Re: [Teneo]Supported DB vendor/versions [message #76354 is a reply to message #76338] |
Fri, 23 March 2007 06:04 |
There is no official list and teneo is tested only on mysql and occasionally on ms sql server. I
would like to test on more databases but there is but so much time in a day available.
Note that Teneo does not add any database specific code and uses standard hibernate/jpox. So
therefore it is safe to say that Teneo should work for the same databases as supported by
hibernate/jpox. If a certain hibernate mapping is not working on a certain database (while it works
on mysql) then this is more a hibernate issue then a Teneo issue (imo).
However, having said this. In general if you encounter an issue with a specific database then I am
willing to spend time/adapt Teneo to check/solve it (provided I do not need to add db specific code).
So for your specific issue, if you would like hsqldb support for this then please analyse the cause
of the issue (what is the difference you see between hsqldb and mysql, which db constraint is
violated, etc.), and preferably a solution (which mapping works).
gr. Martin
Michael Kanaley wrote:
> Is there an official set of database vendors/versions that Teneo attempts to
> integrate with?
> I know the list is huge so narrowing it down is certainly reasonable.
> We have found problems with Teneo's integration with Hibernate/HSQL DB
> (bugzilla number 178471) that don't show up on Hibernate/MySQL.
> Do we file a bugzilla for this or should we stick to the db vendors/versions
> that are tested?
> -mike
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo]Supported DB vendor/versions [message #603814 is a reply to message #76338] |
gr. Martin
> integrate with?
> that are tested?
> -mike
The Netherlands
FUDForum. Page generated in 0.03190 seconds
