Home » Eclipse Projects » DTP » stored procedure debugging
stored procedure debugging [message #718117] Tue, 23 August 2011 10:06 Go to next message
Sunny Xu is currently offline Sunny XuFriend
hi,
when i use "database debug", it prompts "this mode is not supported yet!"(helios with database tools 1.9).
any schedule with this function?
i knew oracle has a dbms_debug package, but recently i found that some ides
are using jdwp to implement the debug progress.
how can i do that?
thanks a lot.
Sunny
Re: stored procedure debugging [message #733503 is a reply to message #718117] Tue, 04 October 2011 21:53 Go to previous messageGo to next message
Brian Payton is currently offline Brian PaytonFriend
As far as I know, stored procedure debugging was fully implemented only
for Sybase databases. (The code was contributed by Sybase.) It would
be great if somebody with Oracle expertise and some extra time would do
the work needed to enable stored proc debugging for Oracle.
On 8/23/2011 3:06 AM, Sunny Xu wrote:
> hi,
> how can i do that?
> thanks a lot.
> Sunny
Re: stored procedure debugging [message #1728211 is a reply to message #733503] Thu, 31 March 2016 23:01 Go to previous message
Shwetha Venkatesh is currently offline Shwetha VenkateshFriend
Any one who is implemented debugger for Postgres in Eclipse using DTP???
Any pointers on how to start and which module to look into??
Previous Topic:Cannot view postgresql tables
Next Topic:Data Soruce Explorer, No tables, only Schemas visible
Current Time: Fri Feb 26 00:33:31 GMT 2021
Powered by FUDForum. Page generated in 0.01989 seconds
