEventListener.java:227)
> at org.hibernate.event.def.DefaultLoadEventListener.proxyOrLoad(DefaultLoadEventListener.java:285)
> at org.hibernate.event.def.DefaultLoadEventListener.onLoad(DefaultLoadEventListener.java:152)
> at com.Larix.Utils.DataLayer.DataLayerSessionHibernate.get(DataLayerSessionHibernate.java:87)
> at com.ViewShape.ViewShapeModel.tests.ViewShapeModelSearchTests.TestLoadForMultipleJoin(ViewShapeModelSearchTests.java:91)
The Netherlands
Re: Proxy &amp;amp; Lazy Load on Many-To-On Association [message #720815 is a reply to message #720296] |
Wed, 31 August 2011 09:39 |
Member |
Well before forcing you to dig into the package i tried to solve the problem.
Digging more into the problem i discovered several problems:
First of all all my entities were marked as lazy="false". i guess with all the tests i made i got screwed up the configuration. This caused the eager load of all entities.
To fix this i extracted the mapping, saved to an xml and updated, setting all my entities as as lazy loadable and now lazy loading was working. Tried to turn on proxy configuration option and again lazy loading was working.
At this point things improved a bit. References are not eagerly loaded, but the ESet method on my entites throws an exception. To fix the problem i had to do something like this in eSet, but this causes the reference to be lazy loaded.
case ViewshapemodelPackage.VARIABILE_UTENTE__CONFIGURAZIONE_QUESTIONARIO_STANDARD:
setConfigurazioneQuestionarioStandard((QuestionarioStandard)((HibernateProxy)newValue).getHibernateLazyInitializer().getImplementation());
kinda lost at this point. Hibernate proxy should derive from my base classes, so i should be able be casted to model classes without problem, right?
[Updated on: Wed, 31 August 2011 16:30] Report message to a moderator
Re: Proxy &amp;amp;amp; Lazy Load on Many-To-On Association [message #721042 is a reply to message #720815] |
Wed, 31 August 2011 18:30 |
Hi Cristian,
I published a new teneo build with a new PersistenceOption: PersistenceOptions.FORCE_LAZY (default is false, you need to
set it to true), the full option name is teneo.mapping.force_lazy. Can you try with setting this option to true?
And set the SET_PROXY option to false. This should force lazy="true" in the mapping without the proxy attribute.
The entity which gets loaded in your stack trace, is that the entity you are requesting in
DataLayerSessionHibernate.get, if so, then this is correct, when you get an instance directly with get it is not lazy
loaded/proxied. The same applies when reading instances with a query. Basically only many-to-one associations are
possibly lazily loaded.
The exception you are getting is not 'normal', my feel is that somehow the mapping does not contain the correct
information. Can you retry with the new option above?
gr. Martin
> First of all all my entities are marked as lazy="false". This cause the eager load of all entities. What can cause the
> lazy="false"?
> To fix this i extracted the mapping, saved to an xml and updated, setting all my entities as as lazy loadable.
