Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Invalid subclass tag in hibernate mapping file .
[Teneo] Invalid subclass tag in hibernate mapping file . [message #74403] Thu, 08 March 2007 17:33 Go to next message
Duncan Alexander is currently offline Duncan AlexanderFriend
Member
--------------060605040602010802090609
im having an issue with my hibernate mapping file as generated by
teneo. The issue seems to be an <id> and <version> tags which have been
inserted below a <subclass> tag. I don't believe this is allowed and Im
getting an error when attempting to use the config file of the form:
org.hibernate.InvalidMappingException: Could not parse mapping document
from resource hibernate_sdmx_config.xml
at org.hibernate.cfg.Configuration.addResource(Configuration.ja va:569)
at etc etc etc.
... 31 more
Caused by: org.xml.sax.SAXParseException: The content of element type
"subclass" must match
" (meta*,tuplizer*,synchronize*,(property|many-to-one|one-to-o ne|component|dynamic-component|any|map|set|list|bag|idbag|ar ray|primitive-array)*,join*,subclass*,loader?,sql-insert?,sq l-update?,sql-delete?,resultset*,(query|sql-query)*) ".
at
com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper. createSAXParseException(ErrorHandlerWrapper.java:236)
.... etc etc etc
The section in question is attached.
My current setup is: Teneo 0.75, EMF2.2, Hibernate 3.2
Any help greatly appreciated.
Duncan
name="snippit.txt"
Content-Disposition: inline;
filename="snippit.txt"
<subclass entity-name="Identifiable" abstract="true" lazy="false" extends="Annotable" discriminator-value="Identifiable">
<meta attribute="eclassName">Identifiable</meta>
<meta attribute="epackage">http://www.sdmx.org/resources/infomodel/1.0/base.xmi</meta>
<id name="urn" type="java.lang.String">
<column not-null="true" unique="false" name="`urn`"/>
</id>
<version name="e_version" column="e_version" access=" org.eclipse.emf.teneo.hibernate.mapping.property.VersionProp ertyHandler ">
<meta attribute="syntheticVersion">true</meta>
</version>
<property name="id" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`id`"/>
</property>
<property name="uri" lazy="false" insert="true" update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`uri`"/>
</property>
<many-to-one name="Name" entity-name="InternationalString" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`internationalstring_name_e_id`"/>
</many-to-one>
<many-to-one name="Description" entity-name="InternationalString" cascade="all" lazy="false" insert="true" update="true" not-null="false">
<column not-null="false" unique="false" name="`internationalstring_description_e_id`"/>
</many-to-one>
</subclass>
--------------060605040602010802090609--
Re: [Teneo] Invalid subclass tag in hibernate mapping file . [message #74421 is a reply to message #74403] Thu, 08 March 2007 17:54 Go to previous messageGo to next message
Martin Taal is currently offline Martin TaalFriend
Yes this seems to be a bug. Can you enter a bugzilla for this and attach the ecore files to that? If
you don't want to have your model publically accessible you can also send the ecores to me directly.
gr. Martin
Duncan ALexander wrote:
> at etc etc etc.
> ... 31 more
> at
> .... etc etc etc
> Duncan
> </id>
> </version>
> </property>
> </property>
> </many-to-one>
> </many-to-one>
> </subclass>
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Invalid subclass tag in hibernate mapping file . [message #74600 is a reply to message #74421] Fri, 09 March 2007 14:11 Go to previous messageGo to next message
Member
Bug added as No: 176821
ECore files mailed directly to you (Martin).
regards
Duncan
> the ecore files to that? If you don't want to have your model publically
> gr. Martin
>> Hi,
>> been inserted below a <subclass> tag. I don't believe this is allowed
>> and Im getting an error when attempting to use the config file of the
>> form:
>> document from resource hibernate_sdmx_config.xml
>> at
>> at etc etc etc.
