Home » Archived » XML Schema Definition (XSD) » XML Schema Comparison
Re: XML Schema Comparison [message #74420 is a reply to message #74401] |
Tue, 20 May 2008 11:28 |
--------------080500060004030301090909
Nazir,
You could compare them as text files. You could also use EMFT's model
compare framework to compare XSD's structured representations directly:
http://www.eclipse.org/modeling/emft/?project=compare
Nazir wrote:
> I would like to know how can I use eclipse's XSD to compare 2 XML
> schemas. Any idea?
> Thanks
> ~nazir~
<html>
<head>
http-equiv="Content-Type">
</head>
Nazir,<br>
<br>
Re: XML Schema Comparison [message #74455 is a reply to message #74438] |
Wed, 21 May 2008 15:59 |
Nazir,
No. The compare framework can work with instances of Ecore, UML, XSD or
any model...
Nazir wrote:
> Thanks Ed,
> I read the link given. Just another question. Does it means I have to
> convert the XML schemas into Eclipse ECore model and then only I can
> use this compare project to compare those models? Any idea on how to
> convert a bunch of XML schemas into this ECore models?
> Thanks, in advance.
> ~nazir~
> Ed Merks wrote:
>> Nazir,
>> model compare framework to compare XSD's structured representations
>> directly:
>> Nazir wrote:
>>> Hi,
>>> schemas. Any idea?
>>> Thanks
>>> ~nazir~
Re: XML Schema Comparison [message #74491 is a reply to message #74473] |
Fri, 23 May 2008 11:53 |
Nazir,
Yes, I believe the compare engine can be used stand alone. It's best to
ask on the EMFT newsgroup about compare. I don't have examples of using
XSD with compare. The XSDMainExample shows how to load XSDs.
Nazir wrote:
> Sorry again, Ed. Just a curiosity about this XSD and Compare
> framework. Can I use the xsd and compare together programmatically
> (without Eclipse IDE)? Is there any example on loading XML schema
> files and use Compare to differentiate them?
> Thanks again.
> Ed Merks wrote:
>> Nazir,
>> or any model...
>> Nazir wrote:
>>> Thanks Ed,
>>> to convert the XML schemas into Eclipse ECore model and then only I
>>> can use this compare project to compare those models? Any idea on
>>> how to convert a bunch of XML schemas into this ECore models?
>>> Thanks, in advance.
>>> ~nazir~
>>> Ed Merks wrote:
>>>> Nazir,
>>>> directly:
>>>> Nazir wrote:
>>>>> Hi,
>>>>> schemas. Any idea?
>>>>> Thanks
>>>>> ~nazir~
Re: XML Schema Comparison [message #74507 is a reply to message #74491] |
Thu, 29 May 2008 03:07 |
Muhamad Nazir Messages: 24 Registered: July 2009 |
Junior Member |
Hi Ed,
Referring to the XSDMainExample.java, is this class loading an XSD or a
bunch of XSDs? I noticed this line:
<excerpt>
XSDResourceImpl xsdMainResource =
(XSDResourceImpl)resourceSet.createResource(URI.createURI("*.xsd "));
</excerpt>
is this referring to multiple XSDs? I'm going to load multiple XSDs as
well.
Ed Merks wrote:
> Nazir,
>> Thanks again.
>> Ed Merks wrote:
>>> Nazir,
>>> or any model...
>>> Nazir wrote:
>>>> Thanks Ed,
>>>> Thanks, in advance.
>>>> ~nazir~
>>>> Ed Merks wrote:
>>>>> Nazir,
>>>>> directly:
>>>>> Nazir wrote:
>>>>>> Hi,
>>>>>> schemas. Any idea?
>>>>>> Thanks
>>>>>> ~nazir~
Re: XML Schema Comparison [message #74525 is a reply to message #74507] |
Thu, 29 May 2008 11:05 |
Nazir,
You'll see it does
xsdMainResource.setURI(uri);
It does this because the appropriate type of resource is created based
on file extension so we use a dummy URI to ensure that a resource for
..xsd extension is created and then we replace that URI with the actual
URI immediately and load that one XSD (which of course can load other
XSDs as includes and imports are resolved).
If you're loading many resources, it's safer to use
resourceSet.getResource(<uri>, true) since this ensures that if a
resource has been loaded because of includes or imports of it by another
resource, that you return the one shared instance rather than creating a
new version of it. Just make sure all your resource URIs end in .xsd,
or register the XSDResourceFactoryImpl for all the extensions you
actually use.
Nazir wrote:
> Hi Ed,
> a bunch of XSDs? I noticed this line:
> <excerpt>
> </excerpt>
> well.
