Home » Archived » M2M (model-to-model transformation) » ATL:Transformation
ATL:Transformation [message #74977] Thu, 14 February 2008 10:57 Go to next message
Originally posted by: ouldkonissa.yahoo.fr
I am doing a transformation of JPDL to BlueXml.
The rule is
rule Swimlane2BPMActor{
from e : JPDL!Swimlane
to out : BlueXML!BPMActor(
assignment<- if e.assignment.oclIsUndefined() then
else e.assignment.pooledactors
endif,
name<-e.name,
manage <- if JPDL!Task.allInstances()->size()>0 then
JPDL!Task.allInstances()->select(t|t.swimlane <>
OclUndefined)->select(t|t.swimlane.name = e.name)-> asSequence()
else
Sequence{}
endif
In the result i obtain
<profileset xsi:type="MMUseCase:BPMActor"
xmi:id="_0PlasdrpEdyWevM8ojuhEA" name="initiator" assignment="">
the problem is that in the three first manage i obtain a 'href' in
<manage
href=" platform:/resource/BlueXml/JPDL2BlueXML/TransfoXmlToJpdl.eco re#//@startstate/@task "/>
<manage
href=" /BlueXml/JPDL2BlueXML/TransfoJpdlToBlueXml.obl#_0Pi-cdrpEdyW evM8ojuhEA "/>
<manage
href=" /BlueXml/JPDL2BlueXML/TransfoJpdlToBlueXml.obl#_0Pi-ctrpEdyW evM8ojuhEA "/>
</profileset>
instead of having an xmi : id
xmi:id="_0PpsINrpEdyWevM8ojuhEA" name="marketing"
manage="_0PiXYNrpEdyWevM8ojuhEA" assignment=""/>
xmi:id="_0PpsIdrpEdyWevM8ojuhEA" name="engineering"
manage="_0Pi-cNrpEdyWevM8ojuhEA" assignment=""/>
Issa Koné
Re: ATL:Transformation [message #75041 is a reply to message #74977] Fri, 15 February 2008 12:00 Go to previous messageGo to next message
Originally posted by: quentin.glineur.obeo.fr
--------------070904000503040005000504
Hi Issa,
Is the resulting model valid ? I mean, is it just a matter of
serialization or are facing a problem with the model structure ?
Quentin GLINEUR
issa kone a
Re: ATL:Transformation [message #75047 is a reply to message #74977] Fri, 15 February 2008 12:12 Go to previous messageGo to next message
Originally posted by: r.c.ladan.tue.nl
issa kone wrote:
> Hello,
> The rule is
> else
> endif,
> name<-e.name,
> else
> Sequence{}
> endif
> <manage
> <manage
> <manage
> </profileset>
This looks like an issue with how EMF serializes the resulting model. It also happens when
there are references to elements in your resulting model for which the referenced elements only
exist in the input model.
HTH,
Rene
Re: ATL:Transformation [message #75062 is a reply to message #75041] Fri, 15 February 2008 13:16 Go to previous message
Hello Quentin,
the resulting model is vaild because i can open it with the sample ecore
editor after having registered the target meta model. But when i rename
the resulting model in xmi and open it with a text editor, i find this
result where i have an 'href' to the name of the target model instead
of having an xmi : id like the others.
href="/BlueXml/JPDL2BlueXML/TransfoJpdlToBlueXml.obl
According to Rene Ladan it may be :
<<This looks like an issue with how EMF serializes the resulting model.
exist in the input model.>>
Thanks for your reply.
Issa Koné
Quentin Glineur a écrit :
> Hi Issa,
> Quentin GLINEUR
> issa kone a écrit :
>> Hello,
>> The rule is
>> else
>> endif,
>> name<-e.name,
>> else
>> Sequence{}
>> endif
>> <manage
>> <manage
>> <manage
>> </profileset>
>> Thanks
>> Issa Koné
Previous Topic:[ATL] Run ant script via console
Next Topic:[ATL] MagicDraw and ATL
Current Time: Sat Jan 18 19:36:17 GMT 2020
Powered by FUDForum. Page generated in 0.01795 seconds
