Adding Connection as Element to its Parent Element to reflect in XML [message #715316] |
Sat, 13 August 2011 05:40  |
Myself created Connection between two nodes. Its working fine, but when I try to add the Connection to its parent list to reflect the connection tag in XML, it throws the following Error in diagram editor but works in model editor...
java.lang.IndexOutOfBoundsException: Index does not exist
at org.eclipse.draw2d.Figure.add(Figure.java:139)
at org.eclipse.draw2d.Figure.add(Figure.java:184)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.addChildVisual(AbstractGraphicalEditPart.java:209)
at org.eclipse.gef.editparts.AbstractEditPart.addChild(AbstractEditPart.java:211)
at org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(AbstractEditPart.java:781)
at com.bpminspire.inspire.bpmn.designer.parts.ProcessPart.notifyChanged(ProcessPart.java:89)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:380)
at org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(EcoreEList.java:255)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:300)
at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:307)
at com.bpminspire.inspire.bpmn.designer.commands.StartCreationCommand.execute(StartCreationCommand.java:80)
at org.eclipse.gef.commands.CommandStack.execute(CommandStack.java:199)
at org.eclipse.gef.tools.AbstractTool.executeCommand(AbstractTool.java:425)
at org.eclipse.gef.tools.AbstractTool.executeCurrentCommand(AbstractTool.java:438)
at org.eclipse.gef.tools.CreationTool.performCreation(CreationTool.java:269)
at org.eclipse.gef.tools.CreationTool.handleButtonUp(CreationTool.java:189)
at org.eclipse.gef.tools.AbstractTool.mouseUp(AbstractTool.java:1200)
at org.eclipse.gef.EditDomain.mouseUp(EditDomain.java:301)
at org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouseReleased(DomainEventDispatcher.java:380)
at org.eclipse.draw2d.LightweightSystem$EventHandler.mouseUp(LightweightSystem.java:548)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:219)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Can any one tell me, what may be the issue is? If i did not add the connection in xml, then its working fine in diagram editor but when i try to open it in Model editor it throws exception that incoming and outgoing do not resolve the have reference, so only i am trying to add in connection it in xml and my concept in the project is to open the diagram in Model editor as well as diagram editor.
Karthik
FUDForum. Page generated in 0.02803 seconds
