Home » Modeling » Graphiti » Problems with respect to printers: Slow performance
Problems with respect to printers: Slow performance [message #716807] |
Thu, 18 August 2011 14:03  |
Ivar Refsdal Messages: 24 Registered: May 2011 |
Hello everybody!
First off: Thanks to the developers for a absolutely very interesting
project. I'm quite thrilled about it.
However, I ran into some small problems.
When selecting between the canvas and nodes/shapes, the performance
was very slow.
Two or three times the following exception occurred:
> java.lang.RuntimeException: WARNING: Prevented recursive attempt to activate part org.eclipse.ui.navigator.ProjectExplorer while still in the middle of activating part org.eclipse.ui.views.ProblemView
The full stack trace is available here: http://pastebin.com/dumpGvE7
Anyhow, the problem turned out to be the following:
> at org.eclipse.swt.widgets.Display.eventProc(Display.java:1238)
> at org.eclipse.swt.internal.gtk.OS._gtk_enumerate_printers(Native Method)
> at org.eclipse.swt.internal.gtk.OS.gtk_enumerate_printers(OS.java:9091)
> at org.eclipse.swt.printing.Printer.getPrinterList(Printer.java:91)
> at org.eclipse.gef.ui.actions.PrintAction.calculateEnabled(PrintAction.java:45)
> at org.eclipse.graphiti.ui.internal.action.PrintGraphicalViewerAction.calculateEnabled(PrintGraphicalViewerAction.java:98)
I suppose the real problem lies within SWT somewhere or this particular
printer setup, but calculateEnabled() gets called very often, for
example every time when you select the canvas or a node, so caching this
would effectively fix the problem.
With making calculateEnabled() return false, the slow performance
disappeared and everything ran very smooth.
Note: There's quite a few printers available (20-30) at this uni, so the
setup is somewhat special. If one chooses "print" from Eclipse,
the dialog where one chooses the printer is also very slow,
but as far as I know this hasn't affected any of the plugins notably,
and also it doesn't crash.
Also an exception occurs if one chooses:
"File" -> "Print" -> "Change printer" -> "Cancel"
See stacktrace here: http://pastebin.com/xjYhm9ep
Should I file a bug report for this or something similar?
Ivar Refsdal
Re: Problems with respect to printers: Slow performance [message #717082 is a reply to message #716807] |
Fri, 19 August 2011 08:50   |
Michael Wenz Messages: 1924 Registered: July 2009 Location: Walldorf, Germany |
Ivar,
thanks for pointing out! In Windows this doesn't seen to be an issue, but
other OS seem to behave differently.
Please open a Bugzilla to track this. What is the OS you are working on?
Michael
"Ivar Refsdal" schrieb im Newsbeitrag news:j2j5f6$8i0$1@news.eclipse.org...
Hello everybody!
was very slow.
> at
> at
Ivar Refsdal
Re: Problems with respect to printers: Slow performance [message #717870 is a reply to message #717082] |
Mon, 22 August 2011 15:06  |
Hi Michael,
thanks for you reply!
A bug report has been submitted:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=355401
The OS is:
> $ cat /proc/version
> Linux version 2.6.18-274.el5 (mockbuild@x86-002.build.bos.redhat.com) (gcc
> version 4.1.2 20080704 (Red Hat 4.1.2-51)) #1 SMP Fri Jul 8 17:36:59 EDT 2011
Best,
Ivar
Michael Wenz wrote, on 08/19/2011 10:50 AM:
> Ivar,
> but other OS seem to behave differently.
> Michael
> Hello everybody!
> was very slow.
>> at
>> at
> Best regards,
> Ivar Refsdal
Current Time: Fri Jan 22 01:42:27 GMT 2021
Powered by FUDForum. Page generated in 0.01648 seconds
