Home » Archived » B3 » b3 and p2 authentication
b3 and p2 authentication [message #714286] Wed, 10 August 2011 08:32 Go to next message
Johan Ekberg is currently offline Johan EkbergFriend
I've just started using b3 in my project and it seems to fit perfect for my needs.
My problem, though, is when I run my aggregation in a headless build the authentication
against my p2 repos fail.
Therefore I wonder wheter there is any way to inject the authentication information
into a headless installation. Please give me a hint or a link where I can start to
find a solution.
BR
Johan
Re: b3 and p2 authentication [message #714290 is a reply to message #714286] Wed, 10 August 2011 08:44 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
Hi Johan,
What kind of authentication are you using and in what way is the aggregator failing? Do you see a stack trace?
- thomas
On 2011-08-10 10:32, Johan Ekberg wrote:
> find a solution.
> BR
> Johan
Re: b3 and p2 authentication [message #714337 is a reply to message #714290] Wed, 10 August 2011 11:03 Go to previous messageGo to next message
Hi Thomas!
I have a p2 repository that I access with a https URL. This URL is password
protected and I think that this is the problem. The stack trace is as follow:
!ENTRY org.eclipse.b3.util 4 -364274674 2011-08-10 10:05:20.759
!MESSAGE Build failed! Exception was org.eclipse.core.runtime.CoreException: Not all repositories could be loaded (see log for details)
!STACK 1
at org.eclipse.b3.util.ExceptionUtils.fromMessage(ExceptionUtils.java:53)
at org.eclipse.b3.util.ExceptionUtils.fromMessage(ExceptionUtils.java:49)
at org.eclipse.b3.aggregator.engine.Builder.loadAllMappedRepositories(Builder.java:1153)
at org.eclipse.b3.aggregator.engine.Builder.run(Builder.java:1629)
at org.eclipse.b3.aggregator.engine.Builder.run(Builder.java:1683)
at org.eclipse.b3.cli.AbstractCommand.run(AbstractCommand.java:133)
at org.eclipse.b3.cli.Headless.run(Headless.java:161)
at org.eclipse.b3.cli.Headless.start(Headless.java:197)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
!SUBENTRY 1 org.eclipse.b3.util 4 0 2011-08-10 10:05:20.760
Johan
Re: b3 and p2 authentication [message #714480 is a reply to message #714337] Wed, 10 August 2011 15:52 Go to previous messageGo to next message
Hi again!
I ran some more test in debug mode and the problem is actually that
I have no login credentials for the URI to the p2 repository. This makes
sense.
So the question is really if there is a way to create these login credentials
for a headless build in somw way?
/Johan
Re: b3 and p2 authentication [message #735293 is a reply to message #714480] Tue, 11 October 2011 13:18 Go to previous message
Bernd Kolb is currently offline Bernd KolbFriend
Member
we are having the same issue. Any solution yet?
Thx
Bernd
Previous Topic:Is it possible to use b3 engine in Indigo?
Next Topic:test, using opera nntp reader
Current Time: Mon Sep 25 17:52:50 GMT 2023
Powered by FUDForum. Page generated in 0.02443 seconds
