Home » Modeling » M2T (model-to-text transformation) » [ACCELEO3] Tab,Tabulator problems([ACCELEO3] Tab,Tabulator problems)
[ACCELEO3] Tab,Tabulator problems [message #714658] Thu, 11 August 2011 08:06 Go to next message
Norman  is currently offline Norman Friend
Hi everyone,
i have a hard Problem. If i make a Tabulator at beginning of codegeneration, everything gets the correct identation. If i generate again, the code moves right with many unwanted tabulators. If i generate again, the code moves more to the right than before. Its annoying.
In 2.6. there was a possibility to insert post(indentTab()). The migration to 3 says its:
<%x.indentTab%> to [x.replaceAll('rn|r|n', '$0t')/]
post(replaceAll('rn|r|n', '$0t')) doesnt work in Acceleo 3.
Can someone help?
Greetings,fnobbi
Re: [ACCELEO3] Tab,Tabulator problems [message #715043 is a reply to message #714658] Fri, 12 August 2011 08:15 Go to previous messageGo to next message
i found my problem. Its because Tabs are generated in Userdefine Code, is it possible to disable that ANY Code is generated in the user define code?
Re: [ACCELEO3] Tab,Tabulator problems [message #715995 is a reply to message #715043] Tue, 16 August 2011 07:38 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent GoubetFriend
Hi Norman,
This is a problem we had with Acceleo 3.0 ... It should be fixed in 3.1. (See also https://bugs.eclipse.org/bugs/show_bug.cgi?id=331978.) Could you update to the new version and confirm whether your use case is fixed now?
Laurent Goubet
Obeo
Re: [ACCELEO3] Tab,Tabulator problems [message #716022 is a reply to message #714658] Tue, 16 August 2011 08:34 Go to previous messageGo to next message
i'll try and give a feedback
Re: [ACCELEO3] Tab,Tabulator problems [message #716443 is a reply to message #714658] Wed, 17 August 2011 12:23 Go to previous message
thanks, the bug is fixed in 3.1
Previous Topic:[Acceleo 3.1] Can't run Acceleo Module
Next Topic:[Xtend] Is there a type name for collections of collections?
Current Time: Mon Mar 08 04:18:46 GMT 2021
Powered by FUDForum. Page generated in 0.01605 seconds
