Home » Eclipse Projects » Standard Widget Toolkit (SWT) » MessageBox orientation
MessageBox orientation [message #719381] Fri, 26 August 2011 21:09 Go to next message
Caleb  is currently offline Caleb Friend
I'm using SWT on Windows.
I was wondering if it's even possible to change the orientation of the text label that appears on a MessageBox?
My message boxes use Hebrew, and it's aligned to the left Sad
Re: MessageBox orientation [message #719962 is a reply to message #719381] Mon, 29 August 2011 14:46 Go to previous message
Grant Gayed is currently offline Grant GayedFriend
This should work as long as your Windows install is running with its
native locale set accordingly (eg.- strings in apps like Notepad are
translated, your Start menu is in the bottom-right corner, etc.). If
this is the case then MessageBox should pick up its orientation from its
parent Shell. On the other hand, if you're running Windows in another
locale (eg.- english) then the MessageBox's orientation will always be
left-to-right.
Grant
On 8/26/2011 5:09 PM, Caleb wrote:
> My message boxes use Hebrew, and it's aligned to the left :(
Previous Topic:Why not just Draw Labels,Instead of creating one?
Next Topic:filtering comboviewer on linux and mac
Current Time: Fri Jan 15 14:54:16 GMT 2021
Powered by FUDForum. Page generated in 0.02038 seconds