>> ... 31 more
>> at
>> .... etc etc etc
>> Duncan
>> <meta
>> </id>
>> </version>
>> </property>
>> </property>
>> </many-to-one>
>> </many-to-one>
>> </subclass>
Re: [Teneo] Invalid subclass tag in hibernate mapping file . [message #74906 is a reply to message #74600] Sun, 11 March 2007 16:22 Go to previous messageGo to next message
Member
Hi Martin,
with regard to your answer in Bugzilla (below)
note: Im generating my ecore from a Rose model.
Is it possible to mark something as a MappedSuperclass within a Rose model or would the actual
..ecore file need to be updated to reflect the new annotation or does Teneo also look at the code
generated from the .ecore file where it would be able to see any additional annotations ?
I've done a fair bit of digging before asking this question as I thought I would be able to work it
out but I'm afraid I hit a blank.
regards
Duncan
------- Comment #1 From Martin taal 2007-03-09 12:59:02 [reply] -------
I checked the ecore files and the Identifiable has an efeature (urn) with the
id property (in ecore) set to true). This means that this efeature is mapped as
the id. Teneo does this eventhough it is a subclass (it is considered to be the
designers responsibility to assign id's only to the root of the inheritance
structure).
There is an option (PersistenceOptions.ID_FEATURE_AS_PRIMARY_KEY) to control if
Teneo should use the id=true efeatures as the pk. You can set this to false.
Another approach could be to map the annotatable as a @MappedSuperclass.
Let me know if this answers this issue.
gr. Martin
> Hi
> regards
> Duncan
>> attach the ecore files to that? If you don't want to have your model
>> gr. Martin
>>> Hi,
>>> form:
>>> at
>>> at etc etc etc.
>>> ... 31 more
>>> at
>>> .... etc etc etc
>>> Duncan
>>> <meta
>>> </id>
>>> </version>
>>> </property>
>>> </property>
>>> </many-to-one>
>>> </many-to-one>
>>> </subclass>
Re: [Teneo] Invalid subclass tag in hibernate mapping file . [message #74920 is a reply to message #74906] Sun, 11 March 2007 16:32 Go to previous messageGo to next message
Hi Duncan,
You can enter a @MappedSuperClass annotation in Rose. I don't know how to do this though, maybe
searching on the emf newsgroup gives the answer. Otherwise you can ask there how to do that.
You can also specify jpa annotations in a separate xml file so that you don't need to adapt the
ecore (or Rose) itself:
http://www.elver.org/hibernate/ejb3_format.html#xml
(see that I need to edit this part of the website, it mentions jpoxdatastore, should be hbdatastore).
gr. Martin
> Hi Martin,
> model or would the actual ..ecore file need to be updated to reflect the
> new annotation or does Teneo also look at the code generated from the
> I would be able to work it out but I'm afraid I hit a blank.
> regards
> Duncan
> with the
> mapped as
> be the
> structure).
> control if
> false.
> gr. Martin
>> Hi
>> regards
>> Duncan
>>> gr. Martin
>>>> Hi,
>>>> allowed and Im getting an error when attempting to use the config
>>>> file of the form:
>>>> at
>>>> at etc etc etc.
>>>> ... 31 more
>>>> type "subclass" must match
>>>> at
>>>> .... etc etc etc
>>>> Duncan
>>>> <meta
>>>> </id>
>>>> </version>
>>>> </property>
>>>> </property>
>>>> not-null="false">
>>>> </many-to-one>
>>>> </many-to-one>
>>>> </subclass>
The Netherlands
Re: [Teneo] Invalid subclass tag in hibernate mapping file . [message #74954 is a reply to message #74920] Sun, 11 March 2007 17:45 Go to previous messageGo to next message
Member
Hi Martin,
As I cant find any clear info on the newsgroups on how to add the MappedSuperClass annotation to
the Rose model I think it would be easier to add it directly to the generated .ecore
file...or....should I be adding it to the generated java file ?
Is it Teneo that will be checking for this annotation (as opposed to Hibernate) and if so
what format would the annotation have in an .ecore file ?
