Home » Language IDEs » Java Development Tools (JDT) » Max packages in eachother?
Max packages in eachother? [message #713845] Tue, 09 August 2011 03:22 Go to next message
I was trying to edit some source code im working on in eclipse and one of the files had a huge ammount of folders in eachother, about 5, so eclipse couldnt put all of the packages in the main src and instead put it in its own source folder. This is giving me alot of errors since eclipse isnt looking in the right directory for those packages. Is there any way to have more than 4 packages inside eachother? Thanks! sorry for bad spelling had to type this quickly in the dark.
also anyone who helps me gets a cookie!
[Updated on: Tue, 09 August 2011 03:26] by Moderator
(no subject) [message #713858 is a reply to message #713845] Tue, 09 August 2011 04:06 Go to previous messageGo to next message
There is no limit. I guess something went wrong when you imported the
source or when you set up the Java build path.
Dani
Re: (no subject) [message #713861 is a reply to message #713858] Tue, 09 August 2011 04:25 Go to previous messageGo to next message
whenever i try to put a new package into the right place it wont let me put it in to where its supposed to go
Re: (no subject) [message #713916 is a reply to message #713861] Tue, 09 August 2011 06:58 Go to previous messageGo to next message
How do you do it?
Dani
Re: (no subject) [message #714115 is a reply to message #713916] Tue, 09 August 2011 16:30 Go to previous messageGo to next message
Oh for some reason Eclipse was removing it from the buildpath. i fixed now
[Updated on: Tue, 09 August 2011 20:23] by Moderator
Re: (no subject) [message #715085 is a reply to message #714115] Fri, 12 August 2011 06:14 Go to previous message
On 09.08.2011 22:30, gr3nwr35stlr wrote:
> If you are willing to use team viewer to help me that would probably
> be easier
Sorry, I can't download and install that.
Dani
Previous Topic:Rename class in Java editor
Next Topic:Creating a new Java project: Diff between two project patterns "Java project" ?
Current Time: Fri Mar 21 01:00:52 EDT 2025
Powered by FUDForum. Page generated in 0.03906 seconds