> Thanks
> Ed Merks wrote:
>> Nazir,
>> to ask on the EMFT newsgroup about compare. I don't have examples of
>> using XSD with compare. The XSDMainExample shows how to load XSDs.
>>> Thanks again.
>>> Ed Merks wrote:
>>>> Nazir,
>>>> XSD or any model...
>>>> Nazir wrote:
>>>>> Thanks Ed,
>>>>> I can use this compare project to compare those models? Any idea
>>>>> on how to convert a bunch of XML schemas into this ECore models?
>>>>> Thanks, in advance.
>>>>> ~nazir~
>>>>> Ed Merks wrote:
>>>>>> Nazir,
>>>>>> Nazir wrote:
>>>>>>> Hi,
>>>>>>> XML schemas. Any idea?
>>>>>>> Thanks
>>>>>>> ~nazir~
Re: XML Schema Comparison [message #74543 is a reply to message #74525] |
Fri, 06 June 2008 03:59 |
Junior Member |
Thanks for the previous answer Ed,
I've another one, how can I load all the schemas without specifying any
XSD but just using a folder, for example? I have something like this:
files:
c:/schemas/LocalAuthorities.xsd
c:/schemas/Address.xsd
c:/schemas/GovernmentAgency.xsd
c:/schemas/codelists/State.xsd
c:/schemas/codelists/Bank.xsd
For example, LocalAuthorites will use the codelists and so does
GovernmentAgency. I have all other folders inside the "schemas" folder as
well.
Can I load only schemas folder or I need to load all? Is the multiple URIs
needed or I need to use java.io.File?
Thanks again
~nazir~
Ed Merks wrote:
> Nazir,
> You'll see it does
> actually use.
> Nazir wrote:
>> Hi Ed,
>> <excerpt>
>> </excerpt>
>> well.
>> Thanks
>> Ed Merks wrote:
>>> Nazir,
>>>> Thanks again.
>>>> Ed Merks wrote:
>>>>> Nazir,
>>>>> XSD or any model...
>>>>> Nazir wrote:
>>>>>> Thanks Ed,
>>>>>> Thanks, in advance.
>>>>>> ~nazir~
>>>>>> Ed Merks wrote:
>>>>>>> Nazir,
>>>>>>> Nazir wrote:
>>>>>>>> Hi,
>>>>>>>> Thanks
>>>>>>>> ~nazir~
Re: XML Schema Comparison [message #74561 is a reply to message #74543] |
Fri, 06 June 2008 13:42 |
Nazir,
You should find all the schemas you want to load somehow; that's not an
EMF/XSD question. If you have file system paths, you should use
URI.createFileURI to create the URI needed by EMF; if it's workspace
paths, use URI.createPlatformResourceURI. For the entire collection of
URIs of schemas you want to load, you'd use
resourceSet.getResource(<uri>, true) to demand load each and every one.
> any XSD but just using a folder, for example? I have something like this:
> files:
> as well.
> URIs needed or I need to use java.io.File?
> Thanks again
> ~nazir~
> Ed Merks wrote:
>> Nazir,
>> You'll see it does
>> based on file extension so we use a dummy URI to ensure that a
>> resource for ..xsd extension is created and then we replace that URI
>> with the actual URI immediately and load that one XSD (which of
>> course can load other XSDs as includes and imports are resolved).
>> another resource, that you return the one shared instance rather than
>> creating a new version of it. Just make sure all your resource URIs
>> end in .xsd, or register the XSDResourceFactoryImpl for all the
>> extensions you actually use.
>> Nazir wrote:
>>> Hi Ed,
>>> or a bunch of XSDs? I noticed this line:
>>> <excerpt>
>>> </excerpt>
>>> as well.
>>> Thanks
>>> Ed Merks wrote:
>>>> Nazir,
>>>> best to ask on the EMFT newsgroup about compare. I don't have
>>>> examples of using XSD with compare. The XSDMainExample shows how
>>>> to load XSDs.
>>>>> Thanks again.
>>>>> Ed Merks wrote:
>>>>>> Nazir,
>>>>>> XSD or any model...
>>>>>> Nazir wrote:
>>>>>>> Thanks Ed,
>>>>>>> have to convert the XML schemas into Eclipse ECore model and
>>>>>>> then only I can use this compare project to compare those
>>>>>>> models? Any idea on how to convert a bunch of XML schemas into
>>>>>>> this ECore models?
>>>>>>> Thanks, in advance.
>>>>>>> ~nazir~
>>>>>>> Ed Merks wrote:
>>>>>>>> Nazir,
>>>>>>>> EMFT's model compare framework to compare XSD's structured
>>>>>>>> Nazir wrote:
>>>>>>>>> Hi,
>>>>>>>>> Thanks
>>>>>>>>> ~nazir~
Re: XML Schema Comparison [message #603019 is a reply to message #74401] |
Ed Merks Messages: 33141 Registered: July 2009 |
Nazir,
Nazir wrote:
> schemas. Any idea?