I assume that it would look like this in the ecore:
<eAnnotations source="http://someURLOrAnother">
<details key="MappedSuperClass" value="true"/>
</eAnnotations>
Duncan
Martin Taal wrote:
> Hi Duncan,
> to do this though, maybe searching on the emf newsgroup gives the
> don't need to adapt the ecore (or Rose) itself:
> gr. Martin
>> Hi Martin,
>> the new annotation or does Teneo also look at the code generated from
>> annotations ?
>> thought I would be able to work it out but I'm afraid I hit a blank.
>> regards
>> Duncan
>> Hi,
>> with the
>> mapped as
>> to be the
>> inheritance
>> structure).
>> control if
>> false.
>> gr. Martin
>>> Hi
>>> regards
>>> Duncan
>>>> gr. Martin
>>>>> Hi,
>>>>> by teneo. The issue seems to be an <id> and <version> tags which
>>>>> have been inserted below a <subclass> tag. I don't believe this is
>>>>> file of the form:
>>>>> at
>>>>> at etc etc etc.
>>>>> ... 31 more
>>>>> at
>>>>> .... etc etc etc
>>>>> Duncan
>>>>> <meta
>>>>> </id>
>>>>> </version>
>>>>> </property>
>>>>> </property>
>>>>> not-null="false">
>>>>> </many-to-one>
>>>>> </many-to-one>
>>>>> </subclass>
Re: [Teneo] Invalid subclass tag in hibernate mapping file . [message #74963 is a reply to message #74954] Sun, 11 March 2007 18:30 Go to previous message
Member
Actually,
I just found this in the eclipse newsgroups which I believe explains the format annotations should
have in the .ecore file.
http://dev.eclipse.org/newslists/news.eclipse.technology.emf t/msg01342.html
Ill try this out first.
thanks Martin for your assistance.
Duncan
> Hi Martin,
> MappedSuperClass annotation to the Rose model I think it would be easier
> to add it directly to the generated .ecore file...or....should I be
> </eAnnotations>
> Duncan
> Martin Taal wrote:
>> Hi Duncan,
>> you don't need to adapt the ecore (or Rose) itself:
>> gr. Martin
>>> Hi Martin,
>>> annotations ?
>>> regards
>>> Duncan
>>> Hi,
>>> with the
>>> mapped as
>>> to be the
>>> inheritance
>>> structure).
>>> control if
>>> false.
>>> gr. Martin
>>>> Hi
>>>> regards
>>>> Duncan
>>>>> directly.
>>>>> gr. Martin
>>>>>> Hi,
>>>>>> file of the form:
>>>>>> at
>>>>>> at etc etc etc.
>>>>>> ... 31 more
>>>>>> at
>>>>>> .... etc etc etc
>>>>>> Duncan
>>>>>> <meta
>>>>>> </id>
>>>>>> </version>
>>>>>> </property>
>>>>>> </property>
>>>>>> not-null="false">
>>>>>> </many-to-one>
>>>>>> </many-to-one>
>>>>>> </subclass>
Re: [Teneo] Invalid subclass tag in hibernate mapping file . [message #603316 is a reply to message #74403] Thu, 08 March 2007 17:54 Go to previous message
gr. Martin
> at etc etc etc.
> ... 31 more
> at
> .... etc etc etc
> Duncan
> </id>
> </version>
> </property>
> </property>
> </many-to-one>
> </many-to-one>
> </subclass>
The Netherlands
Re: [Teneo] Invalid subclass tag in hibernate mapping file . [message #603355 is a reply to message #74421] Fri, 09 March 2007 14:11 Go to previous message
Member
regards
Duncan
> gr. Martin
>> Hi,
>> form:
>> at
>> at etc etc etc.
