Home » Eclipse Projects » GEF » Properties view
Properties view [message #716743] Thu, 18 August 2011 09:47 Go to next message
Rudolf R is currently offline Rudolf RFriend
I am quite new to GEF and wondered if there is a simple way of getting the properties view to get integrated when a figure is selected (everything is based on EMF-Models)
I searched for examples on the web, but did not find anything useful. I've already added the extension to add the property sections and the corresponding models.
Is this easily possible or do any helpful tutorials exist on the web for accessing the property view? Otherwise I would have to mess around with listeneres...
Rudolf
Re: Properties view [message #716779 is a reply to message #716743] Thu, 18 August 2011 12:52 Go to previous messageGo to next message
Originally posted by: Tomas Micko
Try to look at this IBM Redbook
(http://www.redbooks.ibm.com/abstracts/sg246302.html). It is little
outdated but if you look closely you will get the basic idea. If you
click the Additional Material link on that page you can download some
examples.
Rudolf R wrote:
> listeneres...
> Regards,
> Rudolf
Re: Properties view [message #716899 is a reply to message #716743] Thu, 18 August 2011 17:58 Go to previous messageGo to next message
Alexander Nyssen is currently offline Alexander NyssenFriend
Adopting to the PropertySheetView within Eclipse is generally done via the IAdaptable mechanism. As GEF's GraphicalEditor already provides an IPropertySheetPage implementation within its getAdapter() method, all you basically have to do is to overwrite getAdapter() within your EditParts to return the EMF IPropertySource implementation for your model objects.
Re: Properties view [message #731812 is a reply to message #716743] Mon, 03 October 2011 07:28 Go to previous message
Arieh Bibliowicz is currently offline Arieh BibliowiczFriend
The solution is quite easy to implement but a bit tricky. I show this in
my tutorial at http://www.vainolo.com/2011/08/22/creating-an-opm-gef-
editor-part-16-displaying-emf-properties-in-a-gef-editor/
Vainolo
Previous Topic:[zest] initial layout locations at origin
Next Topic:Layout Role for connection childs
Current Time: Sun Dec 05 11:17:54 GMT 2021
Powered by FUDForum. Page generated in 0.02291 seconds
