Re: Failed when Calling crosstab Report [message #717902 is a reply to message #717772] |
Mon, 22 August 2011 16:42 |
What url did you use? do you have the report in the WebViewerExample
directory?
Jason
On 8/22/2011 5:39 AM, cbr125x wrote:
> i made Crosstab report follow the "CrosstabSampleRevenue.rptdesign" in Wiki.eclipse.org,
> after that, i copied the file with *.rptdesign into my tomcat path folder.
> i run the tomcat server, when i called the crosstab report, it shows nothing. only frameset. did i do something wrong here?
> here i attach the report. thx
Re: Failed when Calling crosstab Report [message #718199 is a reply to message #718057] |
Tue, 23 August 2011 14:02 |
What version of the viewer did you deploy? And how did you deploy it?
If this is just a sample report it should run fine.
Jason
On 8/23/2011 2:43 AM, cbr125x wrote:
> when i run the report with url
> "http://localhost:8080/BIRT-demo/run?__report=crossTab2.rptdesign"
> Error occurs like below : The following items have errors:
> ReportDesign (id = 1): + An exception occurred during processing. Please
> see the following message for details:
> exception.error
> Error happens when create hierarchy:ProductLine.NewTabularHierarchy.
> Cannot execute the statement.
> org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does
> not return a ResultSet object.
> SQL error #1:Feature not implemented.
> java.sql.SQLException: Feature not implemented.
> java.sql.SQLException: Feature not implemented. (Element ID:1)
> exception.error ( 1 time(s) )
> detail : org.eclipse.birt.report.engine.api.EngineException: An
> exception occurred during processing. Please see the following message
> for details:
> exception.error
> at
> org.eclipse.birt.report.engine.executor.ExecutorManager$ExecutorContext.executeQuery(ExecutorManager.java:451)
> at
> org.eclipse.birt.report.item.crosstab.core.re.executor.BaseCrosstabExecutor.executeQuery(BaseCrosstabExecutor.java:122)
> at
> org.eclipse.birt.report.item.crosstab.core.re.executor.CrosstabReportItemExecutor.execute(CrosstabReportItemExecutor.java:102)
> at
> org.eclipse.birt.report.engine.executor.ExtendedItemExecutor.execute(ExtendedItemExecutor.java:62)
> at
> org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
> at
> org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
> at
> org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
> at
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:180)
> at
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
> at
> org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:929)
> at
> org.eclipse.birt.report.service.BirtViewerReportService.runAndRenderReport(BirtViewerReportService.java:973)
> at
> org.eclipse.birt.report.service.actionhandler.BirtGetPageAllActionHandler.__execute(BirtGetPageAllActionHandler.java:131)
> at
> org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
> at
> org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
> at
> org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
> at
> org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPageAll(BirtDocumentProcessor.java:183)
> at
> org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
> at
> org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
> at
> org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
> at
> org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
> at
> org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
> at
> org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
> at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
> at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
> at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
> at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
> at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
> at
> org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
> at
> org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
> at
> org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
> at
> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
> at
> org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
> at
> org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerFilter.java:68)
> at
> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
> at
> at
> org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
> at
> org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
> at
> org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
> at
> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
> at
> org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
> at
> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
> at
> org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:852)
> at
> org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
> at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
> at java.lang.Thread.run(Unknown Source)
> Caused by: org.eclipse.birt.report.data.adapter.api.AdapterException: An
> for details:
> exception.error
> at
> org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:636)
> at
> org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteCube(DteDataEngine.java:222)
> at
> org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:270)
> at
> org.eclipse.birt.report.engine.executor.ExecutorManager$ExecutorContext.executeQuery(ExecutorManager.java:441)
> ... 57 more
> Caused by: org.eclipse.birt.data.engine.core.DataException: exception.error
> at
> org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.materializeCube(DataRequestSessionImpl.java:762)
> at
> org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:625)
> ... 60 more
> at
> org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.populateDimension(DataRequestSessionImpl.java:1371)
> at
> org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.populateDimensions(DataRequestSessionImpl.java:1220)
> at
> org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.createCube(DataRequestSessionImpl.java:805)
> at
> org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.materializeCube(DataRequestSessionImpl.java:747)
> ... 61 more
> at
> org.eclipse.birt.report.data.adapter.impl.DataSetIterator.executeQuery(DataSetIterator.java:88)
> at
> org.eclipse.birt.report.data.adapter.impl.DataSetIterator.<init>(DataSetIterator.java:121)
> at
> org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.populateDimension(DataRequestSessionImpl.java:1348)
> ... 64 more
> Caused by: org.eclipse.birt.data.engine.odaconsumer.OdaDataException:
> at
> org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.newException(ExceptionHandler.java:52)
> at
> org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:108)
> at
> org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:84)
> at
> org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.execute(PreparedStatement.java:586)
> at
> org.eclipse.birt.data.engine.executor.DataSourceQuery.execute(DataSourceQuery.java:927)
> at
> org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQueryExecutor.executeOdiQuery(PreparedOdaDSQuery.java:441)
> at
> org.eclipse.birt.data.engine.impl.QueryExecutor.execute(QueryExecutor.java:1495)
> at
> org.eclipse.birt.data.engine.impl.ServiceForQueryResults.executeQuery(ServiceForQueryResults.java:232)
> at
> org.eclipse.birt.data.engine.impl.QueryResults.getResultIterator(QueryResults.java:173)
> at
> org.eclipse.birt.report.data.adapter.impl.DataSetIterator.executeQuery(DataSetIterator.java:84)
> ... 66 more
> Caused by: org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL
> statement does not return a ResultSet object.
> at
> org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery(Statement.java:464)
> at
> org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.doExecuteQuery(OdaQuery.java:469)
> at
> org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.executeQuery(OdaQuery.java:433)
> at
> org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.execute(PreparedStatement.java:575)
> ... 72 more
> Caused by: java.sql.SQLException: Feature not implemented.
> at
> org.apache.derby.impl.jdbc.SQLExceptionFactory40.getSQLException(Unknown
> Source)
> at org.apache.derby.impl.jdbc.Util.generateCsSQLException(Unknown Source)
> at
> org.apache.derby.impl.jdbc.TransactionResourceImpl.wrapInSQLException(Unknown
> Source)
> at
> org.apache.derby.impl.jdbc.TransactionResourceImpl.handleException(Unknown
> Source)
> at org.apache.derby.impl.jdbc.EmbedConnection.handleException(Unknown
> Source)
> at org.apache.derby.impl.jdbc.ConnectionChild.handleException(Unknown
> Source)
> at org.apache.derby.impl.jdbc.EmbedStatement.executeStatement(Unknown
> Source)
> at
> org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeStatement(Unknown
> Source)
> at
> org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeQuery(Unknown
> Source)
> at
> org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery(Statement.java:460)
> ... 75 more
> at
> org.apache.derby.impl.jdbc.SQLExceptionFactory.getSQLException(Unknown
> Source)
> at
> org.apache.derby.impl.jdbc.SQLExceptionFactory40.wrapArgsForTransportAcrossDRDA(Unknown
> Source)
> ... 85 more
> Caused by: ERROR XSAI3: Feature not implemented.