> At this point things improved a bit. References not eagerly loaded, but there's something that still try to lazy load
> them. Now AbstractInitilizer is hit. here is the stack:
> Thread [main] (Suspended (breakpoint at line 165 in AbstractLazyInitializer))
> JavassistLazyInitializer(AbstractLazyInitializer).initialize() line: 165
> JavassistLazyInitializer(AbstractLazyInitializer).getImplementation() line: 215
> ViewshapemodelFactory$6(VariabileUtente).eSet(int, Object) line: 2205
> ViewshapemodelFactory$6(BasicEObjectImpl).eSet(EStructuralFeature, Object) line: 1081
> EReferencePropertyHandler.set(Object, Object, SessionFactoryImplementor) line: 190
> EMFTuplizer(AbstractEntityTuplizer).setPropertyValues(Object, Object[]) line: 583
> SingleTableEntityPersister(AbstractEntityPersister).setPropertyValues(Object, Object[], EntityMode) line: 3822
> TwoPhaseLoad.initializeEntity(Object, boolean, SessionImplementor, PreLoadEvent, PostLoadEvent) line: 152
> EntityLoader(Loader).initializeEntitiesAndCollections(List, Object, SessionImplementor, boolean) line: 982
> EntityLoader(Loader).doQuery(SessionImplementor, QueryParameters, boolean) line: 857
> EntityLoader(Loader).doQueryAndInitializeNonLazyCollections(SessionImplementor, QueryParameters, boolean) line: 274
> EntityLoader(Loader).loadEntity(SessionImplementor, Object, Type, Object, String, Serializable, EntityPersister,
> LockOptions) line: 2037
> EntityLoader(AbstractEntityLoader).load(SessionImplementor, Object, Object, Serializable, LockOptions) line: 86
> EntityLoader(AbstractEntityLoader).load(Serializable, Object, SessionImplementor, LockOptions) line: 76
> SingleTableEntityPersister(AbstractEntityPersister).load(Serializable, Object, LockOptions, SessionImplementor) line: 3268
> DefaultLoadEventListener.loadFromDatasource(LoadEvent, EntityPersister, EntityKey, LoadEventListener$LoadType) line: 496
> DefaultLoadEventListener.doLoad(LoadEvent, EntityPersister, EntityKey, LoadEventListener$LoadType) line: 477
> DefaultLoadEventListener.load(LoadEvent, EntityPersister, EntityKey, LoadEventListener$LoadType) line: 227
> DefaultLoadEventListener.proxyOrLoad(LoadEvent, EntityPersister, EntityKey, LoadEventListener$LoadType) line: 285
> DefaultLoadEventListener.onLoad(LoadEvent, LoadEventListener$LoadType) line: 152
> SessionImpl.fireLoad(LoadEvent, LoadEventListener$LoadType) line: 1090
> SessionImpl.get(String, Serializable) line: 1005
> DataLayerSessionHibernate.get(String, Serializable) line: 87
> ViewShapeDAO.loadVariabileUtenteById(long) line: 597
> ViewShapeTestData.SetupTestData() line: 85
> Anyway beside lazyloading problem i've still the issue that lazy load entities are proxy, and eSet throws an exception.
> To fix it i had to do something like this in eSet.
> is this normal?
The Netherlands
Re: Proxy &amp;amp;amp; Lazy Load on Many-To-On Association [message #721107 is a reply to message #721103] |
Wed, 31 August 2011 21:43 |
Yes, your remark triggered me to add this! so let's hope it helps...
gr. Martin
On 08/31/2011 11:30 PM, Tom Schindl wrote:
> Am 31.08.11 20:30, schrieb Martin Taal:
>> Hi Cristian,
>> PersistenceOptions.FORCE_LAZY (default is false, you need to set it to
> Martin this is exactly what we are using in our teneo application (but
> we did it by postprocessing the hbm.xml)
> Tom
The Netherlands
Re: Proxy &amp;amp;amp;amp; Lazy Load on Many-To-On Association [message #721260 is a reply to message #721240] |
Thu, 01 September 2011 09:16 |
Okay, good to hear, another project (I am leading to :-), which might be interesting is Texo:
http://wiki.eclipse.org/Texo
It generates simpler code than EMF, while still integrating with EMF for model-features and xml/xmi serialization, the
generated code works out of the box on a standard ORM like hibernate. Texo also makes it easy to generate the orm.xml
directly from ecore.
Texo is currently mostly for the server side of (web-)server/service environments. So not for rcp's.
gr. Martin
On 09/01/2011 10:57 AM, cristian.prevedello wrote:
> Oh well i finally discovered the problem. Javassist does not work when it comes to extend a class. It works well when it
> creates a proxy throught an interface.
> to
> In our model generation, we suppressed the usage of interfaces. In our service layer, we create a lot of new instances
> of our model classes for exchanging infos with our DTOs.
> Default generation behaviour is to generate an interface and a corresponding implementation class ( MyEntity and
> MyEntityImpl), and we did not want to pollute our service layer, with new MyEntityImpl() statments. So we killed
> interfaces as a quick fix for that.
> Now i have to code on my workunit object methos to allocate entity Implementations returned as interfaces.
> Not sure if cglib works better on this side, anyhow from first tests in my testcase everything work as expected, lazy
> load included. yeppa.
