Re: TODO: The default literal value "EnumMemberA" is invalid [message #76341 is a reply to message #76307] |
Thu, 13 November 2008 17:59 |
Ed Merks Messages: 33137 Registered: July 2009 |
John,
I see, because it's a union without a common base type. Please open a
bugzilla with this example and I'll look into fixing it.
John T.E. Timm wrote:
> I am having a problem with an attribute that is defined as fixed with
> a simple type enumeration member:
> <xs:attribute name="attr1" type="SimpleTypeA" fixed="EnumMemberA"/>
> is generating:
> protected static final Object ATTR1_EDEFAULT; // TODO The default
> value literal "EnumMemberA" is not valid.
> protected Object attr1 = ATTR1_EDEFAULT;
> The causes a compilation error for unassigned static final field. I
> believe that in the past (perhaps version EMF 2.2) it would have
> generated this:
> protected static final Object ATTR1_EDEFAULT =
> ExampleFactory.eINSTANCE.createFromString(ExamplePackage.eIN STANCE.getSimpleTypeA(),
> "EnumMemberA");
> The full schema that was used for this example is:
> <?xml version="1.0"?>
> <xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
> targetNamespace="http://example.org"
> xmlns="http://example.org">
> <xs:simpleType name="SimpleBaseType">
> <xs:restriction base="xs:token">
> <xs:pattern value="[^\s]+"/>
> </xs:restriction>
> </xs:simpleType>
> <xs:simpleType name="SimpleTypeA">
> <xs:union memberTypes="SimpleTypeB SimpleTypeC"/>
> </xs:simpleType>
> <xs:simpleType name="SimpleTypeB">
> <xs:restriction base="SimpleBaseType"/>
> </xs:simpleType>
> <xs:simpleType name="SimpleTypeC">
> <xs:restriction base="SimpleBaseType">
> <xs:enumeration value="EnumMemberA"/>
> <xs:enumeration value="EnumMemberB"/>
> <xs:enumeration value="EnumMemberC"/>
> </xs:restriction>
> </xs:simpleType>
> <xs:complexType name="ComplexTypeA">
> <xs:sequence>
> <xs:element name="element1" type="xs:string"/>
> <xs:element name="element2" type="xs:string"/>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> I am running Eclipse Ganymede 3.4.1 with EMF 2.4.1 on Windows XP SP3.
> John
Ed Merks
Re: TODO: The default literal value "EnumMemberA" is invalid [message #603475 is a reply to message #76307] |
John,
> is generating:
> generated this:
> "EnumMemberA");
> </xs:restriction>
> </xs:simpleType>
> </xs:simpleType>
> </xs:simpleType>
> </xs:restriction>
> </xs:simpleType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:schema>
> John
Ed Merks
FUDForum. Page generated in 0.03180 seconds
