Re: EMF metamodel with acceleo [message #713161 is a reply to message #710658] |
Mon, 08 August 2011 07:05 |
What is the error message you get when you "don't get any output file"? (Window > Show View > Error Log ... and look if there is something in there when a generation fails.)
If you have no error message whatsoever, the most plausible explanation is that the model you feed Acceleo as an input of your generation has no element matching the type of your main template.
Laurent Goubet
Obeo
Re: EMF metamodel with acceleo [message #714642 is a reply to message #713877] |
Thu, 11 August 2011 07:23 |
What version of Acceleo are you using? (if 3.1, then try to change the settings of your Acceleo project to use the XMI serialization: right click on the project -> properties -> Acceleo -> check XMI).
Quote:Now it's work only when i start eclipse from my model project. But not work when i install my metamodel project as an eclipse plug-in. what is good way for integrate my metamodel in acceleo project ?
If I understand you correctly, if you have your metamodel in the workspace and if you are working with it in your generator it works but when you deploy the metamodel (and the generator?) as plugins in another eclipse it does not work anymore. You should try the switch to XMI based serialization or you could work on your generator with the metamodel install as a plugin first.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Google+: stephane.begaudeau
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
FUDForum. Page generated in 0.03502 seconds
