support for debug.file_link_format [message #74876] |
Fri, 04 July 2008 10:09  |
I see that xdebug has the option to generate links in error pages
with the filename and line number of the error
http://xdebug.org/docs/all_settings
An example format might look like:
myide://%f@%l
Is there any way to use this with eclipse?
If it can't be done directly - is there any way to interact with eclipse
from another program (so that the xdebug link could trigger a helper
program)
I've been looking for this for a while and not found anything so I'm not
expecting easy answers at this point ...
Sean
Re: support for debug.file_link_format [message #74912 is a reply to message #74876] |
Fri, 04 July 2008 16:45   |
Originally posted by: dkel50.hotnospmail.com
Hi Sean, I see that this feature is only available in XDebug 2.1 which
is not released yet, but I would be interested in any feedback on how
PDT gets on with prerelease versions of xdebug 2.1
I don't know if it is possible to do what you want with eclipse though.
I think what is required is the ability to either launch eclipse and
load that file into an appropriate editor or to signal to an existing
eclipse app to do the same. One interesting issue would be what would
happen when you have multiple eclipse instances running (which I tend to
do when working on multiple projects).
Dave Kelsey
Sean Burlington wrote:
> I see that xdebug has the option to generate links in error pages with
> myide://%f@%l
> program)
Re: support for debug.file_link_format [message #74923 is a reply to message #74912] |
Fri, 04 July 2008 18:34   |
would you expect to see problems - it doesn't look like a big change?
it's the second option that I'd be really keen on - its when I'm
developing in eclipse - I get an error Xdebug prints the file name and
line number - I have to manually navigate to this point.
I don't mind if this is limited to working on one - manually configured
project at a time ...
PDT can find the file and line number when it's debugging a program
one thought I had is whether it might help to have a small program that
starts eclipse and keeps a communication channel open - this program
could receive the link from the OS and pass it to eclipse....
Sorry - a bit vague (I'm a web developer and this is getting into OS
territory )
Fireclipse is doing something along these lines for firebug integration
http://fireclipse.svn.sourceforge.net/viewvc/*checkout*/fire clipse/trunk/FireclipseDocumentation/screenshots.htm
http://www.almaden.ibm.com/u/bartonjj/fireclipse/index.html
But those install instructions look like a bit of a nightmare at the
moment ;-)
Sean
Re: support for debug.file_link_format [message #75028 is a reply to message #74923] |
Sun, 06 July 2008 13:22  |
Well 2.0.2 to 2.0.3 was a small change, yet it was enough to stop PDT
from working with XDebug. Any feedback from people trying 2.1
pre-release code is always useful.
>> though. I think what is required is the ability to either launch
>> eclipse and load that file into an appropriate editor or to signal to
>> an existing eclipse app to do the same.
A Solution may be possible. If XDebug supports exception breakpoints
(which would include errors) and I think it does, PDT could be enhanced
to register these breakpoints with xdebug and when an error occurs to
break at the line the error occurred and PDT to display as though it was
a normal breakpoint. Would this be helpful ? The other solution doesn't
sound like something that the eclipse platform would support (But I
could be wrong on that).
>> One interesting issue would be what would happen when you have
>> multiple eclipse instances running (which I tend to do when working on
>> multiple projects).
> territory )
> moment ;-)
FUDForum. Page generated in 0.03495 seconds
