Home » Eclipse Projects » Rich Client Platform (RCP) » Could not create view
Could not create view [message #715222] |
Fri, 12 August 2011 19:51 |
Alex Messages: 2 Registered: August 2011 |
Good evening guys and girls,
let's get right into it:
Preface
- I have a custom RCP application built on top of Eclipse.
- I also created a separate plug-in which works just fine while running as Eclipse Application
- The plug-in still works fine when I select the application and add the plug-in in Run Configurations (which means I can see and alter Preferences, as well as I see the the entry for the plug-ins Perspective
- The problem occurs when I select the Perspective, as all three Views fail to be created
- I am using Eclipse 3.7 on a Win7 x64 machine
What I've tried so far
- I double checked the ID's in the Views' .java file, as well es in the Manifest, as well as in the Perspective's class - they are identical (following this topic ID 301875 advice)
- I cleaned up and rebuilt the applications project (as it was advised here topic ID 309379)
- I checked the solution that mentioned missing icons or plugin.xml (as seen here topic ID 515455)
- I also tried the adding Required Plug-ins and validate Plug-ins options
The outcome is still the same. This is the error log, which looks the same for every View (except the class-name of course).
!ENTRY org.eclipse.ui 4 4 2011-08-12 20:55:42.092
!MESSAGE Exception in org.eclipse.ui.internal.PageLayout.addView: org.eclipse.ui.PartInitException: Could not create view: de.hundt.kewo.views.SimilaritesView
!ENTRY org.eclipse.ui 4 4 2011-08-12 20:55:42.128
!STACK 1
at org.eclipse.ui.internal.ViewFactory.createView(ViewFactory.java:158)
at org.eclipse.ui.internal.LayoutHelper.createView(LayoutHelper.java:162)
at org.eclipse.ui.internal.PageLayout.createView(PageLayout.java:554)
at org.eclipse.ui.internal.PageLayout.addView(PageLayout.java:416)
at org.eclipse.ui.internal.PageLayout.addView(PageLayout.java:390)
at de.hundt.kewo.plugin.ui.perspectives.KEWoPerspectiveFactory.createInitialLayout(KEWoPerspectiveFactory.java:26)
at org.eclipse.ui.internal.Perspective.loadPredefinedPersp(Perspective.java:816)
at org.eclipse.ui.internal.Perspective.createPresentation(Perspective.java:270)
at org.eclipse.ui.internal.Perspective.<init>(Perspective.java:156)
at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation.createPerspective(Workbench3xImplementation.java:55)
at org.eclipse.ui.internal.WorkbenchPage.createPerspective(WorkbenchPage.java:1748)
at org.eclipse.ui.internal.WorkbenchPage.busySetPerspective(WorkbenchPage.java:1108)
at org.eclipse.ui.internal.WorkbenchPage.access$16(WorkbenchPage.java:1099)
at org.eclipse.ui.internal.WorkbenchPage$19.run(WorkbenchPage.java:3814)
at org.eclipse.ui.internal.WorkbenchPage.setPerspective(WorkbenchPage.java:3812)
at org.eclipse.ui.handlers.ShowPerspectiveHandler.openPerspective(ShowPerspectiveHandler.java:146)
at org.eclipse.ui.handlers.ShowPerspectiveHandler.openOther(ShowPerspectiveHandler.java:118)
at org.eclipse.ui.handlers.ShowPerspectiveHandler.execute(ShowPerspectiveHandler.java:57)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:178)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:247)
at org.eclipse.ui.actions.PerspectiveMenu.runOther(PerspectiveMenu.java:376)
at org.eclipse.ui.actions.PerspectiveMenu$3.runWithEvent(PerspectiveMenu.java:130)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at de.dfki.mycbr.gui.Application.start(Application.java:41)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
!SUBENTRY 1 org.eclipse.ui 4 0 2011-08-12 20:55:42.149
!MESSAGE Could not create view: de.hundt.kewo.views.SimilaritesView
Here are both the perspective code from the Application and the Plug-in. The latter one doesn't work.
Application:
public void createInitialLayout(IPageLayout layout) {
PlatformUI.getWorkbench().getActiveWorkbenchWindow().addPerspectiveListener(new PerspectiveListener());
layout.addView(PROJECT_LIST_VIEW_ID, IPageLayout.LEFT, 0.3f, layout.getEditorArea());
IViewLayout conceptListViewLayout = layout.getViewLayout(PROJECT_LIST_VIEW_ID);
conceptListViewLayout.setCloseable(false);
layout.addView(FUNCTION_LIST_VIEW_ID, IPageLayout.BOTTOM, 0.6f, PROJECT_LIST_VIEW_ID);
IViewLayout attributeListViewLayout = layout.getViewLayout(FUNCTION_LIST_VIEW_ID);
attributeListViewLayout.setCloseable(false);
layout.addPerspectiveShortcut(ID);
layout.addPerspectiveShortcut(CaseBasePerspective.ID);
Plugin:
layout.addView(this.FORUM_VIEW_ID, IPageLayout.LEFT, 0.50f,
layout.addView(this.TAXONOMY_VIEW_ID, IPageLayout.RIGHT, 0.50f,
layout.addView(this.SIMILARITY_VIEW_ID, IPageLayout.BOTTOM, 0.3f,
edit: Debug at least showed the point where the exception is thrown. secondaryId and desc where null.
public IViewReference createView(String id, String secondaryId)
throws PartInitException {
IViewDescriptor desc = viewReg.find(id);
// ensure that the view id is valid
if (desc == null) {
throw new PartInitException(NLS.bind(WorkbenchMessages.ViewFactory_couldNotCreate, id ));
Any hunch what I did wrong here is much appreciated.
Alex
PS: replaced the the not-allowed links with just the topics ID to show that I did research here, yet didn't come to any conclusion
[Updated on: Sat, 13 August 2011 09:44] Report message to a moderator
(no subject) [message #715544 is a reply to message #715222] |
Sun, 14 August 2011 12:31 |
Wim Jongman Messages: 423 Registered: July 2009 |
Hi Alexander,
Can you open the views without going in the perspective?
window/show view/etc..
Wim
> Preface
Eclipse Application
to be created
topic ID 309379)
> !STACK 1
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> Application:
> Plugin:
> @Override
> Cheers,
> Alex
Re: Could not create view [message #716866 is a reply to message #715544] |
Thu, 18 August 2011 15:41 |
Also not possible with CTRL+3?
> Hi Alexander,
> Regards,
> Wim
>> Preface
> Eclipse Application
> to be created
> topic ID 309379)
>> !STACK 1
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> Application:
>> Plugin:
>> @Override
>> Cheers,
>> Alex
that
Current Time: Thu Apr 25 17:11:53 GMT 2024
Powered by FUDForum. Page generated in 0.03164 seconds
