Home » Archived » M2M (model-to-model transformation) » [ATL] same source element(s) in two bindings: why the binding order matters?
[ATL] same source element(s) in two bindings: why the binding order matters? [message #75239] Thu, 21 February 2008 18:48 Go to next message
Originally posted by: zhuj.in.tum.de
Hi you ATL guys, I have a question:
I have the following two binding inside a UML2!Class rule, to copy the
attributes to attributes, and generate operations from the same attributes:
1) ownedAttribute <- s.ownedAttribute
2) ownedOperation <- s.ownedAttribute->iterate(a; attrs :
Set(UML2!Property)
= Set{} |
if(a.oclIsTypeOf(UML2!Property))
attrs->including(a)
else
attrs
endif
->collect(p | thisModule.Property2Operation(p)),
The question is:
the binding order 2), 1) works, i.e. Operations can be generated from
attributes.
But the order 1), 2) doesn't work: after binding 1) is finished, the
source part of 2) is always an empty Set{}.
Can someone explain this to me?
Thx.
Re: [ATL] same source element(s) in two bindings: why the binding order matters? [message #75326 is a reply to message #75239] Sat, 23 February 2008 14:55 Go to previous message
Frédéric Jouault is currently offline Frédéric JouaultFriend
The reason why you have this issue is that you are allowing inter-model
references, and not transforming Propertys. Therefore, the source
attributes are actually removed from the source resource, and added to
the target resource, effectively modifying the source model.
Frédéric Jouault
> Set(UML2!Property) = Set{} |
> attrs->including(a)
> else
> attrs
> endif
> The question is: the binding order 2), 1) works, i.e. Operations can be
> generated from attributes. But the order 1), 2) doesn't work: after
> binding 1) is finished, the source part of 2) is always an empty Set{}.
> Thx.
Previous Topic:[ATL] xmi::id for elements refereced by diagram
Next Topic:ATL, AM3 version
Current Time: Mon Jan 27 05:26:32 GMT 2020
Powered by FUDForum. Page generated in 0.01588 seconds
