Home » Eclipse Projects » Dali » JPA Facet doesn't recognize Hibernate as legitmate
JPA Facet doesn't recognize Hibernate as legitmate [message #710239] Thu, 04 August 2011 21:01 Go to next message
yurchp is currently offline yurchpFriend
I am trying to add the JPA 2.0 Facet to an Eclipse 3.7 project. I select Platform: Generic 2.0 and User Library with hibernate-jpa-2.0-api-1.0.0.Final.jar. This gives me the error:
The class 'javax.persistence.Entity' is required to be in the selected libraries.
However, that jar does indeed contain that class. It also has source attached. What am I doing wrong?
Re: JPA Facet doesn't recognize Hibernate as legitmate [message #710246 is a reply to message #710239] Thu, 04 August 2011 21:08 Go to previous messageGo to next message
Paul Fullbright is currently offline Paul FullbrightFriend
I just tried it. I was able to get a library with that jar (and only that jar) to validate for Generic 2.0.
Is there perhaps something else going on? Is your jar maybe corrupt?
Re: JPA Facet doesn't recognize Hibernate as legitmate [message #710598 is a reply to message #710246] Fri, 05 August 2011 07:48 Go to previous messageGo to next message
Thank you Paul. I do not believe the jar is corrupt, as I have used it in another project and it unzips just fine (that's how I verified the existence of the class). As you said, something else could be interfering. I should have mentioned this, but I am specifically using the Spring Tool Suite version of Eclipse 3.7, and the 64 bit JVM (I'm on Win7 x64). However, I switched to the 32 bit JVM and the error remained. I'll post on the Spring forums to see if others have had this problem, but if anyone here is using STS in this way I'd like to know.
Re: JPA Facet doesn't recognize Hibernate as legitmate [message #711023 is a reply to message #710598] Fri, 05 August 2011 17:32 Go to previous messageGo to next message
I downloaded Springsource Tools Suite and tried it again a couple of different ways, all successfully. Sorry I'm not any help. If you do manage to find out a way that works, or you find out what in particular is causing your case to fail, I hope you can give us a heads up on that.
Re: JPA Facet doesn't recognize Hibernate as legitmate [message #711508 is a reply to message #711023] Sat, 06 August 2011 08:24 Go to previous messageGo to next message
Paul, thank you once again. I have no idea why this worked, but rebooting my system fixed the problem (as well as another where java.lib.path wasn't getting updated). I guess the easy thing to do is blame Windows...
Re: JPA Facet doesn't recognize Hibernate as legitmate [message #739274 is a reply to message #710239] Mon, 17 October 2011 09:36 Go to previous messageGo to next message
Le Drogo Jean is currently offline Le Drogo JeanFriend
Hi everybody,
I had a similar problem and rebooting my computer, don't solve it...
I have a JPA Project that was properly working. To show another developper the configuration that he needs to do, I simply remove from my User Librairy the hibernate-jpa-2.0-api-1.0.0.Final.jar. The error message "The class 'javax.persistence.Entity' is required to be in the selected librairies" appears. That's perfectly normal.
But now, I am tring to put it back and Eclipse doesn't seems to find the class anymore. Puting back the JAR in the User Library and selecting it doesn't change the error message...
Any idea welcome.
Re: JPA Facet doesn't recognize Hibernate as legitmate [message #739292 is a reply to message #739274] Mon, 17 October 2011 10:03 Go to previous messageGo to next message
Ok, I find the problem !
If my jpa-2.0-api-1.0.0.Final.jar is part of my project (for example in a lib directory of my project) then Eclipse doesn't see the class.
If I just move this directory out of my directory project and try again, it works.
It's very suprising for me and might be a bug.
What make me think of the solution is that the default download directory for EclipseLink is out of the project.
icon7.gif  Re: JPA Facet doesn't recognize Hibernate as legitmate [message #892870 is a reply to message #739292] Sat, 30 June 2012 20:40 Go to previous message
Pawel Wloch is currently offline Pawel WlochFriend
Hi Jean,
That's genial you have found it out. Sometimes Eclipse and/or eclipse-plugins leave you without any trace of what could be wrong and often the solution is to start again or search in google Smile.
Pawel
Previous Topic:JPA Diagram editor 0.5.0 not working with Graphiti 0.8.0
Next Topic:Using Dali annotation processor from a maven build
Current Time: Tue Sep 22 12:00:49 GMT 2020
Powered by FUDForum. Page generated in 0.01928 seconds
