JET Transformation fails when EMF model editor plugin installed [message #713490] |
Mon, 08 August 2011 14:35 |
Gabriel Telerman Messages: 1 Registered: August 2011 |
Junior Member |
Hi, I'm using an eclipse based product (WebSphere Integration Developer) and I created a set of JET2 templates to generate code. These worked fine until I created a model editor to have a friendly way to create input models.
I created the editor by describing the model as ecore, then generating the genmodel plus model and edit classes.
Now when I deploy the EMF model editor to the plugins directory the JET generation fails.
I tried a number of modelLoader alternatives in the JET transformation's plugin.xml but nothing seems to work.
If I remove the model editor plugin, then the code generation works fine again.
Has anyone seen this kind of behaviour before and can share what needs done to fix it?
Many thanks.
FUDForum. Page generated in 0.07903 seconds
