Home » Modeling » TMF (Xtext) » MWE2 workflow generated import: "import org.eclipse.xtext.parsetree.*"
MWE2 workflow generated import: "import org.eclipse.xtext.parsetree.*" [message #716169] Tue, 16 August 2011 15:27 Go to next message
sungam  is currently offline sungam Friend
Running MWE2 workflow from Indigo generates the following import in the class org.xtext.example.mydsl.ui.contentassist.antlr.internal.InternalMyDslParser:
import org.eclipse.xtext.parsetree.*;
Compiling from maven2 throws error:
package org.eclipse.xtext.parsetree does not exist
Did anyone encounter similar problem?
Re: MWE2 workflow generated import: "import org.eclipse.xtext.parsetree.*" [message #716193 is a reply to message #716169] Tue, 16 August 2011 16:23 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
maybe you have still Xtext 1.0.x stuff on the path?
~Christian
Twitter : @chrdietrich
Re: MWE2 workflow generated import: "import org.eclipse.xtext.parsetree.*" [message #716202 is a reply to message #716193] Tue, 16 August 2011 16:32 Go to previous messageGo to next message
Don't think that is possible.
Because it is a fresh Indigo with xtext2.0 install and I have used the wizard to create a sample xtext project out-of-the-box.
Haven't made any changes at all.
Re: MWE2 workflow generated import: "import org.eclipse.xtext.parsetree.*" [message #716205 is a reply to message #716202] Tue, 16 August 2011 16:36 Go to previous messageGo to next message
Strange, that should work Wink
~Christian
Re: MWE2 workflow generated import: "import org.eclipse.xtext.parsetree.*" [message #716238 is a reply to message #716169] Tue, 16 August 2011 17:50 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
see here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=352409
Fixed for SR1 which was released some days ago.
Sebastian
> class
Re: MWE2 workflow generated import: "import org.eclipse.xtext.parsetree.*" [message #716262 is a reply to message #716238] Tue, 16 August 2011 19:59 Go to previous message
Ok. Thank you.
I am trying to use the artifacts from the fornax-repo
(http://fornax-platform.org/nexus/content/groups/public/) to execute my build.
Any chances this release could be synced up to that repo?
Previous Topic:prefix on Qualified Name
Next Topic:XBase operators marked as error in DomainModel example project
Current Time: Tue Apr 16 18:28:06 GMT 2024
Powered by FUDForum. Page generated in 0.86500 seconds
