Android Emulator in Eclipse [message #717965] |
Mon, 22 August 2011 20:34  |
Hello Developers,
I am very new to the Development of Apps for Android. It's been a few yrs since i have even seen any code . Some info is coming back to me, along with alot of new again stuff. Any how this is the problem. I have dwnld and installed all the software for Eclipse 32bit,64bit, and all the jdk's needed to run. After many hours of reading and following directions lol the best i can, i have tried to do the 1st exercise The Infamous "Hello World" lol . Now i have done this exercise following the instructions from Two different Sources, and i end up with the Same Error message. Here is the error Message...
[2011-08-22 15:26:34 - GoodbyeAndroid] Android Launch!
[2011-08-22 15:26:34 - GoodbyeAndroid] adb is running normally.
[2011-08-22 15:26:34 - GoodbyeAndroid] Performing com.example.goodbyeandroid.GoodbyeAndroid activity launch
[2011-08-22 15:26:34 - GoodbyeAndroid] Automatic Target Mode: launching new emulator with compatible AVD 'Capns_avd'
[2011-08-22 15:26:34 - GoodbyeAndroid] Launching a new emulator with Virtual Device 'Capns_avd'
[2011-08-22 15:26:34 - Emulator] invalid command-line parameter: App.
[2011-08-22 15:26:34 - Emulator] Hint: use '@foo' to launch a virtual device named 'foo'.
[2011-08-22 15:26:34 - Emulator] please use -help for more information
Its the last few lines ...the emulator error. What am i doing wrong?
Re: Android Emulator in Eclipse [message #717971 is a reply to message #717966] |
Mon, 22 August 2011 21:26   |
Thank you Torsten, I did start there and i followed their instructions. And after doing everything i end up with the Emulator error. is there a group forum in here that covers stuff like this? if so plz point me and im sorry if i wrote in the group
Re: Android Emulator in Eclipse [message #719371 is a reply to message #718802] |
Fri, 26 August 2011 20:43  |
Thank you Torsten
The Emulator Stuff is for creating Apps in Eclipse,for Android Platforms. But i did figure out what was wrong. Had to install Eclipse on to C and all Java jre7 had to be on C...Not C:\Prog~ just C:\ and the Android ADT. So now it works.
Thank you
FUDForum. Page generated in 0.01696 seconds
