Home » Eclipse Projects » BIRT » what is the meaning of "can shrink" for table element?
what is the meaning of "can shrink" for table element? [message #714710] Thu, 11 August 2011 10:28 Go to next message
Missing name Mising name is currently offline Missing name Mising nameFriend
Member
I found the table element has a checkbox called "can shrink", what is its usage?
my birt designer version is 2.2.1
(no subject) [message #714875 is a reply to message #714710] Thu, 11 August 2011 15:57 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
This setting if checked will shrink a container to its contents. This
will only work if you do not specify a height or width values for the
container. Run the attached report then select the canshrink checkbox
for the grid and run it again. BTW the report was done in BIRT 2.6.1.
Jason
> its usage?
Re: (no subject) [message #989753 is a reply to message #714875] Fri, 07 December 2012 15:07 Go to previous message
Jan Krakora is currently offline Jan KrakoraFriend
Does it works also in PDF output? When I view the attached report as HTML, it works perfectly. But if I run it as PDF shrink it's ignored.
Previous Topic:[BIRT 2.5.2] Crosstab - Dynamic columns width autofit issues
Next Topic:How to justify the table to center in a BIRT Report
Current Time: Wed Dec 08 04:04:50 GMT 2021
Powered by FUDForum. Page generated in 0.02125 seconds
