Home » Eclipse Projects » EclipseLink » Incorrect OSGI versioning on milestone builds?
Incorrect OSGI versioning on milestone builds? [message #719312] Fri, 26 August 2011 16:56 Go to next message
Jack Lynch is currently offline Jack LynchFriend
I'm deploying an existing application that uses eclipselink 2.3.1-M2 to Virgo 3.0.0.RELEASE.
Virgo complains about the versioning scheme used, i.e. 2.3.1-M2 because it expects
major.minor.micro.qualifier as int,int,int,string (see osgi.org/javadoc/r4v43/org/osgi/framework/Version.html)
[2011-08-26 15:09:25.803] system-artifacts <DE0002E> Installation of plan 'my.plan' version '1.0.0' failed. java.lang.NumberFormatException: For input string: "1-M2"
at java.lang.NumberFormatException.forInputString(NumberFormatException.java:48)
at java.lang.Integer.parseInt(Integer.java:458)
at java.lang.Integer.parseInt(Integer.java:499)
at org.osgi.framework.Version.<init>(Version.java:135)
at org.osgi.framework.Version.parseVersion(Version.java:225)
at org.eclipse.virgo.util.osgi.VersionRange.<init>(VersionRange.java:78)
at org.eclipse.virgo.util.osgi.manifest.internal.BaseImported.getVersion(BaseImported.java:48)
I can see the line (119) in uploadToMaven.xml in the source where the - needs to change to a . but am completely unable to build it from the command line (missing an entire build.deps.dir for a start, and haven't used ant for years). I had hope to just build it and deploy to our local maven repo..
Jack
Re: Incorrect OSGI versioning on milestone builds? [message #719317 is a reply to message #719312] Fri, 26 August 2011 17:27 Go to previous messageGo to next message
Shaun Smith is currently offline Shaun SmithFriend
What bundle are you having trouble with? A quick check of the manifests of the org.eclipse.persistence.core and org.eclipse.persistence.jpa bundles in the 2.3.1 M3 bundle download shows a bundle-version of 2.3.1.v20110804-r9835.
--Shaun
Re: Incorrect OSGI versioning on milestone builds? [message #719323 is a reply to message #719317] Fri, 26 August 2011 17:49 Go to previous messageGo to next message
Right now I don't know, I've been trying to locate/build a 2.3.1.M2 Smile
Upon reading your reply, I suspect the problem is that we define a property ${eclipse.persistence.version} to be 2.3.1-M2 and use it in our own pom files and template.mf files that we use with bundlor. This would mean that our own bundles have the problematic version info in their manifests. I'll take a look and relax the template.mf versioning to something like [2.3.1, 2.3.2]
Jack
Re: Incorrect OSGI versioning on milestone builds? [message #719333 is a reply to message #719323] Fri, 26 August 2011 18:18 Go to previous message
Yes that was it, using a variable (that I introduced.. sigh) while upgrading caused the problem. Thanks for your help Shaun, it sent me to the solution.
Jack
Previous Topic:[Solved] How can I set the defaultRowPrefetch size on the datasource?
Next Topic:(no subject)
Current Time: Thu May 13 23:21:08 GMT 2021
Powered by FUDForum. Page generated in 0.02440 seconds