>> ... 31 more
>> at
>> .... etc etc etc
>> Duncan
>> <meta
>> </id>
>> </version>
>> </property>
>> </property>
>> </many-to-one>
>> </many-to-one>
>> </subclass>
Re: [Teneo] Invalid subclass tag in hibernate mapping file . [message #603438 is a reply to message #74600] Sun, 11 March 2007 16:22 Go to previous message
Member
Hi Martin,
regards
Duncan
structure).
gr. Martin
> Hi
> regards
> Duncan
>> gr. Martin
>>> Hi,
>>> form:
>>> at
>>> at etc etc etc.
>>> ... 31 more
>>> at
>>> .... etc etc etc
>>> Duncan
>>> <meta
>>> </id>
>>> </version>
>>> </property>
>>> </property>
>>> </many-to-one>
>>> </many-to-one>
>>> </subclass>
Re: [Teneo] Invalid subclass tag in hibernate mapping file . [message #603442 is a reply to message #74906] Sun, 11 March 2007 16:32 Go to previous message
Hi Duncan,
gr. Martin
> Hi Martin,
> regards
> Duncan
> with the
> mapped as
> be the
> structure).
> control if
> false.
> gr. Martin
>> Hi
>> regards
>> Duncan
>>> gr. Martin
>>>> Hi,
>>>> file of the form:
>>>> at
>>>> at etc etc etc.
>>>> ... 31 more
>>>> at
>>>> .... etc etc etc
>>>> Duncan
>>>> <meta
>>>> </id>
>>>> </version>
>>>> </property>
>>>> </property>
>>>> not-null="false">
>>>> </many-to-one>
>>>> </many-to-one>
>>>> </subclass>
The Netherlands
Re: [Teneo] Invalid subclass tag in hibernate mapping file . [message #603462 is a reply to message #74920] Sun, 11 March 2007 17:45 Go to previous message
Member
Hi Martin,
</eAnnotations>
Duncan
Martin Taal wrote:
> Hi Duncan,
> gr. Martin
>> Hi Martin,
>> annotations ?
>> regards
>> Duncan
>> Hi,
>> with the
>> mapped as
>> to be the
>> inheritance
>> structure).
>> control if
>> false.
>> gr. Martin
>>> Hi
>>> regards
>>> Duncan
>>>> gr. Martin
>>>>> Hi,
>>>>> file of the form:
>>>>> at
>>>>> at etc etc etc.
>>>>> ... 31 more
>>>>> at
>>>>> .... etc etc etc
>>>>> Duncan
>>>>> <meta
>>>>> </id>
>>>>> </version>
>>>>> </property>
>>>>> </property>
>>>>> not-null="false">
>>>>> </many-to-one>
>>>>> </many-to-one>
>>>>> </subclass>
Re: [Teneo] Invalid subclass tag in hibernate mapping file . [message #603468 is a reply to message #74954] Sun, 11 March 2007 18:30 Go to previous message
Member
Actually,
Duncan
> Hi Martin,
> </eAnnotations>
> Duncan
> Martin Taal wrote:
>> Hi Duncan,
>> gr. Martin
>>> Hi Martin,
>>> annotations ?
>>> regards
>>> Duncan
>>> Hi,
>>> with the
>>> mapped as
>>> to be the
>>> inheritance
>>> structure).
>>> control if
>>> false.
>>> gr. Martin
>>>> Hi
>>>> regards
>>>> Duncan
>>>>> directly.
>>>>> gr. Martin
>>>>>> Hi,
>>>>>> file of the form:
>>>>>> at
>>>>>> at etc etc etc.
>>>>>> ... 31 more
>>>>>> at
>>>>>> .... etc etc etc
>>>>>> Duncan
>>>>>> <meta
>>>>>> </id>
>>>>>> </version>
>>>>>> </property>
>>>>>> </property>
>>>>>> not-null="false">
>>>>>> </many-to-one>
>>>>>> </many-to-one>
>>>>>> </subclass>
Previous Topic:EMaps and the missing @MapKey annotation
Next Topic:[Teneo] Duplicate entity name problem in hibernate mapping file.
Current Time: Sat Nov 28 18:00:32 GMT 2020
Powered by FUDForum. Page generated in 0.02222 seconds