> at org.apache.derby.iapi.error.StandardException.newException(Unknown
> Source)
> at org.apache.derby.impl.store.raw.log.ReadOnly.checkVersion(Unknown
> Source)
> at org.apache.derby.impl.store.raw.RawStore.checkVersion(Unknown Source)
> at
> org.apache.derby.impl.store.access.RAMTransaction.checkVersion(Unknown
> Source)
> at
> org.apache.derby.impl.store.access.heap.HeapConglomerateFactory.createConglomerate(Unknown
> Source)
> at
> org.apache.derby.impl.store.access.RAMTransaction.createConglomerate(Unknown
> Source)
> at org.apache.derby.iapi.store.access.DiskHashtable.<init>(Unknown Source)
> at
> org.apache.derby.iapi.store.access.BackingStoreHashtable.spillToDisk(Unknown
> Source)
> at
> org.apache.derby.iapi.store.access.BackingStoreHashtable.add_row_to_hash_table(Unknown
> Source)
> at
> org.apache.derby.iapi.store.access.BackingStoreHashtable.putRow(Unknown
> Source)
> at
> org.apache.derby.impl.store.access.conglomerate.GenericScanController.fetchRows(Unknown
> Source)
> at
> org.apache.derby.impl.store.access.conglomerate.GenericScanController.fetchSet(Unknown
> Source)
> at
> org.apache.derby.impl.store.access.BackingStoreHashTableFromScan.<init>(Unknown
> Source)
> at
> org.apache.derby.impl.store.access.RAMTransaction.createBackingStoreHashtableFromScan(Unknown
> Source)
> at org.apache.derby.impl.sql.execute.HashScanResultSet.openCore(Unknown
> Source)
> at org.apache.derby.impl.sql.execute.JoinResultSet.openRight(Unknown
> Source)
> at org.apache.derby.impl.sql.execute.JoinResultSet.openCore(Unknown Source)
> at
> org.apache.derby.impl.sql.execute.ProjectRestrictResultSet.openCore(Unknown
> Source)
> at
> org.apache.derby.impl.sql.execute.BasicNoPutResultSetImpl.open(Unknown
> Source)
> at
> org.apache.derby.impl.sql.GenericPreparedStatement.executeStmt(Unknown
> Source)
> at org.apache.derby.impl.sql.GenericPreparedStatement.execute(Unknown
> Source)
> ... 79 more
Re: Failed when Calling crosstab Report [message #718516 is a reply to message #718325] |
Wed, 24 August 2011 15:06 |
That should be fine as long as the runtime is same or higher version.
The cube is built in memory and is not exported. Can you try the
attached report in your 3.7 runtime?
Jason
On 8/23/2011 9:40 PM, cbr125x wrote:
> I use eclipse Helios 2.6.1 to develop the report.
> for the viewer i use BIRT 3.7 Runtime.
> is there a problem with that?
> and also i want to ask, is there something wrong with the cube? is the
> cube must be exported in the "Tomcat Install/webapps/BIRT_viewer" ?
> Thx
Re: Failed when Calling crosstab Report [message #718679 is a reply to message #718516] |
Thu, 25 August 2011 03:26 |
cbr125x Messages: 34 Registered: July 2011 |
Member |
Hi Jason,
The attached report viewed successfully in my 3.7 runtime.
so is there something wrong with my report that i attached?
Thanks for your reply
Jason Weathersby wrote on Wed, 24 August 2011 11:06That should be fine as long as the runtime is same or higher version.
Jason
[Updated on: Thu, 25 August 2011 03:26] Report message to a moderator
Re: Failed when Calling crosstab Report [message #718918 is a reply to message #718679] |
Thu, 25 August 2011 15:23 |
I was able to reproduce your issue. It appears there is a bug in the
3.7 runtime with the sample derby database. If you create a dataset
with the following sql:
select *
from
CLASSICMODELS.ORDERS,
CLASSICMODELS.CUSTOMERS,
CLASSICMODELS.ORDERDETAILS,
CLASSICMODELS.PRODUCTS
where
CLASSICMODELS.ORDERS.ORDERNUMBER=CLASSICMODELS.ORDERDETAILS.ORDERNUMBER
and
CLASSICMODELS.ORDERDETAILS.PRODUCTCODE=CLASSICMODELS.PRODUCTS.PRODUCTCODE
and
CLASSICMODELS.CUSTOMERS.CUSTOMERNUMBER=CLASSICMODELS.ORDERS.CUSTOMERNUMBER
and
CLASSICMODELS.ORDERS.STATUS = 'Shipped'
And just add a table using the dataset it will fail in the 3.7 runtime.
Can you open a bugzilla entry for this? BTW it works in the 3.7 designer.
Jason
On 8/24/2011 11:26 PM, cbr125x wrote:
> Hi Jason, The attached file viewed successfully in my 3.7 runtime. so is
>> Jason
FUDForum. Page generated in 0.03398 seconds
