Home » Language IDEs » ServerTools (WTP) » Install J2EE & Spring plugins(Installing J2EE and Spring plugins in Helios for Javascript)
Install J2EE & Spring plugins [message #719524] Sat, 27 August 2011 15:51 Go to next message
Vasanthakumar V is currently offline Vasanthakumar VFriend
Dear All,
Not sure if this has already been discussed in this forum. I have been using eclipse "Helios for Javascript", working on js. Now I have to work in J2EE / Spring. Could you please assist in setting up J2EE / Spring in the same IDE I am using (without having to install eclipse "Helios / Indigo for J2EE")??
[Message initially posted as msg_719468 in "Java tooling in Eclipse" Forum by mistake]
Thanks and Best Regards,
Vasanthakumar V
Re: Install J2EE & Spring plugins [message #719952 is a reply to message #719524] Mon, 29 August 2011 14:47 Go to previous message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
It sounds like you'll want to check the Spring documentation; my guess is that it will direct you to which parts of the Java EE tools from Eclipse that it might need as well as how to install it properly.
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Previous Topic:Problem with Indigo and Tomcat 7.0 on fedora 15
Next Topic:Adding Taglibraries to a web app
Current Time: Tue Apr 16 13:23:07 GMT 2024
Powered by FUDForum. Page generated in 0.42203 seconds