> Ty Martin for the help. Own you a bear anyhow :)
The Netherlands
Re: Proxy &amp;amp;amp;amp; Lazy Load on Many-To-On Association [message #814255 is a reply to message #721260] |
Tue, 06 March 2012 08:16 |
Member |
Greetings Marting, how are you? Hope things are going well on your side.
i'm briging up this old post again because new issues about lazy loading ManyToOne came up.
The datamodel is
Class RisultatiQuestinario 1---1 OutputRisposte
the reference is not bidirectional, that is risultatiquestionario has a link to outputrisposte, but not the reverse. And the reference is set as not optional, and with resolveproxy to false.
the generated mappings are
<class name="com.xxx.Model.impl.RisultatiQuestionarioImpl" entity-name="RisultatiQuestionario" abstract="false" lazy="true" discriminator-value="RisultatiQuestionario" table="`risultatiquestionario`" proxy="com.ViewShape.Model.Base.RisultatiQuestionario">
<id name="Id" type="long" unsaved-value="0">
<column not-null="true" unique="false" name="`id`"/>
<generator class="native"/>
</id>
<discriminator type="string">
<column name="dtype" index="risultatiquestionariodtype" length="255" not-null="true"/>
</discriminator>
<version name="e_version" type="int">
<column not-null="true" unique="false" name="`e_version`"/>
</version>
<many-to-one name="Risposte" entity-name="OutputRisposte" lazy="proxy" cascade="all" foreign-key="risultatiquestionario_risposte" insert="true" update="true" not-null="true" unique="true">
<column not-null="true" unique="false" name="`outputrisposte_risposte_e_id`"/>
</many-to-one>
<class name="com.xxx.Model.impl.OutputRisposteImpl" entity-name="OutputRisposte" abstract="false" lazy="true" discriminator-value="OutputRisposte" table="`outputrisposte`" proxy="com.ViewShape.Model.Base.OutputRisposte">
The problem is, whenever i load a RisultatiQuestionario class, OutputRisposte is eagerly loaded.
as suggested from hibernate forum i put a breakpoint into immediateload in session hibernate to see what's firing the load.
Thread [main] (Suspended)
JavassistLazyInitializer.invoke(Object, Method, Method, Object[]) line: 190
OutputRisposte_$$_javassist_32.eInverseAdd(InternalEObject, int, Class, NotificationChain) line: not available
RisultatiQuestionarioImpl.setRisposte(OutputRisposte) line: 491
RisultatiQuestionarioImpl.eSet(int, Object) line: 1368
RisultatiQuestionarioImpl(BasicEObjectImpl).eSet(EStructuralFeature, Object) line: 1081
QueryLoader(Loader).initializeEntitiesAndCollections(List, Object, SessionImplementor, boolean) line: 982
QueryLoader(Loader).doQuery(SessionImplementor, QueryParameters, boolean) line: 857
QueryLoader(Loader).doQueryAndInitializeNonLazyCollections(SessionImplementor, QueryParameters, boolean) line: 274
QueryLoader(Loader).doList(SessionImplementor, QueryParameters) line: 2533
QueryLoader(Loader).listIgnoreQueryCache(SessionImplementor, QueryParameters) line: 2276
QueryLoader(Loader).list(SessionImplementor, QueryParameters, Set, Type[]) line: 2271
QueryLoader.list(SessionImplementor, QueryParameters) line: 452
QueryTranslatorImpl.list(SessionImplementor, QueryParameters) line: 363
HQLQueryPlan.performList(QueryParameters, SessionImplementor) line: 196
SessionImpl.list(String, QueryParameters) line: 1268
QueryImpl.list() line: 102
DataLayerSessionHibernate.Query(String, Object...) line: 143
ViewShapeDAO.Query(String) line: 176
ViewShapeModelTestsSearch.TestGetListaRisultati() line: 838
NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not available [native method]
NativeMethodAccessorImpl.invoke(Object, Object[]) line: 39
DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: 25
Method.invoke(Object, Object...) line: 597
FrameworkMethod$1.runReflectiveCall() line: 44
FrameworkMethod$1(ReflectiveCallable).run() line: 15
FrameworkMethod.invokeExplosively(Object, Object...) line: 41
InvokeMethod.evaluate() line: 20
RunBefores.evaluate() line: 28
BlockJUnit4ClassRunner.runChild(FrameworkMethod, RunNotifier) line: 76
BlockJUnit4ClassRunner.runChild(Object, RunNotifier) line: 50
ParentRunner$3.run() line: 193
ParentRunner$1.schedule(Runnable) line: 52
BlockJUnit4ClassRunner(ParentRunner<T>).runChildren(RunNotifier) line: 191
ParentRunner<T>.access$000(ParentRunner, RunNotifier) line: 42
ParentRunner$2.evaluate() line: 184
BlockJUnit4ClassRunner(ParentRunner<T>).run(RunNotifier) line: 236
JUnit4TestMethodReference(JUnit4TestReference).run(TestExecution) line: 49
TestExecution.run(ITestReference[]) line: 38
RemoteTestRunner.runTests(String[], String, TestExecution) line: 467
RemoteTestRunner.runTests(TestExecution) line: 683
RemoteTestRunner.run() line: 390
RemoteTestRunner.main(String[]) line: 197
when calling eInverseAdd method, the proxy is loaded and hits the database.
