Home » Modeling » Graphiti » Capture zone of anchors, setReferencedGraphicsAlgorithm
Capture zone of anchors, setReferencedGraphicsAlgorithm [message #717189] Fri, 19 August 2011 14:47 Go to next message
Hernan Gonzalez is currently offline Hernan GonzalezFriend
I turned to BoxRelativeAnchor (FixPointAnchor seemed too buggy), I'm having doubts regarding the "capture zone" (don't know if if this is the right term) of an anchor, and the role of the associated GA.
I tried to implement this hierarchy:
(BTW: you can't upload images to this forum, no?)
http://img217.imageshack.us/img217/6245/graphiti2.png
It almost worked as expected. Except that the anchor only "captures" the mouse pointer (i.e., it turns on to accept connection start) in a very tiny spot (not even its little GA rectangle, it seems just a single pixel position), practically impossible to find.
Then I saw that the tutorial calls a setReferencedGraphicsAlgorithm() method, but it doesnt explain what for ("anchor references visible rectangle instead of invisible rectangle" - why?), and the Javadoc of the method says nothing.
I tried to set its referencedGraphicsAlgorithm to the connRect (green rectangle), but no difference. I tried to set it to the big roundedRect (red), but it throws an exception: "ga and referenceGa must not be null, and ga must be a child of referenceGA".
[Updated on: Fri, 19 August 2011 14:48]
Report message to a moderator
Re: Capture zone of anchors, setReferencedGraphicsAlgorithm [message #719892 is a reply to message #717189] Mon, 29 August 2011 10:36 Go to previous messageGo to next message
Michael Wenz is currently offline Michael WenzFriend
In the tuturial you have an outer invisible rectangle that contains both the
shape of the class itself and the connection point (the circle that is drawn
on top of the border but overlaps to the outside of the shape. In order to
enable that the outer invisible rectangle has been created.
Unfortunatly this connection point is not used, otherwise it would probably
be your exact usecase.
In case the connection is really only possible to that one pixel please open
a Bugzilla so we can track this.
Michael
"Hernan" schrieb im Newsbeitrag news:j2lsd5$rb$1@news.eclipse.org...
http://help.eclipse.org/indigo/index.jsp?topic=%2Forg.eclipse.graphiti.doc%2Fjavadoc%2Forg%2Feclipse%2Fgraphiti%2Fmm%2Fpictograms%2FAnchor.html.
Re: Capture zone of anchors, setReferencedGraphicsAlgorithm [message #719953 is a reply to message #719892] Mon, 29 August 2011 14:50 Go to previous message
Michael Wenz wrote on Mon, 29 August 2011 07:36
Thanks, Michael. But I'm not confortable opening issues when I'm not sure about the expected behaviours. In particular, I still don't have the slightest idea about the "referencedGraphicAlgorithm" role, and how it's supposed to influence the Anchor behaviour. Does the referencedGA, or the GA, (or none) define the capture zone of the anchor?
Previous Topic:How to make a shape Unselectable
Next Topic:Patterns - DeleteFeature hasDone problem
Current Time: Mon Jan 25 19:35:30 GMT 2021
Powered by FUDForum. Page generated in 0.02223 seconds
