Home » Eclipse Projects » EGit / JGit » Tag icons
Tag icons [message #718902] Thu, 25 August 2011 14:29 Go to next message
Dani Megert is currently offline Dani MegertFriend
I see two different tag icons in the 'Git Repositories' view: a "normal"
one which is also used for local tags and one with some sort of dark
blue angle on the left side.
What I wonder is why are my own tags, even if pushed to the shared base
repository and then fetched in another workspace (and hence no longer
local) still show up without that dark blue angle? Or is that blue angle
meaning something different?
Dani
Re: Tag icons [message #718937 is a reply to message #718902] Thu, 25 August 2011 16:08 Go to previous messageGo to next message
Matthias Sohn is currently offline Matthias SohnFriend
The blue L-shaped angle decorates light-weight tags which don't have a tag message.
The user guide [1] should show the corresponding icons, I will add that.
[1] http://wiki.eclipse.org/EGit/User_Guide#Light-weight_and_Signed_Tags
Re: Tag icons [message #719179 is a reply to message #718937] Fri, 26 August 2011 08:44 Go to previous messageGo to next message
> tag message.
The user guide also says that the lightweight tags are shown in yellow.
While that's true, non-lightweight tags also appear in yellow, so that
sentence is a bit confusing.
Dani
Re: Tag icons [message #727714 is a reply to message #719179] Wed, 21 September 2011 21:11 Go to previous message
I added some screenshots to [1] to explain this better.
Previous Topic:Retrieve Tag information using JGit API
Next Topic:[Announce] JGit / EGit Release 1.1
Current Time: Thu Feb 27 06:17:46 GMT 2020
Powered by FUDForum. Page generated in 0.02145 seconds
