Re: PDT [message #718628 is a reply to message #716769] |
Wed, 24 August 2011 21:42 |
Anttix Messages: 1 Registered: August 2011 |
Junior Member |
Thank You for the tip Toshihiro.
I had a similar problem when m2eclipse plugin started throwing errors in POM editor after I installed wtp. I removed the following conflicting files from my ~/.eclipse/*/plugins :
javax.xml_1.3.4.v201005080400.jar
org.apache.xerces_2.9.0.v201005080400.jar
org.apache.xml.resolver_1.2.0.v201005080400.jar
org.apache.xml.serializer_2.7.1.v201005080400.jar
And it works now!
Running on Fedora 15 with eclipse-platform-3.6.2-5.fc15.x86_64 and eclipse-dtp-1.8.2-1.fc15.noarch
[Updated on: Wed, 24 August 2011 21:49] Report message to a moderator
Re: PDT [message #894203 is a reply to message #716627] |
Sat, 07 July 2012 15:16 |
prbhas raju Messages: 8 Registered: July 2012 |
Junior Member |
@Bugzy Magro
Hi, I was tried through "Install new Software" to install a Plugin Tool for UML(eUML2 provided by soyatec.com). But it shows Unable to connect the site connection refused. Even i tried to instll from downloads.eclipse.com but getting same error. How do install new plugins to Eclipse Helios in Fedora15.
Thanks in Advance.
[Updated on: Sat, 07 July 2012 15:16] Report message to a moderator
FUDForum. Page generated in 0.04331 seconds
