Home » Eclipse Projects » Target Management » Extend System, SubSystem in the UI?
Extend System, SubSystem in the UI? [message #715115] Fri, 12 August 2011 12:09 Go to next message
Ralph P is currently offline Ralph PFriend
Member
Hello there!
Is there a way to extend/customize my System and Subsystem types in the Remote Systems View? Basically I want to add custom actions to their context menus, just like I did with my model objects:
MyModelClassAdapter extends AbstractSystemViewAdapter implements ISystemRemoteElementAdapter...
Thanks in advance!
Ralph
(no subject) [message #715136 is a reply to message #715115] Fri, 12 August 2011 13:35 Go to previous messageGo to next message
David McKnight is currently offline David McKnightFriend
Hi Ralph,
If all you want to do is add custom actions to the context menus, you don't
need to programmatically alter the RSE view adapters. You could just use
the standard Eclipse popupMenus extension point. The following is an
example from the org.eclipse.rse.examples.tutorial plugin:
<extension point="org.eclipse.ui.popupMenus">
<objectContribution
objectClass="org.eclipse.rse.subsystems.files.core.subsystems.IRemoteFile"
nameFilter="*.jar"
id="actions.jar">
<action
label="Show contents"
tooltip="list contents of this file"
class="samples.ui.actions.ShowJarContents"
menubarPath="additions"
enablesFor="1"
id="actions.jar.show">
</action>
</objectContribution>
</extension>
The objectClass attribute indicates which RSE object to contribute the menu
item to. For example, if you wanted to contribute something to a host
object, you'd use:
objectClass="org.eclipse.rse.core.model.IHost"
I hope this helps,
Dave
"r.pakosch" <forums-noreply@eclipse.org> wrote in message
news:j234h2$oo1$1@news.eclipse.org...
> Hello there!
> Thanks in advance!
> Ralph
Re: (no subject) [message #716086 is a reply to message #715136] Tue, 16 August 2011 12:38 Go to previous message
Member
Hi Dave,
thanks, I think this will do the job! I will try that out!
Best regards
Ralph
Previous Topic:How to programmatically refresh a file subsystem view?
Next Topic:Copy/paste in terminal for Mac OS X
Current Time: Thu Dec 08 07:32:16 GMT 2022
Powered by FUDForum. Page generated in 0.02409 seconds
