Home » Eclipse Projects » Technology Project and PMC » Eclipse application using Hibernate
Eclipse application using Hibernate [message #75085] Tue, 18 December 2007 23:33
Hi all,
There are 2 different projects in my workspace. Project A and
B(say).
A is dependent on B. A has a java class X(say) that uses hibernate to
fetch data from database.
.hbm.xml files and corresponding classes needed for the same are
in project B and under same package. When i run class X individually
(using public static void main...), it works fine. But when i try to run
the project as eclipse application, it doesnt find hibernate.cfg.xml. If i
hardcode the file path(which is not right way of doing it) in my class
while calling .configuer(path), it gets the file but doesnt find any
class which is mentioned in .hbm.xml file.
My hibernate.cfg.xml is in project B. Even if i place it in
project A it gives same problem. I tried placing it under root dir/ in
src, in both the projects but faced same problem.
I tried adding all the properties and classes through code using
configure.addClass(..) and configure.setProperty(..). Still it didnt work.
Can anybody help?
Previous Topic:Eclipse Group Growing on LinkedIn.com
Next Topic:Eclipse application using Hibernate
Current Time: Fri Jun 13 16:48:32 EDT 2025
Powered by FUDForum. Page generated in 0.04419 seconds