ty for your help.
Re: Proxy &amp;amp;amp;amp;amp; Lazy Load on Many-To-On Association [message #814284 is a reply to message #814255] |
Tue, 06 March 2012 09:03 |
Hmm, I read a bit through the thread, but what are your current problems?
gr. Martin
> The datamodel is
> </id>
> </discriminator>
> </version>
> </many-to-one>
The Netherlands
Re: Proxy &amp;amp;amp;amp;amp;amp; Lazy Load on Many-To-On Association [message #814420 is a reply to message #814292] |
Tue, 06 March 2012 12:29 |
But the association is not bidirectional is it? Hmm, why the inverseadd?
gr. Martin
On 03/06/2012 10:22 AM, Missing name Mising name wrote:
> maybe i should have opened a new thread, since my current problem is not exatly related to what i described previosuly
> in the thread.
> right now, entities are not lazy loaded but eagerly loaded.
> RisulatoQuestionario in the model has a one way 1-1 relation with Outputrisposte
> the mapping generated is the one in my previous post. The problem is whenever i load 1 risultatoquestonario,
> outputrisposte is loaded as well. Debugging throught the code,
> i tracked down the moment the outputrisposte is loaded.
> When RisultatoQuestionario is materialized, hibernate sets a proxy for outputriposte into RisultatoQuestionario.
> In the RisultatoQuestionario setter, an inverseAdd method in proxy for outputrisposte is called, and that triggers the
> load from the database.
The Netherlands
Re: Proxy &amp;amp;amp;amp;amp;amp; Lazy Load on Many-To-On Association [message #814497 is a reply to message #814420] |
Tue, 06 March 2012 14:16 |
Member |
this is the generated setter code
public void setRisposte(OutputRisposte newRisposte)
if (newRisposte != risposte)
NotificationChain msgs = null;
if (risposte != null)
msgs = ((InternalEObject)risposte).eInverseRemove(this, ViewshapemodelPackage.OUTPUT_RISPOSTE__RISULTATO_QUESTIONARIO, OutputRisposte.class, msgs);
if (newRisposte != null)
msgs = ((InternalEObject)newRisposte).eInverseAdd(this, ViewshapemodelPackage.OUTPUT_RISPOSTE__RISULTATO_QUESTIONARIO, OutputRisposte.class, msgs);
msgs = basicSetRisposte(newRisposte, msgs);
if (msgs != null) msgs.dispatch();
else if (eNotificationRequired())
eNotify(new ENotificationImpl(this, Notification.SET, ViewshapemodelPackage.RISULTATI_QUESTIONARIO__RISPOSTE, newRisposte, newRisposte));
anyway you gave an idea, i will try to make the relation bidiretional to see if it works.
Re: Proxy &amp;amp;amp;amp;amp;amp;amp; Lazy Load on Many-To-On Association [message #814526 is a reply to message #814497] |
Tue, 06 March 2012 14:58 |
I mean the generated code seems to indicate that it is already bidirectional, which explains the inverseAdd. I mean only
bi-directional associations would have that.
I would say that you should not set it to bi-directional to prevent proxy loading.
gr. Martin
The Netherlands
Current Time: Thu Apr 25 20:15:05 GMT 2024
Powered by FUDForum. Page generated in 0.04740 seconds