> Thanks
> ~nazir~
<html>
<head>
</head>
Nazir,<br>
<br>
Ed Merks
Re: XML Schema Comparison [message #603026 is a reply to message #74438] |
Nazir,
any model...
Nazir wrote:
> Thanks Ed,
> Thanks, in advance.
> ~nazir~
> Ed Merks wrote:
>> Nazir,
>> directly:
>> Nazir wrote:
>>> Hi,
>>> schemas. Any idea?
>>> Thanks
>>> ~nazir~
Ed Merks
Re: XML Schema Comparison [message #603035 is a reply to message #74473] |
Nazir,
> Thanks again.
> Ed Merks wrote:
>> Nazir,
>> or any model...
>> Nazir wrote:
>>> Thanks Ed,
>>> Thanks, in advance.
>>> ~nazir~
>>> Ed Merks wrote:
>>>> Nazir,
>>>> directly:
>>>> Nazir wrote:
>>>>> Hi,
>>>>> schemas. Any idea?
>>>>> Thanks
>>>>> ~nazir~
Ed Merks
Re: XML Schema Comparison [message #603037 is a reply to message #74491] |
Junior Member |
Hi Ed,
<excerpt>
</excerpt>
well.
Ed Merks wrote:
> Nazir,
>> Thanks again.
>> Ed Merks wrote:
>>> Nazir,
>>> or any model...
>>> Nazir wrote:
>>>> Thanks Ed,
>>>> Thanks, in advance.
>>>> ~nazir~
>>>> Ed Merks wrote:
>>>>> Nazir,
>>>>> directly:
>>>>> Nazir wrote:
>>>>>> Hi,
>>>>>> schemas. Any idea?
>>>>>> Thanks
>>>>>> ~nazir~
Re: XML Schema Comparison [message #603042 is a reply to message #74507] |
Nazir,
You'll see it does
actually use.
Nazir wrote:
> Hi Ed,
> <excerpt>
> </excerpt>
> well.
> Thanks
> Ed Merks wrote:
>> Nazir,
>>> Thanks again.
>>> Ed Merks wrote:
>>>> Nazir,
>>>> XSD or any model...
>>>> Nazir wrote:
>>>>> Thanks Ed,
>>>>> Thanks, in advance.
>>>>> ~nazir~
>>>>> Ed Merks wrote:
>>>>>> Nazir,
>>>>>> Nazir wrote:
>>>>>>> Hi,
>>>>>>> Thanks
>>>>>>> ~nazir~
Ed Merks
Re: XML Schema Comparison [message #603044 is a reply to message #74525] |
Junior Member |
files:
well.
Thanks again
~nazir~
Ed Merks wrote:
> Nazir,
> You'll see it does
> actually use.
> Nazir wrote:
>> Hi Ed,
>> <excerpt>
>> </excerpt>
>> well.
>> Thanks
>> Ed Merks wrote:
>>> Nazir,
>>>> Thanks again.
>>>> Ed Merks wrote:
>>>>> Nazir,
>>>>> XSD or any model...
>>>>> Nazir wrote:
>>>>>> Thanks Ed,
>>>>>> Thanks, in advance.
>>>>>> ~nazir~
>>>>>> Ed Merks wrote:
>>>>>>> Nazir,
>>>>>>> Nazir wrote:
>>>>>>>> Hi,
>>>>>>>> Thanks
>>>>>>>> ~nazir~
Re: XML Schema Comparison [message #603049 is a reply to message #74543] |
Nazir,
> files:
> as well.
> Thanks again
> ~nazir~
> Ed Merks wrote:
>> Nazir,
>> You'll see it does
>> Nazir wrote:
>>> Hi Ed,
>>> <excerpt>
>>> </excerpt>
>>> as well.
>>> Thanks
>>> Ed Merks wrote:
>>>> Nazir,
>>>> to load XSDs.
>>>>> Thanks again.
>>>>> Ed Merks wrote:
>>>>>> Nazir,
>>>>>> XSD or any model...
>>>>>> Nazir wrote:
>>>>>>> Thanks Ed,
>>>>>>> this ECore models?
>>>>>>> Thanks, in advance.
>>>>>>> ~nazir~
>>>>>>> Ed Merks wrote:
>>>>>>>> Nazir,
>>>>>>>> Nazir wrote:
>>>>>>>>> Hi,
>>>>>>>>> Thanks
>>>>>>>>> ~nazir~
Ed Merks
Current Time: Thu Apr 25 23:11:51 GMT 2024
Powered by FUDForum. Page generated in 0.26486 seconds
